Thermaltake Launch Their First Overclocking CPU Cooler, Thermaltake Frio
3volvedcombat
1,514 (0.27/day)
South California, The desert.
System Name My Computer
Processor Core 2 Q9550 4Ghz 1.23volts
Motherboard Gigabyte
Cooling Corsair
Memory OCZ
Video Card(s) Galaxy
Storage Western Digital
Display(s) Acer
Case Lian li
Audio Device(s) Asus
Power Supply Corsiar
Software Microsoft
Benchmark Scores 25,000 3dmark06 at 4.35Ghz processor, 835core card!
I believe it would do good on lower wattage CPU's but it doesn't fair well with that CPU atleast.
3.5GHz @ Low: 34C / High: 70C
4.2GHz @ Low: 42C / High: 81C
But it's a fairly high wattage CPU. They should have tried it on something that draws less power IMO for more DRAMATIC EFFECTS if they really want to sell it. Plus the fact they add in 'DESIGNED FOR OVER-CLOCKING ENTHUSIASTS" ..... *sigh
Acctually for the voltage and speed its running, those are good temps for that processor, and should do perfectly fine. with 80c loads.
In the real world i7's can take that heat+ you wont be loading a 1.3ish volts 4.2Ghz i7 at 100% on all cores would you -_-
ALSO WHATS With people saying its running at 3.4-4.0Ghz. In the video they start of at 3.45-3.5Ghz then you can specifically see that they upped it to 4.2 and they enlarge it to see it at 4.228Ghz with loads of 81-80c -_-
Are you guys day dreaming? I watched it in 1080p so...
sweeper
796 (0.11/day)
SW, Ohio
System Name "X"
Processor AMD PHENOM II X 6 3.2GHz @ 3.6GHz
Motherboard ASUS M4A785-M
Cooling ARCTIC COOLING Freezer 7 Pro Rev.2
Memory Kingston Hyper X DDR2 1066 2X2 - 4GB
Video Card(s) SAPPHIRE Radeon HD4870 1GB 256-bit GDDR5
Storage Western Digital 500GB SATAII Black / Western Digital My Book Essential External HDD 1TB
Display(s) Soyo 22" LCD / Vizio 32" LCD
Case Thermaltake Xaser II Full Tower
Audio Device(s) ON-BOARD VIA VT1708S
Power Supply Antec Basiq 550W Plus Modular
Software Windows 7 Ultimate
I saw the same thing. It started out @ 3.45/3.5GHz and upped to 4.2GHz. I watched it in HD too. lol.
Bo$$
Lab Extraordinaire
5,656 (1.02/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
yeah Thrermaltake are TROLLIN'!!!!! :laugh:
5,196 (0.94/day)
System Name Dust Collector
Processor AMD Ryzen 5 3600X
Motherboard Asus B550I Aorus Pro WiFi AX
Cooling Alpenfohn Black Ridge V2 w/ Noctua NF-A9x14
Memory Corsair Vengeance LPX 16GB DDR4 3200MHz/CL16
Video Card(s) Power Color Red Dragon RX 5700 XT
Storage Samsung EVO+ 500GB NVMe
Display(s) Dell S2721DGF
Case Dan Case A4
Power Supply Corsair SF600 Platinum
Mouse Logitech G603
Keyboard Logitech G613
I watched the first 4 seconds 5 times before getting over how crappy their slogan was... "Thermaltake! Embrace the future."
I don't care for the cooler. :p
K I'm watching the video now... looks like any other tower cooler with 2 fans in push/pull. They're acting as if any of the features (I use this word very loosely) haven't already been implemented in like what, 100 other coolers?
They're using 1 stick of RAM, I'm assuming, to keep the heat output as low as possible. Pathetic,
sweeper
796 (0.11/day)
SW, Ohio
System Name "X"
I didn't say I would go out and buy the damn thing but facts are facts. AND I'm using an ARCTIC COOLING Freezer 7 Pro BTW!!!!!! :slap: Does the trick just fine. Under Prime95 with all four cores 100% loaded it only sees 50c and idles at 31c-34c. :pimp:
86 (0.01/day)
Frio is spanish for cold not cool.Guess they thought it sounds better.Also how does a particular material translate to flatness, not good machining and qualitycontrol.A company should not treat consumers as total idiots.
9,899 (1.74/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
It's 4.2Ghz with 83c max ^^
So still gets outperformed by most other high end coolers?
The Coolink corator ( may of spelt that wrong) is cheaper and is only 1c behind the noctua dh-14, so people should just buy that and teach thermal-take not to make subpar products :laugh:
5,250 (0.88/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
