Technical Issues - TPU Main Site & Forum (2022)
Status
Not open for further replies.
stinger608
11,250 (1.89/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Yeah I emailed them, but no response. Does anyone have a way to contact them?
I do through the moderation private forum.
I am a moderator on Heatware.
Shoot me a PM with the email that you sent, (just the text of course) and I'll send him a personal message with it.
It can sometimes take a few days to get him to respond, but he is usually pretty good and communications.
197 (0.07/day)
The "Relative Performance" chart is rendered incorrectly on Firefox-based browsers on mobile if horizontal resolution is low. Appears fine on Chromium-based:
wolf
Better Than Native
8,498 (1.31/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I cant seem to quote people and have it display correctly when typing my reply. tried on Win 10 Chrome, Edge and Android Chrome
29,358 (6.90/day)
I'm not seeing this in FireFox. Let me try Iron, BRB..
Nope. This is from Iron(secure Chromium fork). Works just fine..
Ok, back in Firefox. What you might want to try is clearing your browser cookies and site data.
Mussels
Freshwater Moderator
58,412 (7.84/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Getting some serious lag right now, especially loading images on the forum (including the one above in this thread, it just loaded... now)
stinger608
11,250 (1.89/day)
Wyoming
Hmm, not seeing it on this end. Maybe the provider? Check a different site maybe? See if it is loading slow.
W1zzard
Administrator
28,292 (3.73/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Still happening? Post a traceroute to www.techpowerup.com and tpucdn.com.
If it's images specifically, could be your local Cloudflare having issues
Looks perfectly fine for me on Firefox iOS, Firefox desktop with narrow window, Firefox desktop simulating various mobile devices
Any idea how to repro?
Mussels
58,412 (7.84/day)
Oystralia
pings seemed fine, everything just loaded really slow
i made sure my actual connection was idle, as you said may have been a cloudflare issue
197 (0.07/day)
Yes, now I do. I dug deeper and found out it's not the narrow resolution at all. The phone that I found the issue on had the text/font setting on "Large" from the factory -- I guess because the screen is really small by modern standards, but the resolution is not that low, so "default" text would look absolutely tiny.
So, using two Android phones at three resolutions (540x1080, 720x1280 and 1080x1920) I reproduced the issue. In all instances, text/font settings "Small" and "Default" both display okay, but using "Large" and anything above causes Firefox-based mobile browsers to break the performance table. Chromium-based browsers only scale the title and bottom text of the table -- no problem there. I also tried reproducing it in Windows at 150% scaling or simulating really low resolutions, but nothing broke it.
Behold, my MS Paint skillz, just to see it all at a glance:
Edit: I played around with the in-browser font scaling options and the results are the same: using anything above 100% (even 105%) breaks things on Firefox-based browsers, while taking it to even 200% is still okay on Chromium-based ones.
470 (0.30/day)
Belgium
System Name MSi Coffee Lake
Processor i7-8700k
Motherboard MSI Z370 GAMING PRO CARBON AC
Cooling NZXT something AIO loop
Memory 16GB Kingston HyperX 2133 C14 Fury Black
Video Card(s) TITAN Xp Jedi Order Edition
Storage Samsung 960 Evo NVMe
Display(s) Medion 23'
Case Cooler Master Stryker
Power Supply BeQuiet 600W
Mouse Logitech Trackman T-BB18
Keyboard Generic hp
I am seeing a blank page on the TPU website when using firefox 95.0.2
Currently using Edge now without problems.
Edit:
Update to FF 96.0.2 did not help.
I installed FF in a sandbox and from there I can see the webpages.
29,358 (6.90/day)
What you are seeing here is likely a rendering glitch that exists within the settings in your phone OS software. Have tried what you have shown and am not seeing it on my phones(both). Tried both Firefox standard and Firefox Focus, latest version as well as Icecat(Firefox fork). I am not seeing this glitch.
Not seeing this either.
470 (0.30/day)
Belgium
Processor i7-8700k
Keyboard Generic hp
Somehow I have to allow a tracker now to have the website display properly,
whereas everything was working fine before.
I have no clue to what has changed. Maybe some previous setting expired?
I did upgrade from FF version 85 to 95 some days ago.
W1zzard
Administrator
28,292 (3.73/day)
Memory 48 GB
Edit:
I installed FF in a sandbox and from there I can seen the webpages.
Turning off adblock helps?
470 (0.30/day)
Belgium
Processor i7-8700k
Keyboard Generic hp
TPU already was allowed (in ghostery) on the previous version of FF (85).
Then a few days ago i did upgrade FF , and all was fine.
Just this afternoon I saw this sudden change.
Allowing TPU again fixed it.
3,023 (1.15/day)
System Name System V
Processor AMD Ryzen 7 9700X
Case NZXT Source 210
All I see with ublock enabled are white margins, but the rest is fine. Might want to check which specific filter is making that issue happen.
197 (0.07/day)
Glad it's working for you, Lex :) Meanwhile I've managed to reproduce the issue on two more deices -- that's every mobile smart device I've got at home right now. Every device is from a different manufacturer, they all run different Android versions (5 to 10), they all exhibit the same issue.
I also tried toggling the desktop mode on mobile - it's still broken, just looks a bit different.
I'm starting to think it's some obscure Firefox bug.
3,023 (1.15/day)
I reproduced the issue on Firefox Nightly for Android too. Curiously, it doesn't seem like Nightly pays much attention to Android 11 scaling when it exceeds default level, so I had to switch it to manual.
Anything over 100% scaling caused the "stairs" effect.
3,602 (2.60/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
For more then a week (two maybe) i can't open the site with Firefox, had to use another browser to write this. Works fine on Opera, Chrome or Edge. I even have no cookies allowed on opera and it stills open the site, on Firefox i have nothing special and nothing.
I just get a black page, trying to access forum or the main site. Is this just me? weird?
PS: btw its not an abblocker issue, turned off and nothing and with ablocker ON on Opera i still see the website. It's definitely something with Firefox, maybe just mine idk
W1zzard
Administrator
28,292 (3.73/day)
Memory 48 GB
Seems to be just you. Can you try disabling all addons?
3,602 (2.60/day)
Mouse G502
3,602 (2.60/day)
Mouse G502
Did you you whitelist TPU in Ghostery or disable it?
Or an addon/extension, like was discussed above.
i just unnistaled, was the last straw as they say, i swaped it for privacy badger.
Status
