Slow NVMe SSD especially write speed
573 (0.20/day)
Latvia
Processor AMD Ryzen™ 7 5700X
Motherboard ASRock B450M Pro4-F R2.0
Cooling Arctic Freezer A35
Memory Lexar Thor 32GB 3733Mhz CL16
Video Card(s) PURE AMD Radeon™ RX 7800 XT 16GB
Storage Lexar NM790 2TB + Lexar NS100 2TB
Display(s) HP X34 UltraWide IPS 165Hz
Case Zalman i3 Neo + Arctic P12
Audio Device(s) Airpulse A100 + Airpulse SW8
Power Supply Sharkoon Rebel P20 750W
Mouse Cooler Master MM730
Keyboard Krux Atax PRO Gateron Yellow
Hi, i have noticed that crystaldiskmark and as ssd speeds don't match advertised speeds of Silicon Power UD85 2TB. There are significantly lower write speeds and also lower read speeds to.
Fresh w11 install and ssd health is good! MB ASRock B450M Pro4-F R2.0 installed on first NVMe slot.
Any thoughts on what's is going on ?
My Score
7,390 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (RX 7900 XT/XTX or RX 9070 XT?) | Intel® Iris® Xe Graphics
Can you please check the PCI-E link speed?
A note from ASRock with your board:
- 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Vermeer, Matisse, Cezanne, Renoir, Picasso, Summit Ridge, Raven Ridge and Pinnacle Ridge)
With your Ryzen 5 5600 codename Vermeer you should see Gen 3 speeds it could be that the SSD doesn't work well with Gen3 but that's really rare cases.
If you haven't try update the motherboard bios or ssd bios.
430 (0.11/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
I had the same problem with an ADATA Gammix S5 256 gb nvme ssd...on a B450M-A motherboard running a ryzen 5 5600 processor.....tried all kinds of fixes....did not work....finally replaced the drive with a crucial nvme 500 gb ssd....working perfectly now....
3,832 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
That's a sign the ssd is degraded/dying.
430 (0.11/day)
i have heard that flashing the firmware of the nvme can potentially fix the issue..i have not personally done it myself....its better to buy a new ssd rather than risk it....
1,069 (0.17/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 990PRO 2TB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
He stated the SSD Health check was good,
But I would recommend to check that in details,
@Krit Can you run HDD Sentinel or some similar utility and post here the results?
825 (0.43/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
Is that your system drive? How full is it? These factors could affect the SSD speed
Also if you've written a lot to it already, it could be that the cache is fully used up so the speeds drop
ir_cow
4,736 (0.79/day)
USA
It's rare budget drives ever match advised speeds once you start to use them and isnt "fresh"
3,907 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Also worth noting that advertised speeds are usually from some benchmark that more often than not has no real relation to reality. The small print for most manufacturers says the numbers come from ATTO.
879 (1.20/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium, RM850X (2024)
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum Cherry MX
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
With budget drives it's sometimes a lottery, they use components of lower quality and in some cases even the used part's like Controller and Nand are completely different then advertised. ADATA was doing this last year with budget drives, using lower quality and completely change the drive, it was re-tested and almost 50 percent slower! Without saying anything or let the buyers know this.:mad:
7,390 (1.04/day)
Have anyone ever considered doing tests on drives that is not running a OS on them?
This in my experience gives the best read/write result just a suggestion.
879 (1.20/day)
Belgium
I always test a drive without the OS being installed on it. You always lose some performance when you do the test, because the OS is always busy doing background tasks writing and reading to the drive. Another good test is copy big game files to that drive, you see the performance in real time! And you see also how good the DRAM and SLC cache is on your drive.
990 (1.40/day)
System Name BarnacleMan
Processor 14700KF/12100
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte ud850gm pg5
Keyboard msi gk30
My Silicon Power A60 sucked too. It was fast, for the first 10GB or so, then we're talking like kilobytes a second.
Have you confirmed its using all 4 lanes?
3,401 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
My Score
Under settings there is an NVMe mode. Make sure you turn that option on and retest.
30 (0.06/day)
It looks like TLC speeds. Give the drive one day or another to see if it recovers its full speed. If it doesn't, then secure erase it and reinstall the system.
BTW, did you check the drive with CrystalDiskInfo?
