The 5600X Cinebench is stuck at 3.7GHz
16 (0.03/day)
Processor R5 5600X
Motherboard gigabyte b450m s2h
Cooling Arctic Freezer 34 eSports DUO
Memory gskill 3600mhz cl18
Video Card(s) gigabyte 3060ti oc
Storage a2000 kingston
Power Supply 750w
Software w11
My R5 5600X CPU stays at 3.7GHz when running Cinebench tests. In games, anywhere, programs etc. there is no problem. This only happens to me when testing Cinebench. That's why I can't test the temperature.
966 (0.43/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
Please fill in your full system specs Windows 10 or 11 etc.
This information is useful when troubleshooting.
If you have not then you may want to use HWINFO64 for hardware diagnostics. Click free download not the Try Now button!
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
i updated. i using hwinfo during test
1,911 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
CPU requires more power than 76W of PPT that is set as limit.
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
508 (0.14/day)
Ilirska Bistrica, Slovenia
System Name Thermaltake
Processor AMD Ryzen 5 5800X3D @ 4.60 GHz
Motherboard Gigabyte B550 Aorus Elite V2
Memory 32 GB Crucial Ballistix @ 3600 MHz CL16
Video Card(s) XFX 319 Merc 6800 XT
Storage Kingston 256GB SSD | Kingston 240GB NVMe | Samsung 1TB NVMe | Samsung F3 1TB HDD | Barracuda 2TB HDD
Display(s) 34" ultrawide LG 34GL750B 144hz 1ms | 55" LG UR91 4k@60Hz
Case Phanteks Eclipse P400
Audio Device(s) ALC 1220 120dB SNR HD Audio
Power Supply Thermaltake GF1 850 W - 80 Plus Gold
Mouse Logitech G502 HERO Lightspeed
Keyboard Asus TUF Gaming K3
Software Windows 11 Pro x64
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
508 (0.14/day)
how can I do it and why does this not happen in games?
It should be somewhere under AMD Overclocking in your BIOS settings. It doesn't happen in games because games don't usually utilize all threads to their max. It may happen in some games tho.
1,911 (0.61/day)
System Name BOX
Keyboard HP KB-9970
^This + AVX2 (which is responsible for higher power draw in R20/R23), isn't exactly needed all the time in games at the moment.
freeagent
8,596 (3.79/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I have seen this chip use up to 135w PPT with PBO and CO, 76w is strangling it :)
I have my 5600X set to 200/140/180 with an all core CO of -29 and is stable at +150 in core cycler, but I run it at +200, so every core and thread pegs at 4850.
Why those power limits you may ask? Well I lost the piece of paper I had my 5600X settings on, and this is what I used to run my 5900X at :D Don't worry, it cant use the full 200w, unlike 5900X :D
3x0
960 (1.22/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
Guys, the PPT isn't the reason the CPU is stuck at base clock FFS.
By default, PPT is 76W for the 5600X and it should be scoring ~10500 points in R23.
@parinalar Which BIOS version and what scores do you get in CB23?
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
i set 180/100/120 rn and values increased. If I use it like this, will it cause a problem? are the values normal?
966 (0.43/day)
In R23 settings, disable the 10min pass and do a single run. Report you score or post it.
Running AVX2 instruction you can expect a lower all core clock speed VS games. Ryzen master shows you hitting 4335Mhz so I don't see it locked at 3.7.
Also R23 is reporting 3.7 because that is the base speed of the CPU not the actual running clock speed.
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
4.3ghz because i set 180ppt value.
3x0
960 (1.22/day)
Again, please post your BIOS version and the Cinebench R23 result with default PPT values
76W is the default factory PPT and with default values you should score ~10500 points.
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
i have just done with default ppt values
  • Like
Reactions: 3x0
3x0
960 (1.22/day)
Here are my results with default PPT values
As you can see, I have no problem scoring 10k+ points with 76W PPT and 4+GHz clocks.
And you haven't said which BIOS version you're running.
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
mb F64a bios version
3x0
960 (1.22/day)
Try clearing the motherboard CMOS and try again. Turn off your PC, and short these two pins for a few seconds highlighted below.
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
i'll try rn.
freeagent
8,596 (3.79/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
  • Like
Reactions: 3x0
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
I reset the bios, only opened xmp and the result is still the same.
''clear cmos+windows reinstall'' is recommended i've seen some places.
should i try?
3x0
960 (1.22/day)
should i try?
No, not yet. Can you reset the settings in Ryzen Master and uninstall it? Maybe it's interfering somehow.
16 (0.03/day)
Processor R5 5600X
Power Supply 750w
Software w11
No not, yet. Can you reset the settings in Ryzen Master and uninstall it? Maybe it's interfering somehow.
still same
3x0
960 (1.22/day)
That's really weird. It's possible the BIOS version is bugged with that motherboard. You could set a higher manual PPT value as a workaround (since it's the easiest), or try flashing an older BIOS version with AGESA 1203 (F61 for your board).
I don't think reinstalling Windows will fix it, and it's too much of a hassle to try IMO.
