Single RGB fan connection confusion...
424 (0.12/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
Hi..I am in the middle of an ongoing Ryzen build...my motherboard is an Asus prime B450M-A which has a 12v rgb header for led strips... I will be using a Corsair Carbide 175R mid tower case for the system...now the 175R comes with a single front 120mm RGB fan..the fan has 2 cables, a 3 pin fan power cable & a 4 pin RGB cable marked 12v and an arrow over pin 1.....
Now i have connected the 3 pin cable to my motherboards' case_fan header and the fan spins normally....but the rgb leds do not light up...can i connect the 12v rgb 4 pin cable to the 12v rgb header on the motherboard or do i risk damaging the mb or fan..
The Corsair Carbide 175R case manual tells you to connect the 4 pin rgb cable to the motherboard header though...
638 (0.32/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Motherboard TUF GAMING B550-PLUS WIFI II
Memory 32 gigs - 3600hz
Video Card(s) EVGA GeForce GTX 1080 SC2 GAMING
Storage NvmE x2 + SSD + spinning rust
Display(s) BenQ XL2420Z - lenovo both 27" and 1080p 144/60
Case Fractal Design Meshify C TG Black
Audio Device(s) Logitech Z-2300 2.1 200w Speaker /w 8 inch subwoofer
Power Supply Seasonic Prime Ultra Platinum 550w
Mouse Logitech G900
Keyboard Corsair k100 Air Wireless RGB Cherry MX
Software win 10
Benchmark Scores Super-PI 1M T: 7,993 s :CinebR20: 5755 point GeekB: 2097 S-11398-M 3D :TS 7674/12260
Does this Header work ?
if it dont you might want to RMA.
424 (0.12/day)
130060
my motherboards header is the one on the right....my fan cable also is the same..
yes the same header....i still have not connected the fan cable yet...scared about damaging the mb..
638 (0.32/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
It should be able to RGB, i use this as source.
424 (0.12/day)
what i am confused about is that most sites/videos show connecting multiple fans and/or rgb splitters to the header......the mb manual shows that the header can output 12v 3 amps...will it burn out a single rgb fan if connected..?
638 (0.32/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
No no, it supports up to 12v 3 amps, there is a voltage controller :)
424 (0.12/day)
so it won't burn out the rgb leds on a single fan?..thank you...that's a relief to hear.. so you mean the mb will control the volts/amps required for a single fan automatically?..
638 (0.32/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
And up to 50 LED "strips" even
sneekypeet
Retired Super Moderator
29,441 (4.39/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
The headers can power single devices or many. However, as you get into two, three, or more fans/strips, they tend to come with a hub which just uses the signal for rgb, and are powered via SATA or Molex.
424 (0.12/day)
thank you eskimonster...i am currently away from home...will update as soon as i have made the connection..
Aha..i see... this is the first time i am working with an rgb setup...thank you sneekypeet..
130062
i had already connected an led strip light to the header during assembly some days back...and the header works...but am yet to connect the rgb fan to the header..
Thank you all for your quick and expert opinions.. will update soon..
1,327 (0.37/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | QKZ x HBB
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Windows 10 Education 22H2 x64
I have limited experience with these lighting shenanigans but I think that's only for A-RGB. RGB pin can power more RGB things since they're 12V while A-RGB pin needs hubs that pull power from SATA since they're 5V.
424 (0.12/day)
130095
You mean the ones on the left side right?...my mb has only 12v header..not 5v addressable one..
The 5v header has a missing pin....mine has all 4 of them..
The rgb connectors look the same tho....chances of connecting a 5v cable to the 12v header is very high..
5,896 (2.93/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
View attachment 130060View attachment 130060
Arrow should match pin 1 on the motherboard RGB header. Mobo should have two types of connectors, 4pin for RGB and aRGB one.
130105
Your mobo has 12V RGB header, you have a 12V RGB connector in your case.
424 (0.12/day)
Thank you chomiq..
5,896 (2.93/day)
Poland
424 (0.12/day)
Hey, I want through the same dilemma this Saturday, reading manual for case and mobo solved it.
i was completely confused after reading both manuals..:D...i didn't know rgb components came in 12v and 5v adressable versions...atleast one of the manuals should have mentioned this..:kookoo:...
Really hard being a first timer with rgb components..
5,896 (2.93/day)
Poland
I'm actually impressed they've managed to narrow it down to "only" two connectors.
1,327 (0.37/day)
Nowy Warsaw
System Name SYBARIS
Actually there's four!!! According to MSI B450 Pro Carbon AC I was looking at it has J_RGB (12V 4-pin RGB), J_Rainbow (5V 3-pin A-RGB) and J_Corsair (dunno the specifics but A-RGB pin for Corsair products lol). Then Gigabyte has a completely different 3-pin A-RGB header. Last I checked they ditched it in favour of same 3-pin ARGB header others (ASUS, MSI) use.
And OP you're mistaken. RGB and A-RGB are different things. RGB is like if you have a TV and you can change the color of every pixel to the same color. So the TV is blue/green/red/purple for the whole screen.
Addressable is like more refined. You can set it like RGB but also control individual pixel to output different color. Also make each individual pixel turn on and off.
That's why A-RGB things are more expensive than RGB version of the same.
Example for ARGB:
Example for RGB:
8 (0.00/day)
System Name Ryzen H20 Super Duper Looper Cooler Gaming King of the HILL PC
Processor Ryzen x1700 @4.0ghz
Motherboard Asus Prime X370-Pro
Cooling DIY Water Loop CPU only
Memory Corsair 3000mhz 16-16-16-35-1 DDR4 16GB
Video Card(s) Asus 2070 RTX Super Dual Series
Storage 3xSSD (480GB, 250GB, 120GB) & 1 HDD 3TB & 1 SSHD 2TB (Seagate both)
Display(s) 4K HDTV & 27" 1080P LCD & HTC Vive VR
Case Phanteks Eclipse P400
Audio Device(s) Soundblaster X
Power Supply Corsair TX850
Keyboard Logitech &Corsair
THis is my patented 303 Multitool RGB Wire Connector.... or like we lazy bums at DIY call it, used hell of a lot of black insulating tape
8,534 (3.23/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Example for ARGB:
Example for RGB:
Don't forget Gigabyte's 5 Pin RGB connector so that the fan can do white. The 3 pin is still a unique design as well.
424 (0.12/day)
now i have another doubt...is there any possibility of conflicts between Asus Aura sync and Gigabyte Aorus engine+RGB Fusion?.....i have a gigabyte aorus rx570 4G...
i remember reading somewhere that asus and gigabyte are sworn enemies...and their rgb control software is incompatible with each other..
Aorus engine is already full of bugs..
8,534 (3.23/day)
Cooling In Win SR36
There are some workarounds to allow that, Cooler Master on their ARGB 3 way splitter has a selection for Gigabyte's 3 pin. Gigabyte did update their boards to allow you to use a standard 4 pin in the 5 Pin header. There are all kinds of RGB accessories you can buy on Amazon (mostly from China) like ARGB frames, cables and splitters.
https://www.amazon.ca/Way-LED-RGB-S...3CF5HSE1XY&psc=1&qid=1566834906&s=electronics
I have bought all of these and they all work like a charm.
424 (0.12/day)
that's great..thank you kapone32..
8,534 (3.23/day)
Cooling In Win SR36
5,047 (0.96/day)
Iberian Peninsula
YEP, for more than 1 A-RGB fan you need the splitter cable, as the one from Corsair linked above. No need for controller boxes if your mobo has Aura or similar.
