Shift+D not working??
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
Hi guys, i have a really strange problem on my Main rig.
Whenever i try to right a capital d, they keyboard does not respond to the shift+d input. All other key combinations are fine as far as i can tell. It's just the shift d combo.
any ideas:confused:
A second, unrelated problem, is related to the printer. It is hooked up to my main rig and shared across a network. Printing from any network computer is fine, it takes a few seconds.
But, on my main rig, when i try to print, it takes about 3 minutes for the print options screen to appear (in any application) and then another 4-5 minutes from pressing the print button to the printer actually printing and the program becoming responsive again (it hangs while waiting for the print job to be spooled)
Both are really strange problems, it may be a sign that i just need to re-install windows, but i'd rather not if possible.
Thanks
NanoTechSoldier
27 (0.01/day)
Both Shift Keys..?? You Could Have The Wrong Keyboard Setup In OS etc.. US - UK etc
Have You Set Your Network Computer, Up As A Print Server..?? or
Have You Tried, Adding A WiFi Router, To The Printer (Using RJ45 To Router) & Having IP Addresses, Set For Your Computers MAC Addresses & Relaying To Another WifI Router Attached To Your Main Rig..??
Virus Scanned All Networked Drives..??
If All Else Fails.. You Should Have A Backup Of OS & Just Format Drives & Re-Install OS.. Shouldn't Take That Long... You're Using An Intel i5 2500k @ 4.4GHz..
4,213 (0.71/day)
Vietnam
Yea, both shift keys. They work with any other letter. I just cannot make a capital d.
e.g. i get: ABCdEF....... if i try to do shift + d, no input occurs.
My printer is set up as a shared printer attached to my main rig. It has no ethernet ports to set up that way, only usb :(
I'm running kaspersky AV, i guess something could have gotten through, i'll run a full system scan.
95Viper
Super Moderator
13,136 (2.21/day)
Try un-installing/re-installing your keyboard driver in device manager.
6,270 (0.91/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
If you select caps lock does it then do a capital D?
4,213 (0.71/day)
Vietnam
I just rebooted my system, as it's been running about 2 weeks without re-boot. Working now :toast:
Weird problem, thanks for the responses.
AAARGGHHHH!!!
Now it has stopped working again!!!!
Caps lock doesn't work, nor does shift :(
DDDDDDDDDD
oh, caps is working now, shift is not.
The problem is confusing the hell out of me. DDDDDDDDDD
And now shift works.
Maybe i have a dodgy keyboard???
I'll try the drivers next :confused:
6,270 (0.91/day)
New York
Wow that is kind of weird...I would suspect the keyboard has damage on the circuit board but other than that I am at a loss.
9,019 (1.40/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
I'd try it out with another keyboard first.
Also run ccleaner, it does miracles :)
Totally unrelated, and perhaps also irrelevant (apart from the uniqueness of the problem), occasionally I get issues with the forums having icons misplaced, or someone's avatar instead of the "quote" button for example. I don't know what's the cause since no one ever got these problems before, but ccleaner solves them.
Trying won't hurt.
6,270 (0.91/day)
New York
Trying won't hurt.
Yeah that's because CCleaner is cleaning the web browsers cache.
9,019 (1.40/day)
Processor i9 9900k
Keyboard Motospeed
Yes. I was thinking perhaps the OP's pc has some software or programs which affected the capital D and running ccleaner might clear it.
Perhaps there is a special symbol on the D letter?
For example on my '3' letter I have the Euro symbol. But pressing Shift-3 gives me this: #
Pressing Alt-0-1-2-8 gives me the €.
Perhaps you're using the D for another command?
43,249 (6.74/day)
unplug the keyboard and replug it
9,019 (1.40/day)
Processor i9 9900k
Keyboard Motospeed
Try this out.
I stand to be corrected but I guess that if it works fine the problem is with your keyboard whereas if you still get the error, the problem is with software or other settings in your pc.. (sorry if that wasn't too helpful :eek: )
(You can change the language if you're using another one, I tried both English and Vietnamese myself and my 'D' using Shift-d appears correctly.)
4,213 (0.71/day)
Vietnam
Thanks BP.
I'll try it as soon as it breaks again. I wasn;t working 5 mins ago, but now it is.
Everything is in standard US. No Vietnamese key programs and no macros.
Hmm..
Stopped working again, must be mechanical. Weird that shift works with every other key except 'd'
I have a spare keyboard somewhere. I'll have to dig it out and give that a go.
I tried the website, and while typing, it recognizes the left shift key + d being pressed atm, but when i try right shift, it recognises every key other than D.
It may just be the right shift key as i usually type without realising which shift i am using.
Edit - ok i unplugged it and replugged it in, and it's the same. guess i need a new KB
43,249 (6.74/day)
Wonder if Shorting is the cause, btw this a USB keyboard or a PS/2 Keyboard
Thanks BP.
Hmm..
4,213 (0.71/day)
Vietnam
It's a ps/2 kb hooked up to a usb converter. I've only had this problem the last week, but it could be the fault of the adaptor i suppose.
ok, i puled out an old ps/2 kb from a box of junk and it appears this one works. I guess i need a new KB.
Very strange, i've heard of single keys failing, but never keys failing only in a combination.
43,249 (6.74/day)
Your motherboard doesnt have a PS2 connector does it?
4,213 (0.71/day)
Vietnam
I just edited my above post as your came up. I'm not sure if it does. I use an adaptor + extender so i can get a decent length. I like to sit back on my chair and put the kb on my lap :)
Anyway, found the problem... never seen anything similar before.
I have a semi-built spare rig, with a ps/2 port, so i'll triple check this kb on that rig as soon as i get time.
43,249 (6.74/day)
so your saying the adapter isnt junk?
jurrai
1 (0.00/day)
I had the same problem. turns out, my F3 key was stuck. once i popped it out the shift-d worked again.
NZChuck
1 (0.00/day)
Had same problem with right Shift and D only. Left Shift and D was working, right Shift and D was not doing anything (not a small d but nothing at all). All other Shift key combinations were working. In my case turned out the print screen button on the keyboard was stuck. Once released worked fine. So if a key isn't working pays to see if some other keys are stuck.
6,270 (0.91/day)
New York
6+ year necro resurrection.....
