Sparkle Announces First Single Slot GeForce GTS 450 Graphics Card
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
On the non-standardized coolers they can run fine without a fan. Additionally since its a occupies an additional slot it creates more surface area to dissipate heat without a fan.
I don't think there is a high end card out rught now that wouldn't overheat if the fan was stopped completely. Even the generally lower heat producing ATi cards are running at 85+°C with the fan running at a reasonable clip, stop the fan they will overheat.
And chances are the heatsink on this card will be made of copper instead of aluminum like the dual slot cards, which will cool the card a lot better.
746 (0.12/day)
F*cking finally, Sparkle to the rescue! :rockout: Now I can upgrade this stupid Dell E520's GeForce 7300LE to something more acceptable, which will only take single-slot graphics card due to the case's quirky design.
HaZe303
305 (0.04/day)
Sweden (08-Stockholm)
System Name Desktop PC & HTPC
Processor Intel Core i7 920@4.0ghz & Intel Q9450@3.6ghz
Motherboard Asus P6T Deluxe V2 & Asus P5Q-E
Cooling CPU: TRUE w/Noctua P12 Fan & TR Ultima-90I
Memory Corsair XMS 1900mhz & OCZ Reaper 8gb@900mhz
Video Card(s) Gigabyte GTX460OC1GB SLIx2 @840/1680/2000mhz & ATI HD5870@1000/1300mhz + XFX 9800GT PhysX
Storage 3xSamsung TB1 F1@raid0, 2xOCZ SSD@Raid0, and several others..
Display(s) FS LSL 3260W 26" LCD@1920x1200 & LG 37" HDTV@1360x768
Case Silverstone TJ09B (WINDOW DIY) & Silverstone LC17
Audio Device(s) Realtek HD 5.1 DolbySurround & X-FI Titanium Fatal1ty Pro
Power Supply ThermalTake ToughPower 1200W & Corsair TX650W
Software Windows 7 Ultimate x64 RT7Lite x64 & x86.
You guys think this could be a good card for physx in my ati system? My last pci-e slot only has room for a single slot card, or atleast a card that dont take two pci spaces in the back.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
I'd use something that consumes less power and puts out less heat. A GT240 is a perfect card for PhysX.
5,250 (0.85/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
one slot card nice, quad SLI will be awesome
47,527 (7.48/day)
Ya, i've never understood this kind of design, why put the fan there if it's just going to be blowing the hot air back into the case?
Because it's not that with the fan on its rear, the cooler is going to push air out of the case (it's a single-slot card with no rear exhaust vents). So it makes largely no difference.
2,446 (0.40/day)
System Name Dell Workstation t5810
Processor Xeon CPU's E5-2683 v4 Broadwell-E Technology
Motherboard Broadwell-E X99
Cooling Default fan System Level 3
Memory 48GB DDR4
Video Card(s) Radeon Pro VII 16GB
Storage 2 Internal SSD, 6 External HDD
Display(s) Dell 27 Inch Monitor
Case Dell Precision 5810
Audio Device(s) RealTek High Definition
Power Supply 825 Watts PSU
Mouse Soundless Black Quiet Mouse
Keyboard Dell Black
Software Windows Pro 10 x64
Yea this is really the perfect 450. From the size of the card, i am sure it doesn't draw that much power. Maybe 90w?
I wouldn't spend over 100 bucks for just a physx card. I would buy a simple nvidia card just for physx, gt 240 is best.
bear jesus
1,534 (0.29/day)
Britland
System Name Gaming temp// HTPC
Processor AMD A6 5400k // A4 5300
Motherboard ASRock FM2A75 PRO4// ASRock FM2A55M-DGS
Cooling Xigmatek HDT-D1284 // stock phenom II HSF
Memory 4GB 1600mhz corsair vengeance // 4GB 1600mhz corsair vengeance low profile
Storage 64gb sandisk pulse SSD and 500gb HDD // 500gb HDD
Display(s) acer 22" 1680x1050
Power Supply Seasonic G-450 // Corsair CXM 430W
If anything on a single slot card this fan placement makes more sense to me, if it's blowing at the bracket then would it not give more resistance than if it blows out the other side and at the same time it would be blowing over the vrm's helping to cool them.
Also if the case it's in can't handle the heat it's putting into it then i think it needed better ventilation anyway.
I can't wait to see some reviews as a single slot nvidia card would be perfect for getting my htpc folding.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Yes, but with the fan the way it is now, it is blowing directly against the airflow coming from the front fan of most cases. Resistance should be about the same. However, with the fan the current way it disrupts airflow in the rest of the case.
Our complaints have nothing to do with being able to hanle the heat buildup.
Additionally, if someone is buying thie card they are doing so because they need a single slot solution. That means there will be a card in the slot under the video card. With the fan in its current placement, it is almost guaranteed to be blocked, even by short cards. The other alternative is the card is going in an ITX case which only has room for one card. But most ITX cases have a vent under the PCI slot to allow a little airflow out.
bear jesus
1,534 (0.29/day)
Britland
Very good points, i think I'm getting too used to running without a case so I'm starting to forget the basics :laugh: I don't remember the last time i saw a case without an intake that blew towards the cards and i should have thought about the fan being blocked as well, i always try and space my cards out to give the fans good airflow :slap:
I need to go sit in the dunce's corner and think about how stupid my comments were :laugh:
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
They aren't stupid, they make sense from one point of view, and if you don't have a fan in the front(a lot of people don't) then your point makes more sense than mine. There are also a lot of ITX cases with just abismal airflow and no vent for the air to escape if the fan blew the way I want it to, but then again I wouldn't be buying those pieces of trash.:laugh:
bear jesus
1,534 (0.29/day)
Britland
True but i was thinking about one for my HTPC and it has a fan blowing in from the front thats off to the side a little, so would just push all the hot air at the ram and cpu and there is a card in the next slot so they are things i really should have thought about for my own use never mind others, although the card is a tiny abit pci-e wireless card so would not block it by much.
