Soldering Iron Kit for PC repair
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Motherboard TUF GAMING B550-PLUS WIFI II
Memory 32 gigs - 3600hz
Video Card(s) EVGA GeForce GTX 1080 SC2 GAMING
Storage NvmE x2 + SSD + spinning rust
Display(s) BenQ XL2420Z - lenovo both 27" and 1080p 144/60
Case Fractal Design Meshify C TG Black
Audio Device(s) Logitech Z-2300 2.1 200w Speaker /w 8 inch subwoofer
Power Supply Seasonic Prime Ultra Platinum 550w
Mouse Logitech G900
Keyboard Corsair k100 Air Wireless RGB Cherry MX
Software win 10
Benchmark Scores Super-PI 1M T: 7,993 s :CinebR20: 5755 point GeekB: 2097 S-11398-M 3D :TS 7674/12260
No not yet,there is so many to chose from.I will get one of thouse cheap kits ,and see where i go from there.
No i don,t think so,it is all right for stuff that fits in the letterbox.
ah okey, i bought like 500+ random things from them, they never not helped me, if i got wrong item or broken. Money was always returned to me in 2 days, if something was wrong with the purchsed item FYI.
2,463 (1.77/day)
UK
I get your point there,but bigger stuff i get click and collect.
Few soldering irons can handle the big ground planes of mother boards.
Desoldering Pump 230V : Amazon.co.uk: DIY & Tools
might work (it's the hollow tip that helps)
It is cheap but i would have to buy other stuff for it.
Get on amazon.com and look at reviews
I see you have a forum on here *How to solder*i will check it out. :)
I think i will get this one
Soldering Iron Kit, Tabiger 60W Welding Tools with Adjustable Temp 200-450°C and ON/Off Switch, 5 Soldering Tips, Desoldering Pump, Solder Wire, Wire Stripper Cutter, Stand, Tool Case​
14 in 1 £15 loads of reviews i know you can,t beleave them all
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
2,463 (1.77/day)
UK
I was going to get one simuler to the one you have
solder wick
1* soldering iron; 1* multimeter; 2* multimeter pens; 5* soldering tips; 1* solder wire; 1* desoldering pump; 1* soldering iron stand; 1* cleaning sponge; 1* screwdriver; 1* wire stripper cutter; 1* anti-static tweezers; 1* insolation tape; 2* electric wires; 1* PU bag; 1* User Manual
Thats why i will properly get the other one i showed you this one does not have Solder wick:(It seems like you and me are the only ones on here after kits like these. o_O
Digital Multimeter,​
are the
The problem with Ali Expres you can,t say you want the lowest price of something like you can on eBay. :( And then the postage varies so much.You can get something that is the lowest price but when you pay the postage the the item comes out more exspencive.o_OThats one of the reasons i use eBay.I am onlly using Amazon because they have given me a 30 day trial for Prime.I don,t buy enough stuff on there to warrent paying for a year Prime membership.
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
solder wick
View attachment 306137are the
i always considder the PP, they try hard to sell low and PP makes up the cost for the low price. but i´m well aware of it and dont bite. :)
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
I would rather have lower postage and higher cost for the item.
i´m Diamond member on ali, i get some exclusive member prices now and then.
807 (0.64/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
That switch in the middle of the cable must be a PITA if you start moving it around.
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
That sounds cool. :) How do you get to become a diamond member, by buying lots of stuff from them? o_O
yea, i bought like 600 items+. got Diamond rank about 500 items. Over a 6-7 years periode.
2,295 (1.21/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
The only coupons I get from AliExpress are for like $2-$3 off $100. But you cant beat alot of their deals with a stick compared to Amazon. Anything wcing gear from Byski and Barrow is wayyy cheaper vs Amazon. The 3-4 week wait stinks but it's worth it if your buying a large quantity of fittings and a GPU block.
The soldering kit I picked up from Amazon was like $25 but it included everything needed to get started. I did end up replacing the iron with a cheap Weller because the one that came with the kit was junk. Sometimes its better not to go whole hog with gear until you know what your strengths and weaknesses happen to be. My particular soldering weakness is I'm just not very good at it! So it worked out perfectly only spending $40 total.
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
i don´t have Amazon in DK sadly.
473 (0.49/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
I have a <$40 'import' kit off eBay. I think it's supposed to be a Hakko 936 clone/derivative.
(nearly identical to my unit from 4-5 years ago: ) https://www.ebay.com/itm/234096664500
It's been dropped off shoulder-height shelves onto concrete and ran over by a 400+lb power wheelchair+occupant.
Still works, even if part of the plastic casing is broken off and rattling around inside the power unit. :laugh:
I have the Hakko 936 that I bought new off of Ebay from a woman that retired from the electronic industry for 75$ shipped over 15 years ago, and it still works like a champ.
I would go for something like this and just buy the tweezers and cutters separately and the solder and flux as well. You will get better quality and a more flexible setup for soldering.
668 (0.30/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
looks pro
2,463 (1.77/day)
UK
Wow thats a lot of stuff o_OYou deseve it after buying so many iteimso_OJust recived my irem but it was the wrong one. :(
looks pro
They have sent the wrong item i can,t see any where to ask for a refund , or for them to send me the right item :(I can,t make head or tail of how you can get in touch with them to get a refund or for them to send me the right one. :( i wanted this. High Quality 1PC SATA Interface Network Adapt they sent me :(They have a picture of the IDE one on the order ,if i wanted one of those i would not have. paid 12.30 for it:(
