Thermaltake Announces Bigwater 760 Pro Liquid Cooling System
46,834 (7.63/day)
Thermaltake announced the Bigwater 760 Pro CPU liquid cooler. It consists of a CPU liquid block, tubing, and a head unit that occupies two 5.25-inch drive bays. Unlike other closed-loop liquid coolers, Thermaltake's solution uses a conventional CPU block with no other function than heat dissipation. Coolant pump, reservoir, and a radiator ventilated by a 120 mm fan, are located in the heat unit.
Its front-panel keeps you up to speed on the coolant level, and control over its coolant pressure. Its reservoir features a port with which you can inject additional coolant (propylene glycol solution in distilled water). The CPU block features a nickel-plated copper base with mirror finish. The block supports all modern CPU socket types, including LGA2011, LGA115x, LGA1366, LGA775, AM3+/AM3/AM2+/AM2, FM2/FM1. The Bigwater 760 Pro is expected to be priced around US $150.
3,145 (0.67/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
Oh god the nightmares....
260 (0.06/day)
The Netherlands
Processor Intel Core i5 3570k
Motherboard MSI Z77 MPower
Cooling Thermalright Archon
Memory Crucial Ballistix Elite 2x4GB 1600MHz (8-8-8-24)
Video Card(s) MSI Geforce GTX 1060 6GB Gaming X
Storage Plextor M5 Pro 512GB; WD Caviar Green 2TB
Display(s) 2x HP ZR24w
Case Phanteks Enthoo Pro M Special Edition Tempered Glass
Power Supply Seasonic Focus GX-650
Mouse Logitech G403 HERO
Keyboard SteelSeries 7G
Software Windows 10 Pro 64-bit EN
That looks rather inconvenient, a radiator mounted horizontally in a 5.25" bay.
Besides I don't like the aesthetics all that much anyway, it looks rather cheap and not well thought out.
DOM
7,628 (1.15/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
the big water needs to be taken out to the back and put out of its misery lol
the54thvoid
Intoxicated Moderator
12,695 (2.38/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Price says it all.
Pump, Rad, Reservoir, block all contained in a custom built box for $150. Good liquid solutions aren't cheap.
It would be good to see a contraption based on an 'out of the case' set up with a couple of tubes going into the case to the blocks.
I'd contemplated that for my next build - to use a standalone res/rad/pump unit.
16,813 (2.33/day)
I remember their first take of this, the cap for the water tank was like a screw top of an airplane size wine bottle, and just as solid...
Worst watercooling kit ever...
512 (0.10/day)
For that money there are way better kits out there. Might not fit in a 5.25 bay but were they ever ment to?
3,145 (0.67/day)
Mouse Logitech
Keyboard Corsair
Software Win10
I went to some shrink sessions to forget this abomination, now I have to book some more cause of this news article :p
3,484 (0.56/day)
Terra
System Name :)
Processor Intel 13700k
Motherboard Gigabyte z790 UD AC
Memory 64GB GSKILL DDR5
Video Card(s) Gigabyte RTX 4090 Gaming OC
Storage 960GB Optane 905P U.2 SSD + 4TB PCIe4 U.2 SSD
Display(s) Alienware AW3423DW 175Hz QD-OLED + Nixeus 27" IPS 1440p 144Hz
Case Fractal Design Torrent
Audio Device(s) MOTU M4 - JBL 305P MKII w/2x JL Audio 10 Sealed --- X-Fi Titanium HD - Presonus Eris E5 - JBL 4412
Power Supply Silverstone 1000W
Mouse Roccat Kain 122 AIMO
Keyboard KBD67 Lite / Mammoth75
VR HMD Reverb G2 V2
Software Win 11 Pro
I can't believe they still have this in production. xD
Frick
Fishfaced Nincompoop
19,075 (2.83/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
So what is so horrible about it? I have no WC experience at all, but it looks pretty decent to me. And I think there has been several members here wishing for a reservoir that fits in the 5.25 bays.
2,144 (0.35/day)
Austin TX
Processor i9 11900k
Motherboard Maximus XII Apex
Cooling Custom Liquid W/ 360x60 Radiator
Memory 32Gb Team XTREEM ARGB 3600 b-die
Video Card(s) Waterblocked MSI RTX 4070
Storage Intel 900p 480Gb + 4tb Intel 670p
Display(s) LG C2 evo 42"
Case Geometric Future Model 8
Audio Device(s) HD58X + Sennheiser GSX 1000
Power Supply Corsair RM 750x
Mouse Steelseries Aerox 5 wired
Keyboard Akko Mod 007b HE
VR HMD Samsung Odyssey+
given the fact that the radiator, reservoir, and pump all have to share space in a rather small 2x 5.25 bay says a lot. the pump is small and probably noisy and if its anything like their past products its made out of very thin cheap plastic and prone to leak very easily. and if you think about it... how is that radiator going to breathe very easily when its sandwiched between cd rom drives and such
4,267 (0.69/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
That's easy, no one uses opticals anymore ;)
Seriously though, I did think about it and when installed it might sit right under my top fan mount. This may be the situation for a number of models, I'd need to look up the length to know.
...not that I want one as I agree with the earlier aesthetics comments and so far the opinion of Thermaltake WC products seems to be pretty low.
529 (0.11/day)
System Name As Himself
Processor 2700X
Motherboard Asrock 370X ThaiChi
Memory 4133MHz Team
Video Card(s) Radeon VII
Storage Samsung 512 SSD's
Display(s) Asus "24 144Hz
Case Tt P5
Audio Device(s) Asus Essence One Muses/Sparkos
Power Supply EVGA 1200
Mouse RAT ProX
Keyboard Drop CTRL
Software W10 steam futuremark
not trying to be rude, but that is what Tt is counting on here....
i DO have alot of WC exp, and to call this thing a piece of $h!t would be an insult to all things warm, stinky, and steamy!!!
Bad pump, bad radiator, cheap plastic res, sticks WAY out of the end of the 5-1/4 bay, and its loud....
the $150+ would be better spent on ANY of the other "all in one" liquid cooling systems from the likes of Nzxt, Corsair, CoolerMaster, Zalman, or even Thermaltake themselves!
5,426 (1.06/day)
OOUGHHH The memories. I had the BigWater 745 (i think its 745) back in the days, overclocking my Q6700 like a baws!
63 (0.01/day)
Price says it all.
NOT True at all. XSPC's $150 water cooling kit is actually GREAT. Granted it is an actual complete water cooling loop, and not a single unit like this.
63 (0.01/day)
There have been about 20 5.25" Bay reservoirs on the market for several years now.
the54thvoid
12,695 (2.38/day)
Software W10
You know what I mean. An all in one unit that doesn't need built up. Granted the H100 is cheaper but it's not the same as having what Tt have made.
Maybe I'm a snob but I like my kits very quiet and pretty. My pump+block+rad+res combo would be a lot more than that.
Frick
19,075 (2.83/day)
Piteå
I'm even more confused now. Isn't this thing new? How do you know it is so horrible?
2,132 (0.38/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
Ok, lets get the Bigwater facts out of the way. The unit is for the novice or for those looking not to take a lot of space. It really doesn't do a bad job believe it or not...... but there are better options out there. The thing that craps out the Bigwater is they use an aluminum radiator with mixed metals in the setup and mixing metals is a nono with watercooling. Mixing metals leads to corrosion and the unit IMO is crap and should be avoided like the plague. Also, the Thermaltake pumps have a huge reputation of failing and the plastic parts crack.
2,666 (0.44/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
i use just the water for this kit from thermaltake sold separtely and its pretty damn good !
1,585 (0.29/day)
Los Angeles/Orange County CA
System Name Vulcan
Processor i6 6600K
Motherboard GIGABYTE Z170X UD3
Cooling Thermaltake Frio Silent 14
Memory 16GB Corsair Vengeance LPX 16GB (2 x 8GB)
Video Card(s) ASUS Strix GTX 970
Storage Mushkin Enhanced Reactor 1TB SSD
Display(s) QNIX 27 Inch 1440p
Case Fractal Design Define S
Power Supply Cooler Master V750
Software Win 10 64-bit
It has been sad, but I feel I must say it again in my own way.
No way the radiator gets enough ventilation to stay cool.
2,132 (0.38/day)
Chicago burbs
Yes it does but not as much as one installed inside the case. Remember, this is a space saver. I used one many moons ago and it really did not do bad. I took a Phenom II 9850 with 1.55 volts to 3.27GHz with it. I was surprised and it was an older bigwater model. I got it when I was a nooby and did not know much about liquid cooling. The pump failed but it did not hurt the system.
1,763 (0.31/day)
System Name Lailalo
Cooling Noctua
Video Card(s) XFX 7900XT 20GB
Power Supply XPG 1000W
Mouse G602
Keyboard G510s
Heh...Thermaltake...90% of their products suck. Its just the 10% that don't which seem to keep them going. This reminds me somewhat of their 5.25in GPU PSUs which work well. But from the sound of this I'd say the concept is lost due to bad design.
One point that stands out for me is that there is a refill cap. I thought the idea of these was that you wouldn't have to refill? Isn't that potentially exposing it to contamination? Or is "(propylene glycol solution in distilled water)" that strong? Heh...you find that glycol stuff in lots of things. From underarm deodorant, textiles, and shampoo...to foods we eat. Maybe even more. Check ingredients on what you eat. Specially foods with some form of gelatin in them. You'll find the stuff out gets tossed in often.
2,666 (0.44/day)
Switzerland
Keyboard Rapoo
Its a tubular radiator works different than regular radiators.
173 (0.04/day)
Processor 4GHz intel i7 950
Motherboard GA X58-USB3 F5
Cooling Noctua C12P
Memory 48GB G.Skill RipjawsZ
Video Card(s) EVGA GTX 480 873/1746/1848
Storage Intel 520 Series
Display(s) HP 2210m
Case Antec 300
Power Supply Antec True Power New 750
Software Windows 8 Pro
Well you need a place to start, so it's the "fill cap".
There's also evaporation too, I used to have to top up my Swiftech Micro res maybe, once or twice a year (this doesn't bode well to sealed all in one units as they still evaporate through the tubes). <:
