System boots slow when left powered off for long
1,561 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w 5.1 Home Theater | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Blackviper.com you have something i believe software related slowing down your boot up.
When in doubt, format
I don't think so since BIOS also initially shows 800 MHz and the entire interface is laggy and slow.
johnspack
Here For Good!
6,001 (0.98/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 2x 24" 1080 displays
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Windows 10
Benchmark Scores It's linux baby!
Just a throw out idea... could it be memory retraining?
13,686 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
1,561 (0.31/day)
Kolkata, India
800 MHz CPU due to memory? That too even after booting up Windows? I am confused.
I have got another tried and tested CR2032 and replaced again.
When I came back home from office, problem happened again. So it is not a BIOS issue. I have upgraded the BIOS to latest version again.
I was reading some threads on similar issues and one of them suggested it might be an issue with the BD_PROCHOT signal where the motherboard "thinks" the CPU is hot and hence makes it throttle.
It might have happened that the sensor goes crazy when things are cold (it was indeed colder yesterday night than normal) and hence the issue was reproduced in intervals of 6 hrs.
Update: Powered on system today morning after 10 hrs. Booted quick and fine with no issues. Old CMOS battery voltage was 2.87V at no load. Such an issue due to bad CMOS battery?
1,561 (0.31/day)
Kolkata, India
Update 2 : Powered on system after 12 hrs. CPU frequency 4200 MHz, Windows booting fast and perfect. Thanks to all of you who helped. Special thanks to @Mussels who identified the exact issue.
Here are some photos from the adventure. I cleaned VRM section as well as it was dirty.
Before cleaning:
After cleaning (notice the Digi VRM chip which was dirty):
And in case some of you didn't know, the Southbridge heatsink actually has provision for this:
All distant photos shot on Moto Z2 Play and macros taken on my trusty old ASUS ZenFone 2.
hat
Enthusiast
21,735 (3.36/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
What's with that discoloration around the VRMs? Is that normal? :eek:
Glad you got your issue sorted, though.
1,561 (0.31/day)
Kolkata, India
Yeah that is normal and happens in any high temperature area where there is silicon paste or pads.
1,561 (0.31/day)
Kolkata, India
Hello everyone, was not active for quite some time. The problem returned after a few days of the post above. And finally I found the solution (14th September I believe).
There's a "CPU Standby Voltage" for this motherboard (Maximus VIII Ranger) and it was automatically set to a very high value (Deep red colored in ASUS BIOS). I have set it to 1.1 V after a bit of tinkering and since that day, my system has been running fine without any slowdowns. I have even overclocked my CPU now and it runs at 4.5 GHz with almost no voltage change from stock.
Just thought I should update here for the knowledge base and for someone going through a similar issue. :)
40,953 (6.56/day)
When bios get way to complex for their own good is this example
You got a link for the fix?
1,561 (0.31/day)
Kolkata, India
Not really. Since the issue was dependent on whether standby power was being fed to the systen or not, that setting caught my mind. I tried to input the displayed value manually and it was in the deep red zone. I was concerned about the life of the CPU for that and tried reducing it keeping the system stable at the same time. So I set the voltage manually to 1.1 V which is just below the yellow zone and hence should be safe. I checked the dependency and it seems the more I overclock, that standby voltage also increases. Since then, the issue never ever happened. There have been days where I powered on system after 4 or 5 days and it boots in less than 10 seconds with CPU frequency as supposed to be. Basically the fix was stumbled upon. I never thought higher voltage could be an issue. But that voltage definitely goes to the CPU when the system has standby power and even if it is turned off.
40,953 (6.56/day)
This should be stickied
1,561 (0.31/day)
Kolkata, India
Here's a photo of my BIOS screen:
You can see the CPU Standby Voltage near the bottom. Also the settings used for the present OC.
Another thing is that the issue was dependent on temperatures. When it used to happen, it was when the system was cold and it would become fine after it warmed up a bit. I believe it might be a protection mechanism for the CPU preventing damage from temperature spikes when the CPU is cold beyond what it will ever be while running after sometime even if idle.
