**SOLVED**USB drives not appearing in windows explorer? help please
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
As my title says, Im not seeing my usb drives in Windows explorer. i plug them in , there is No sound, no "installing device software", nothing. If i open "my computer" , the progress bar SLOWLY fills up with green, and MAYBE the useless "removeable drive" title will appear, with the right letter, but it isnt any good, because if i click it in ANY way, process explorer freezes. I CAN see the drives i plug in, if I go into Device manager\disc drives. I have tried BOTH Usb 3.0, and 2.0 , annd I have had NO luck. They used to work, but I can think of NO reason why now they do Not. Any useful ideas are Gladly welcomed.**edit** If i have the USB drive plugged in , and try to run Disc manager, it doesnt appear, just a blank window, but if i remove all usb drives, and run it again, viola! it works fine.
If i touch any of these removable drives my PC's windows explorer will freeze
thanks.
Win 7 64B
MoBo Asrock Z68 extreme 3 Gen 3
i5 2500K
Solaris17
Super Dainty Moderator
27,171 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
can you do a scan for viruses and run a SMART scan on your HDD?
I reccomend
Hitman or EEK
and pretty much any HDD program will do but I primarily use gsmart or crystal
also do the disks show up in disk management?
only reason i suggest the smart data is because of the slow access time of explorer.
I suggest the virus scan because i had to deal with a system several months ago that had a trojan that modified files and prevented usb devices from loading.
I suggest disk manager because using bench machines for data pulls from HDDs would allocate all of my drive letters and windows stopped issuing them even after the drive was removed and there is a way to clear them.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
i scanned today @ 7AM, with Malwarebytes Pro, nothing showed up.
what do you mean when you say a "smart" scan?
as far as disc manager goes...thats a good point i forgot to mention. which shows its got to be usb drives caising the issue. If i have the USB drive plugged in , and try to run Disc manager, it doesnt appear, just a blank window, but if i remove all usb drives, and run it again, viola! it works fine.
Solaris17
27,171 (3.84/day)
Alabama
VR HMD Quest 3
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
are the drives readable in another machine?
they work perfectly fine in my other PC its a win10 PC, but i dont think its the OS, its either My USB drivers, or Asmedia usb 3.0 or something like that. i just dont know where to begin
Frick
Fishfaced Nincompoop
19,715 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
It sounds like a classic dead drive thing, but as they work on other systems... Have tou reinstalled the drivers? What about other stuff, like mice and keyboards, do they work as intended?
Solaris17
27,171 (3.84/day)
Alabama
VR HMD Quest 3
I would try ripping out my USB controller drivers and maybe even reinstalling the chipset and start there.
Once we know the drivers are good we can move on.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
yeah that was my first step, but they work A-Okay in the other PC's. they actually show up in less than a second, and are decently fast for what they are, its my Old SB i5 PC, likely driver based rubbish causing the problem.
And what would be the easiest way? just uninstall from "control panel, then you think i should use the intel Driver utility? or go right to Asmedia ? God im outta touch, its been SO long since ive had to troubleshoot something like this....normall its just **swap out random faulty component..insert new one** and im all done ;)
i ran that intel chipset utility, and its giving me an error stating "intel chipset device software Failed" ? where can i get this stuff manually?**nevermind, it turns out that intel driver software wa for theyre Motherboards, not theyre CPU's.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
i ran updates, haven't done chipset yet, restarted, and still when i plugged the drive into the PC nothing, tried the front panel 3.0 = nothing tried the usb 2.0's on my monitor = nothing, tried the 3.0 on the back of my PC = nothing, then oddly enough i tried the 2.0 on the Back I/O of the PC and it worked, so i scanned it and..... NOW i am REALLY stumped. im gonna try the chipset installation, but after that im all out of ideas.
now i cant find the damn Asmedia 3.0 Host controller driver download FFS . where the hell can i get the damn Asmedia USB 3.0 Host controler driver from?? anyone know? i lookedo nasmedias site, but it just tells about the software, it doesnt supply the driver
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
I GOT IT !!!! i ended up installing the oldest Asmedia driver i could find e.g the Disc that came with my board O_O from 2010 :roll: they all are working great now..thanks Gentlemen.
Solaris17
27,171 (3.84/day)
Alabama
VR HMD Quest 3
glad you got it working. make sure to check your windows updats for that asmedia driver in the coming weeks, thats probably what did it to begin with
:toast:
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
:toast:
will do, and thanks again. BTW, heres a separate issue that is bothering me. I ran a file transfer onto one of the USBdrives, to see its speed, did it via the 3.0 port, then on the 2.0 port, and got the EXACT same numbers O_O . i dunno why it isnt benefiting from the 3.0 increased capabilities, but it isnt, possibly because it is Such an old Drive, and is 2.0 only, atleast that is my guess....coem to think of it, i dont think i even own a USB 3.0 drive...now i know where to spend some of that free newegg $$ :) see the photos included, i named the Pic's according to the usb used.
Solaris17
27,171 (3.84/day)
Alabama
VR HMD Quest 3
;) USB is backwards compatible not forward. a USB 2.0 device will max out its speed on a USB 3 port not USB 3 itself.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
yeah i know, i just thought they might benefit from a little extra bandwidth, thats why i said i need to order a 3 drive soon
Solaris17
27,171 (3.84/day)
Alabama
VR HMD Quest 3
remember though you will always be limited to the drive itself. first and formost. There will always be other bottle necks and software over head but bearing in mind all else is fine you will only ever pull what the stick itself is capable of and even as USB 3 goes not all sticks are created equal. some have drastically different R/W speeds.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
any recommendations? purchase brand wise/type?
Solaris17
27,171 (3.84/day)
Alabama
VR HMD Quest 3
im not to ask here. i care about my ram but not my thumb drives, iv destroyed several kingstons and silicon powers though.
I have an ADATA and OCA drive that have lasted forever. The mushkin drives are nice too.
Athlon2K15
HyperVtX™
7,909 (1.18/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
If you want a drive that will last forever get a Sandisk Extreme
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
not so much last forever, just a good all arounder is all. its been a VERY long time since i sprung for one (usb drive). its one of those things like lighters, or pennies, you just find 'em around, and it seems liek i never need to buy 'em. but now its catching up to me, since my fastest ones, are REALLY slow. ill just check for a reputable brand, and look for good reviews, or good speed ratings.
667 (0.20/day)
127.0.0.1, London, UK
System Name Warranty Void Mk.IV
Processor AMD Ryzen 5 5600
Motherboard Asus X470-I Strix
Cooling Phanteks PH-TC12LS + 2x Be Quiet! Pure Wings 2 140mm / Silverstone 120mm Slim
Memory Crucial Ballistix Elite 3600MHz 2x8GB CL16 - Tightened Sub-timings
Video Card(s) EVGA RTX 2080 XC Ultra
Storage WD SN550 / MX300 / MX500
Display(s) AOC CU34G2 / LG 29UM69G-B - Auxilary
Case CM NR200P
Audio Device(s) Realtek ALC 1220+SupremeFX
Power Supply Silverstone SX650-G 650W
Mouse Logitech G302/G303 SE/G502/G203 / MMO: Corsair Nightsword
Keyboard CM Masterkeys Pro M / Asus Sagaris GK100
VR HMD Oculus Rift S
Software Windows 10 Pro x64 - LTSB
There are updated Asmedia drivers in existence that were edited to support newer OS and so on for specific Asmedia chips. Not sure where I found them on google,
