Stupid Fujitsu 16pin motherboard [HELP]
Poolcoder
14 (0.01/day)
So i recently got a good deal for a fujitsu
Esprimo p420
Specs:
i5-4440
Ram: 2x4ddr3 1600mhz
Hdd: 500gb
Gpu: none (integrated)
So i wanted to upgrade to a gpu (rx 480 8gb)
But the power supply is bad, so i had to buy an njoy ayrus 450w psu, but the problem is the motherboard which requires 16pin connector but my psu has 20+4 pin, i cannot find any adapters online, can someone help please?
FreedomEclipse
~Technological Technocrat~
24,538 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Its a proprietary connector. The only way youre going to get around it is replace it with a stock Fujitsu one or get a multi-meter out. snip off the 16 pin on the old power supply and read the voltages to find out which cable goes where on the new PSU so it fits into the 16 pin adapter.
An adapter for these PSUs dont exist.
Poolcoder
14 (0.01/day)
Oh okay, but what if i just use the crapy psu with 16pins to power motherboard, and njoy ayrus 450w to power my gpu drives and fans, will 2 psus in a pc work? (I will leave the crapy one outside of the case)
FreedomEclipse
24,538 (3.76/day)
You could do that but youd need to find a guide on how to trip both PSUs on at the same time so they both run when you push the power button. There are a few that exist
7,412 (2.68/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
just get a cheap motherboard
Cram1956
1 (0.00/day)
I am on a budget i cant buy any more parts,
Actually, converters do exist and even especially for fuji, the problem is you have to buy at least 100 pieces.
2,319 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
btw im curious, how much did you pay for this desktop?
Mussels
Freshwater Moderator
58,412 (7.84/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
@Cram1956 this threads a year old, i think it's a bit late for the OP
Looks like these are still for sale, and the PSU has a special 11V rail that replaces the standard 5VSB rail, so they're basically E-waste
Deleted member 24505
eeew
silentbogo
5,622 (1.36/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
The main problem with those, is that Fujitsu prebuilts have been using something akin to intel's recently introduced ATX12VO. All you have is 12V output, 11V standby(instead of your typical 5VSB) and a little more familiar PSON and PG signals. So, just like on my HP it will be an active adapter with a little buck converter for standby rail.
Not sure why there are no PSU adapters on the market, but if you decide to make your own - here's a link with pinouts and everything you need:
But given that you went with some no-name bottom of the barrel PSU with fake 80+ rating and specs straight from late 90s, I can tell you right away that this is a bad idea. Being "really tight on the budget" is not a good excuse to have a potential fire hazard in your house. Return it right away, and start looking for a proper PSU.
In regards to PSU adapter: I'm sure you can find local dudes that make PSU mods for miners - just ask them to make it for you if you don't know how to do it properly.
Mouffy
1 (0.00/day)
A Fujitsu 24pin to 16pin adapter is available here on eBay. It can be used in conjunction with any standard PSU:
Mussels
58,412 (7.84/day)
Oystralia
This is a really old thread, but to be honest thanks for posting that - it probably will help someone out a lot.
