[Solved] Recommend me quiet but quality PWM fans without 0rpm option
4,698 (0.95/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
BIOS fan profiles all @ 100% PWM, tried splitters, different headers, BIOS update, I also found MSI boards with this issue...
have you tried different fan connectors on the motherboard to see if the problem repeats itself?
18,584 (2.68/day)
System Name AlderLake
You mean fan headers of the motherboard I guess, yes tried them all I think...
It is always randomly..
5,689 (1.10/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
18,584 (2.68/day)
What are the noise levels at those RPMs? I imagine at 3000 it's pretty loud. :eek:
These fans have 3 modes, I will try them at max 2500rpm first.
This is at 1500rpm, not louder than noctua nf-a12x25
tabascosauz
8,192 (2.35/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Typhoons are not for the faint of heart. You can chop carrots with one of those.
Vento Pros only the 2150rpm version of GT not the extended 3000-5400rpm versions
A12x25 and T30 are both highly GT-influenced designs and have higher RPM ranges than Vento Pro. You're telling me that Vento GT @ 2150 somehow chops off fingers but the T30 @ 3000 (that is heavier with thicker and harder fan blades) is safe for work?
If the noise is a concern, all of these fans are PWM for a reason.
Didn't find a true solution with google.
Hope these new Be Quiet! fans fix this issue..
New York Lol GIF by Lifetime
Did you ever try voltage control vs PWM?
SW4 is a solid choice.
18,584 (2.68/day)
No I didn't try DC mode , since they are PWM fans.
I think so, would be nice if it fixes my problem.
Also they should be good enough for a future CPU upgrade.:)
The new fans should arrive tomorrow if there aren't any delays.
tabascosauz
8,192 (2.35/day)
Western Canada
System Name ab┃ob
No I didn't , since they are PWM fans.
It's just an alternative way to control fan speed with the 3rd instead of 4th pin. Easily changed in the dropdown in Gigabyte bios fan control.
Voltage is a necessity for A12x25s on Y-splitter that don't play nice with Gigabyte boards and abruptly stop. Stands to reason it's worth trying even if no Y-splitter.
9,439 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Power Supply Deepcool 1000M
Keyboard Logitech G510
I was talking abotu the Typhoons I had one back in the day before PWM. The 3 pin was the connector so full speed it was and it was by far the fastest RPM fan I have ever had. I think I still have it in a bin somewhere. I have the Noctua 140mm 3000RPM and they are nothing like the Typhoon at 120mm.
1,210 (0.20/day)
Any other options?
Was just looking at the https://www.scythe-eu.com/en/products/fans/kaze-flex-120-slim-pwm.html but they only go to 1800rpm @ 50.79 CFM..
Need at least 60 CFM if possible...
Got 1 of these at top-exhaust but becomes noisy at higher rpm's, was otherwise been a good choice with it's 1300rpm , 74.25 CFM..:ohwell:
Edit: Ok the Scythe Slipstream 120 PWM is not that unbearably loud, just ran it at 100%, maybe I have no other option than Scythe slipstream 120 PWM fans...
Scythe Slipstreams are ancient. I remember people talking about those all the time back when I frequented overclock.net more than a decade ago. They are pretty quiet, but they're also known for having horrible static pressure. You won't get 60CFM from those when mounted on anything.
18,584 (2.68/day)
Ordered 3 Be Quiet! Silent Wings Pro 4
1,210 (0.20/day)
Those are pretty good quality fans. I think you'll like them.
7,078 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Give us an update on how well they work for you.
18,584 (2.68/day)
Well, they should work as good as the 3 Noctua's NF a12x25's I have according to W1zz's review,
the SW Pro4's are even more powerful (CFM) at 3000rpm than the Noctua's, but I'll set the switch at 2500rpm,
which I expect to be good enough to cool my i7 12700K...
I just hope it fixes my fanstop on startup issue...
7,078 (1.01/day)
USA
Mouse Zowie EC3-C
I have no issues with the NHD15S, if you could fit one of those. The 14cm Noctua doesn't seem to turn off.
Edit: I had a similar issue you describe with my old Gigabyte where it didn't provide enough start up voltage before PWM so the fans wouldn't start spinning / would stop spinning during the boot if the PWM curve was too sedate. Thankfully the ASRock and EVGA motherboards I have had since provide a nice big blip of voltage before going into PWM mode.
18,584 (2.68/day)
I used the same fans/cooling setup with my previous Asus Z170 built, never had any issues.
The fans do start spin all though as soon as I hit the power button...It was few seconds after that 1 noctua would randomly stop..
I searched a lot on google about this issue, I have found it also happens with some MSI boards and maybe even more brands if you search deeper.
Haven't found a real solution online yet though....
The fans should arrive today, keep my fingers crossed.. :D
Mussels
Freshwater Moderator
58,413 (7.90/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
0 RPM mode should never activate on its own
It needs a PWM signal below a certain threshold for fans to stop - so what are you using here? Are you just throwing the default motherboard settings? a fan controller? voltage instead of PWM signals?
PWM is always 12V but pulsing, voltage isnt - voltage tends to have the issues where fans spin down and cant spin up, and various case hubs are PWM only and run at 100% or nothing at all when fed a voltage signal
18,584 (2.68/day)
Have my fan profiles set at 100%rpm PWM mode in the BIOS, until my fan app takes over once in windows.
Mussels
58,413 (7.90/day)
Oystralia
Well that fan app is the cause of your problems then, not the fans.
Put better settings in it, or change software.
18,584 (2.68/day)
If a fan stops, it does it before I login and before the fan app is loaded, so it has nothing to do with the fan app in windows....
7,078 (1.01/day)
USA
Mouse Zowie EC3-C
If you daisy chained the Noctua fan off another fan so the motherboard only sees that fan's tach signal, would that work? By this I mean I have a Aquacomputer Splitty 9 Active hub. I have one of my Thermalright's providing the return tachometer signal to the motherboard. All the other case fans run on the hub, but they are not all identical Thermalrights, so the motherboard only sees the Thermalright's tachometer signal in response to the motherboard's PWM output, but the SP120L and the Noctua NF-A12x15 are on the same PWM output as the Thermalright. I hope that was readable.
If you have another PWM fan that does work, you could try doing this by using a splitter cable so the motherboard just sees the other fan's tachometer, not the Noctuas. Total shot in the dark but might work if you have a pile of fans and cables like I do.
18,584 (2.68/day)
I tried, sometimes it worked, next day it didn't, randomly...
Got the new fans installed, powered on, all fans keep spinning, so all fine for a first start!
I have them set to 2500 rpm max, they do have a jet sound at around 2000, they would be quite loud if I had set them to 3000...
Edit: Tweaking fan profiles...
But.. They move a ton of air!
After running 1 Cinebench R23 multi:
Playing GTA V for about 45 minutes
28,419 (6.76/day)
View attachment 273842View attachment 273843
Wait, what happened to the Arctics? Change your mind?
18,584 (2.68/day)
Yeah cancelled those.
However I still have 3 Scythe fans coming, oh well maybe sell them or maybe keep them for my nephew as case fans.
My motherboard just didn't like Noctua fans it seems...:ohwell:
The fanstop issue seems finally to be solved with my 3 new Be Quiet! fans.:)
:clap:
phill
17,022 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
A real daft question after everything you've tried and reading through all of the thread... What about a simple fan controller??
I must be the only one running one nowadays to be honest.... :eek: Am I that old??
18,584 (2.68/day)
Actually my case has it kind of and I use it for 2 140mm intake fans, the switch has 3 modes, DC fans though, no PWM.
I just prefer full control of the fans with software creating fan profiles.:)
I had a Zalman fan controller in the past with nice display and all, for controlling 4 fans... :D
