Sony VAIO PCV-RX1 no life on the PC
2,262 (1.92/day)
UK
I bought this yesterday and looked at videos on them ,i could not see one with my exact modal.I like the way it is easy to get stuff out of there.I have tried the PSU you can see it working 2035 ,so there is no problem with the PSU.I have looked at the manual on here but no picture of the motherboard. :( Looking on the board i can,t see where the front panal connector's go.o_OIt would be nice to get it going, but don,t see how without a picture of the motherboard.Someone on one forum said there might be a problem with the on off button.Where do i start?It is no good taking the board out if i cant connect a power button ,i can,t see a speaker or where to put one. o_O
13,805 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Is the bottom slot populated with a sound card, there appears to be a buzzer on that.
Also older Motherboards like that will have the FP connector positions silk screened adjacent to the pins.
Front Panel connectors are on the bottom right corner of that board.
5,226 (0.85/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
Plug everything back together and if you can find the front power button pins on the motherboard take a flat head screw driver and bridge those two pins to see if the system powers up.
2,262 (1.92/day)
UK
No it is a dial up Modem.
430 (1.73/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
Oh, another timeless generic design made of pure unobtanium? How charming.
You might want to read the board.
FreedomEclipse
~Technological Technocrat~
23,808 (3.75/day)
London,UK
System Name Codename: RX-7878
Processor AMD 7800X3D
Cooling AM5 Contact Frame + Thermalright PS120SE
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Video Card(s) Sapphire Nitro+ AMD Radeon™ RX 7800 XT Gaming OC 16GB
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
You can buy a basic power button or trip it with a flat head screwdriver.
I have a few of these in a draw somewhere. Always handy when youre doing a lot of diagnosing of faulty computers. You can also rip them out of old computer cases if you dont want to buy them.
2,262 (1.92/day)
UK
I don,t think you can take the front cover off.
Thats what i use all the time ,but there are no pins to put it on the board. :( If i new where to fit it would be fine.I don,t know where to trip on the board.:(
2,012 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
in the black box is a connector inserted with the white shaky lines i did- the pins are under there - if not i eat no meal today and only drink further
do ya see it ? thats a big fat black connector you have to pull out but not the socket with the black shaky lines
@Greenslade
2,262 (1.92/day)
UK
@Greenslade
I have put it in there I have tried it where i thought the power switch should go ,I have got all the screws out of the board and it went come out not come out . I see the buzzer is just just above that connector.I don,t know why it want come out, there were loads of screws in there.
705 (0.10/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
You missed the center screw under the RAM latch tabs.
Should be 3 across the top, 3 across the middle, 2 across the bottom (mATX board).
2,262 (1.92/day)
UK
Thanks once again 68Olds no wonder i was having such a job:) That power switch is in the right place isn,t ito_OI am disappointed it is not going to work as i liked the case the way you can get stuff out easy.Its spinning the fan that is i put a new cmos battery in there ,where do i put a speaker in i thought there was one by that connection.
101 (0.06/day)
System Name even lower budget then an old Optiplex :)
Processor Intel Xeon E5-2643 v3 - 3.4GHz
Motherboard Lenovo Orion - X99 chipset
Cooling ID Cooling SE-914-XT
Memory 16GB Micron DDR4 2400MHz
Video Card(s) Nvidia Quadro K2200 4GB GDDR5
Storage 120GB/512GB SSDs - 3TB HDD
Display(s) Samsung UN32EH4003 32" TV/Monitor 1366x768
Case Fractal Design Pop Mini Air
Audio Device(s) Onboard Realtek ALC662
Power Supply EVGA SuperNOVA 550 GA
Mouse MS Wheel Mouse Optical 1.1A USB
Keyboard Saitek Eclipse red backlit USB
Software Windows 10 22H2
2,262 (1.92/day)
UK
Quick post as I have to step out. But having worked on one of these years ago, I vaguely remember the board is very similar to the Asus P4T-M though the front panel pin-outs are different.
Manual: https://dlcdnets.asus.com/pub/ASUS/mb/sock423/850/p4t-m/p4tm-100.pdf?model=P4T-M
Thanks budget_Optiplex :)i looked at it is very simuler to my one.
Even on the video i put on here he thought the motherboard was made by ASUS and this guys was a ASUS motherboard.
[MEDIA=youtube]Raa_WZCzvrc:9[/MEDIA]
I have looked on my board and it says P4T-LE rev 1.03 but i can,t see any Asus boards with that number.I guess the board i have was made specially for Sony.Lot of P4T modals though :(I replaced the CMOS battery and it started spinning .But now it spins for a few seconds and turns off.:(As you can see it needs a good clean.
I Have just tried the two drives and the HDD and none of them work :( So perhaps it was not such a good deal for £1o_OIf the floppy or the board work it could be.
