System boots slow when left powered off for long
1,561 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w 5.1 Home Theater | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Hi all,
Since the last month, I have been facing a strange problem. Suppose I have the system powered off for > 1 day. The next time I power it on, Windows boots very slowly (the rotating dots will rotate 6 or 7 times) and the lock screen and desktop will come slow as if it is booting from a HDD with fast startup turned off. However if I power it off then and power it on after 2 hrs, it will boot fine (rotating dots only twice).
Things I have tried:
Remove, clean, reseat GPU, RAMs, reset CMOS, turned off overclock, cleaned entire system -> No effect
Power on system after two full days, directly go to BIOS and go here and there, wait for some time and exit without saving - Windows boots fine and quick.
Things I have noticed:
When the system boots slow (that is after I power on after a long time), for the first few seconds, there is no disk activity. After it boots up, if I right click and refresh, even that is slow.
If I keep the PC plugged in to mains with the switch on (that is with standby power supplied), the system boots fine even after 2-3 days.
All disks are recognized in BIOS at any given time.
System is rock stable once booted into OS (be it slow or quick). If it boots slow, it will eventually make its way to the OS and when left for sometime (hardly 2 mins), return to normal speed.
I suspect:
Some component, the operation of which is dependent on standby power or the PSU itself.
I have checked CMOS battery voltage and it is at 2.98 V. So I think that is fine.
Info: System specs as on signature, Windows 10 installed on the Kingston HyperX 3K 240 GB SSD. No RAID config done. SMART status of all drives are fine.
Anyone having any ideas?
70 (0.03/day)
Croatia
System Name Level 3 mage
Processor Xeon e3-1225v3
Motherboard Asus Maximus Hero VII
Cooling Huh Stock intel Cooler
Memory HyperX Fury 1866 2x8GB
Video Card(s) R9 280 w/ R7 250
Storage 1TB Toshiba P300, PM981 OEM HP M.2, SA400 Kingston 480GB
Display(s) Some random Acer, Asus VW228N
Case Ehh steel?
Audio Device(s) Logitech S200
Power Supply VS550
Mouse Speedlink LEDOS
Keyboard Genius
Software Windows 10?
Benchmark Scores 1050Ti superposition unofficial world record https://ibb.co/fkQhhc
This is on pure guess, as I saw for new ssd from Samsung EVO from gamernexus and testings how hot they get (around 50*C?), probably as SSD is cold its slow? As it heats up to its operational temperature it works better?
Im on pure guess.
Try windows on HDD if possible, or leaving only windows SSD/HDD plugged in motherboard.
Sorry for stupid reply.
712 (0.22/day)
Croatia
Processor Ryzen 5 3600 PRO
Motherboard AsRock B450 Pro4
Cooling Thermalright Peerless Assassin 120
Memory Silicon Power XPower Zenith 2x8GB @3200 MHz
Video Card(s) Gigabyte RTX 2070 Super Gaming OC 8GB
Storage Crucial P5 Plus 1TB / Crucial MX 500 1TB
Display(s) Dell P2419H
Case Fractal Design Pop Air /w 3x Thermalright TL-C12C
Audio Device(s) Creative Sound Blaster Z + Edifier R1000T4
Power Supply Super Flower Leadex III 650W
Mouse Microsoft Intelimouse Pro
Keyboard IBM KB-8926
Benchmark Scores Turns on on the first try! Usually.
I'd try checking the PSU itself first if you have a replacement. I'd also try booting a live linux distro off a USB to see if it has something to do with the drives.
1,561 (0.31/day)
Kolkata, India
Im on pure guess.
It makes sense in general but the thing is I have noticed that the problem does not happen when standby power is supplied to the system. SSD operation is not dependent on any standby power.
I will give this a shot. So if it doesn't exhibit the problem, what exactly might be wrong with the current PSU?
Mussels
Freshwater Moderator
58,413 (8.06/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
CMOS batteries are 3.3V when new, despite the 3V label on them - its still possible thats part of the issue
going through this with a mobo that uses a non-standard battery, reads 3.2V at idle, but throw some load on and it droops low enough to partially reset the BIOS, keeps corruptign the time (windows was rather confused it was the year 2037)
13,686 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
If the PSU checks out ok, then test the power from the wall socket is what it should be, it may be under powered.
266 (0.11/day)
Processor Intel core i5 4590s
Motherboard Asus Z97 Pro Gamer
Cooling Evercool EC115A 915SP Cpu cooler,Coolermaster [200mm (front and top)+140mm rear]
Memory Corsair 16GB(4x4) ddr3 CMZ16GX3M4X1600C9(Ver8.16)(XMP)
Video Card(s) MSI GTX 970 GAMING 4G
Storage Western Digital WDC WD2001FAS 2TB Black, Toshiba DT01ACA100 1TB
Display(s) LG Flatron L177WSB
Case Coolermaster CM Storm Enforcer
Audio Device(s) Creative A550 Speakers 5.1 channel
Power Supply SuperFlower Leadex 2 Gold 650W SF-650F14EG
Mouse PLNK M-740 Optical Mouse
Keyboard ibuypower GKB100 Gaming Keyboard
Software Windows 7 Sp1 64 bit
something is happening with bios settings I think in particular relating to drives attached and boot device ie when no hdd activity is observed could be the delay for boot device recognition and confirmation, it's either that or the boot device is having power up issues after being off for a long time. try booting from another device first
1,561 (0.31/day)
Kolkata, India
I will get a new CMOS battery first and check since that is quite obvious (what Mussels said).
The bad thing is that it will take 24 hrs before I can actually test it, that too without the PC.
8,160 (2.22/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
If you see the dots in a circle animation, you are already booting windows. Cold boots do take longer mainly because your volatile memory has lost its data and must process it again. Like a car that needs to be warmed up in cold weather.
1,561 (0.31/day)
Kolkata, India
The slowness I am referring to is uncomfortably slow. Like the first boot after a long time takes around 80 seconds and restart or turning on after say 2 hrs takes 15 seconds. Moreover, it never used to happen before.
silentbogo
5,501 (1.41/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
There are some features in Windows that are responsible for this behavior. "Hybrid Sleep" and "Fast startup" are the most prominent.
It's quite normal to see a 15sec startup time after short period of time versus 30sec on cold boot. The difference became even more noticeable since 1803.
Though, 80 seconds is a bit too dramatic, don't you think (especially if you say Windows only does 5-6 circle animations)?
13,686 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Faulty Ram can also cause slow boot issues, I suggest testing one stick at a time.
1,042 (0.35/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
How about you test your system after 2 days with another cloned ssd or hdd?
1,561 (0.31/day)
Kolkata, India
Yeah but even after that, the lock screen, the desktop (after logging in with password) takes time to come. Fast startup is turned off since I built this PC.
Yeah true. But how come system is rock stable after booting up? Also if I power on system after a short while or power on after a long time with standby power supplied, system starts up quickly? RAM does not get any standby power as far as I know.
This I will try. Firstly, I am changing the CMOS battery.
13,686 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
DRAM Training, system with standby power won't have the issue.
So change the CMOS battery first then see if it is resolved.
Mussels
58,413 (8.06/day)
Oystralia
Do you have features like IRST (intel rapid start) or anything with similar wording in the BIOS? Some of those functions are designed in similar ways to hibernation, and that partially working/failing could also be a cause
1,561 (0.31/day)
Kolkata, India
Not that I know of. I will try looking for it once I get home. Carrying a CR2032 while I am typing this.
Found the reason: Came back home and turned on system (almost 24 hrs since last shutdown) and directly went to BIOS. Even BIOS scrolling and menus were slow. Suddenly noticed that the CPU frequency is 800 MHz (ROG BIOS, shown on right) and shortly after it jumped to 4200 MHz and never came down again. Rebooted system using ctrl+alt+del and went to BIOS again. CPU frequency was still at 4200 MHz. Booted up Windows. Booted in less than 15 seconds. Typing this from the exact PC. What can be the issue?
hat
Enthusiast
21,735 (3.36/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I don't get it. Sounds like power saving features that clock down the CPU when under light load... but as far as I know, that shouldn't be happening when in BIOS. Nor should it be happening when you're booting Windows. Maybe check if there's a BIOS update for your board?
1,561 (0.31/day)
Kolkata, India
Okay. Here's what happened. Replaced CMOS battery yesterday, removed CPU, cleaned and reapplied TIM. On booting the system first after cleaning and CMOS reset, the following messages came:
New CPU installed!
Speed 800 MHz.
Same behavior exhibited as before. Everything in BIOS was slow for sometime and frequency then suddenly triggered to 4200 MHz.
Powered off system at 1 a.m. in the night.
Powered on again at 8 a.m. Windows booted very slow. After getting to the desktop, opened up power options and set to high performance.
Opened up CPU Z, speed was 800 MHz at 0.702 Volts. Opened up AIDA 64 and did a FPU stress. Frequency was still at 800 MHz. After about a minute, it went up to 4200 MHz and stayed. Everything became normal as if nothing happened.
Before leaving for office, I downgraded the BIOS to version 3703. After I come back home, I can check it again.
hat
Enthusiast
21,735 (3.36/day)
Ohio
I would expect a little weirdness after replacing the battery and reinstalling the CPU, but setting it to high performance should make it run full speed all the time, at least once Windows is loaded.
You said you downgraded your BIOS... were you already on the latest version?
1,561 (0.31/day)
Kolkata, India
Yeah I was on the latest (3804). Now I am at one step before the latest.
  • Like
Reactions: hat
8,160 (2.22/day)
SE Michigan
System Name Dumbass
So either the chip is faulty or the motherboard. after the BIOS down grade, did you load default settings and save it?
2,074 (0.48/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
Did you try disconnecting all your drives except the Windows boot SSD? If Windows detects bad sectors on a HDD it may possibly be running chkdsk in the background? Just a thought, probably not the problem. I even had a bad DVD burner cause a no boot recently (but that was stuck at POST).
1,561 (0.31/day)
Kolkata, India
Yes I did. The system is running at full stock.
Did once earlier but that is not the issue since that would not cause the CPU to be stuck at 800 MHz during a stress test.
Moreover, all SSD/HDD SMART data are fine with no bad sectors or errors.
40,951 (6.56/day)
Blackviper.com you have something i believe software related slowing down your boot up.
When in doubt, format
