Solar System
Or I can rely on my own research. Yeah, I think I'm gonna do that. Thanks for the tip though.
You bet! Good luck with that research.
Let me know how your research into Dark Energy and Dark Matter go.
Make sure you throw Black Holes and Neutron Stars in the mix as well.:laugh:
Happily. Can already do that. News flash for you there bub; dark matter and dark energy do not exist. More to the point the energy/matter science thinks is "dark" actually isn't. It's simply beyond our range of observation. All of the work being done to "find" dark energy/matter is a waste of time, money and effort. We will never find such because we are physically incapable of interacting with them.
Happy, can already do that. News flash for you there bub; dark matter and dark energy do not exist. More to the point the energy/matter science thinks is "dark" actually isn't. It's simply beyond our range of observation. All of the work being done to "find" dark energy/matter is a waste of time, money and effort. We will never find such because we are physically incapable of interacting with them.
I agree with a lot you have to share... to a point.
I do disagree that we are incapable of interacting with the cosmic sector... this forms the basis for our universe.
Good to see you haven't fallen for the Dark Energy/Dark Matter ruse.
There must be explanation for the "physical" observed as so there must be an answer laying wait to be found.
I submit to you that you will not find any such answer by following today's "modern" astronomy forums.
What otherwise would be force fields if not the effect of time on space?
The two are a balance in one.
That assumes the universe exists as it is described, a "Space Time Continuum". However that can not be correct as the universe behaves is ways that contradict that description.
The true nature of the universe is scalar.
What you and I experience as our reality is our own 3D construct that we call extension space which exists in three dimensions of coordinate space with scalar (clock) time. Would you believe there exists this relationship in reciprocal: 3D time with scalar (clock) space? It's true.
Have you read Plato's The Allegory of the Cave? Classic.
https://web.stanford.edu/class/ihum40/cave.pdf
This image captures a landform on Mars peculiar to the Hellas Basin, sometimes referred to as ‘banded terrain’.
A New Crew Heads to the Space Station
Saturn at equinox
This photo of Ceres and the bright regions in Occator Crater was one of the last views NASA's Dawn spacecraft transmitted before it depleted its remaining hydrazine and completed its mission.
Saturn at equinox
Equatorial rings such as those shown in the image above are caused when a star reaches supernova and portions of some layers are accelerated FTL into the 2-x intermediate speed range and has only a 2D spacial representation in or fixed 3D coordinate system. This 2-x motion will give off X-rays as matter drop back down to the low speed (1-x) range. Yes, Saturn's rings are an X-ray source.
This is similar to the effect seen in some supernova where the explosion is violent enough to create 1D polar jets. This motion, also FTL, has been accelerated to the 3-x ultra high-speed range. Matter dropping below "Light speed" from the ultra high-speed range will emit gamma rays.
Low speed (1-x) matter is distributed spherically (3D) in space.
Matter accelerated FTL will emit RF. An example would be a spark gap interrupter in a LC tank circuit. Pop! + RF "interference."
Saturn has much more in common with an early Main Sequence star than a planet.
That it has rings means that it has supernova'ed at least once already.
Judging by the faint glow... I would suspect not much fuel to fission at the moment.
Credit: NASA/JPL-Caltech
Uh oh:
"The probe, known as a “mole”, started to burrow into the surface Feb. 28, hammering its way into the surface. Tilman Spohn of the German space agency DLR, principal investigator for HP3, said that it appeared to reach a depth of about 30 centimeters after a four-hour hammering session. The probe, though, went no deeper during a second, five-hour hammering session March 2, after which the instrument team decided to hold off on further efforts to burrow into the surface.
Spohn said at the conference that the team speculated that the probe hit a rock shortly after burrowing into the surface that deflected it by about 15 degrees but allowed it to continue. “At about 30 centimeters depth we encountered something,” he said. “We don’t know yet if it’s a harder layer of regolith or a rock.”
https://spacenews.com/engineers-still-studying-problem-with-insight-heat-flow-probe/
Sun
NASA's InSight lander took this series of images on Tuesday, March 5, 2019, capturing the moment when Phobos, one of Mars' moons, crossed in front of the Sun and darkened the ground around the lander. The images were taken by InSight's Instrument Deployment Camera (IDC), located on the lander's robotic arm.
Martian lunar Eclipse wow that's a Rare event ( especially for us Terran's to observe in any way)
that's a pretty good close up of the moon; where did you get that?
its really too bad we didn't actually go there...
EDIT: oops, my bad... I just saw it was Mars....wait...if we can see Mars that good; cant we
see 1/2 inch pebbles on the moon?...
What do you mean by "cleared"? Do you mean debris in it's orbit? Earth hasn't done that either..
It basically means it's the big fish in it's oribit in terms of being the majority of mass. Pluto is not.
lol Earth hasn't done that. Of course it has, that is one of the definitions of being a planet and the reason it was decided Pluto was not one.
If that were true, we would not be pelted every 30 seconds by meteors and meteorites and other such leftover rubbish from the formation of the solar system. No it hasn't. By the same measure, none of the other planets have either. Such a condition is a completely lacking way to define what a "planet" is, even if partly. Just because general academia accepts it doesn't make it correct.
Well forgive me, It seems the definition of a planet will have to be re-written because you don't agree with it. Clearing the orbit does not include specks. the earth and the other planets have cleared their orbits, whether you agree with it or not.
This is more acceptable. However, Pluto is the big fish in most of it's orbital path. It is possible, and entirely likely, that Pluto was "nudged" out of it's original orbit by an unknown astronomical event. Pluto is in it's own orbit around this home star. It also has a mass sufficiant to maintain satellites in stable orbit around itself. Those are acceptable definitions.
Lots of qualifed people don't agree with it. I'm hardly alone.
Your opinion of course.
