Thermaltake Announces Bigwater 760 Pro Liquid Cooling System
HammerON
The Watchful Moderator
8,400 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
OOUGHHH The memories. I had the BigWater 745 (i think its 745) back in the days, overclocking my Q6700 like a baws!
Same here, except it was cooling a E8400 and was the 735. It was my first attempt at water cooling. Ah the memories:laugh:
Ok, lets get the Bigwater facts out of the way. The unit is for the novice or for those looking not to take a lot of space. It really doesn't do a bad job believe it or not...... but there are better options out there. The thing that craps out the Bigwater is they use an aluminum radiator with mixed metals in the setup and mixing metals is a nono with watercooling. Mixing metals leads to corrosion and the unit IMO is crap and should be avoided like the plague. Also, the Thermaltake pumps have a huge reputation of failing and the plastic parts crack.
Excellent point about novice users! The block that came with my BigWater did crack after installing it several times. I believe it was because I was tightening the nozzels to tight:)
Anyways I am glad it did so I had an excuse to move to a real water loop set-up. I think I sold the pump to bogmali...
446 (0.10/day)
Santa Ana, Ca.
System Name Mobydick
Processor Intel i7 2600k @ 4.4
Motherboard MSI M Power
Cooling CM TPC 812
Memory patriot 8gb x 2
Video Card(s) EVGA GTX 970
Storage Kingston hyper x 3k 120ssd,Samsung 256ssd, seagate 750gb green
Display(s) Benq XL2720Z
Case Haf X
Audio Device(s) creative soundblast xz
Power Supply EVGA G2 850w
Mouse deathadder chroma
Keyboard logitech g710
Software Windows 7 64bit
i had the bigwater 760is cooling my old 965 (Oc'd to 3.9 since day one), and it did a damn good job especially in the summer, i never had to worry about my cpu over heating, even in 95+ degree weather with only 1 fan in my room.
2,132 (0.37/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
I heard stories about blocks cracking too. Good call. Overall, there are better options IMO. It is a space saver though if there is a bright spot.
944 (0.20/day)
Slovenia
System Name PC.
Software Windows7 64....
Hya , Serious build improvement from the last option 760. New LGA2011, LGA115x, LGA1366.
Now you can see liquid status on the front and there is also fen speed regulator.It was all hidden before and CPU liquid block is also made much better and it will not stopping the flow!:),
MxPhenom 216
ASIC Engineer
13,057 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
I don't see this thing being very successful with the Swiftech H220 coming out soon.
15 (0.00/day)
Surely Thermaltake are trolling us all with this release.
No sane person would ever consider putting one of these abominations in their rig. Well I hope not anyway.
I would sooner piss on my cpu to keep it cool before Id have one of these in my system.
2,132 (0.37/day)
Chicago burbs
944 (0.20/day)
Slovenia
System Name PC.
We hew to see this product es chip way the cooling fluid of the entire system as we get at least 3 to 4 Important parts and add larger radiator and WGA blok.136 € was the price the previous model and has had a lot of mistakes. Now they are removed. Lako say that the system is good enough, if your home is what radiator and will carry out its function well. but if you want more expensive items, you place an order with EK I hew !:;)
