- Mar 4, 2005
- 3,652 (0.50/day)
System Name | TheReactor / HTPC |
Processor | AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core) |
Motherboard | ASrock x670e Taichi / ROG Strix z490-e gaming |
Cooling | HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump |
Memory | 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4 |
Video Card(s) | Nvidia 3090ti / Nvidia 2080ti |
Storage | Crucial T700 2TB Gen 5 / Samsung Evo 2Tb |
Display(s) | Acer Predator xb271hu - 2560x1440 @144hz |
Case | Corsiar 550 |
Audio Device(s) | on board |
Power Supply | Antec Quattro 1000W |
Mouse | Logitech G502 |
Keyboard | Corsair Gaming k70 |
Software | Windows 10 Pro 64bit |
According to SerialATA.org there is no difference between cables but just quality of the cable. To achieve 6gbs a high quality cable is required, but any cable will work as long as it has enough copper and low resistance.
http://www.serialata.org/documents/SATA-Revision-3.0-FAQ-FINAL.pdf
See Section 9.
I believe this is part of JEDEC set standards.
One thing that was mentioned was NCQ needs to be enabled.
See Section 9.
