Thermaltake Launches the World's First CPU & Memory AIO Liquid Cooler
47,171 (7.56/day)
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, proudly presents the first-ever product that combines memory and an AIO liquid cooler, the Floe RC360 / RC240 CPU & Memory Liquid Cooler. Thermaltake never stops to seek out possibilities to impress our users with a more efficient cooling solution for our memory modules. With the new Floe RC360 / RC240 CPU & Memory Liquid Cooler, users can acquire an unparalleled gaming experience.
Floe RC360 / RC240 CPU & Memory Liquid Cooler is compatible with TOUGHRAM RC memory modules (Sold separately) and grants further expandability which allows users to equip a high-quality all-in-one cooling system, including a water block, radiator, an ARGB controller, and three high airflow 120 mm fans on the RC360 version and two high airflow 120 mm fans on the RC240 version. Other than that, Floe RC360/RC240 CPU & Memory Liquid Cooler can be synchronized with motherboards equipped with 5 V addressable RGB headers such as ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, Biostar VIVID LED DJ and ASRock Polychrome, allowing users to control the lights directly from the motherboards RGB lighting software.
Features of the Floe RC360 / RC240 CPU & Memory AIO Liquid Cooler:
Motherboard RGB Sync Ready
Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, Biostar VIVID LED DJ, and ASRock Polychrome. The Floe RC360 / RC240 CPU & Memory Liquid Cooler supports motherboards equipped with 5 V addressable RGB headers, allowing you to control lighting effects directly from the software mentioned above without installing any extra lighting software or controllers.
ARGB Sync Radiator 120 mm Fan
The product is equipped with Thermaltake's 120 mm ARGB Sync Radiator Fan. It features compression blades, hydraulic bearings, and a 16.8 million color LED ring with nine addressable LEDs that are ready to sync with 5 V RGB capable motherboards.
High-Efficiency Radiator
Specially designed with a large surface radiator, Floe RC360/RC240 CPU & Memory Liquid Cooler increases heat dissipation.
High-Performance Water Block
The high-performance copper base plate accelerates heat conductivity. The pre-filled coolant reduces any hassle for liquid replenishment. Additionally, the reinforced sleeved cables deliver heavy durability and prevent the tubing from any damage.
Hardware Supported
It can support the latest Intel and AMD CPU and compatible with universal sockets (including Intel LGA 1200).
Memory Water Block Lighting
The waterblock for the memory strips are equipped with four lighting strips, featuring 36 addressable LEDs that allows users to show their RGB lightings.
Compatibility
Floe RC360/RC240 CPU & Memory Liquid Cooler is compatible with TOUGHRAM RC DDR4 Memory Modules - Our modules feature the same quality that customers expect from the TOUGHRAM Memory line. Launching in frequencies of 3,200 MHz, 3,600 MHz, 4,000 MHz, and 4,400 MHz in kits of 8GBx2 modules; users may find a configuration to fit any PC allowing installation capacity of up to 32 GB on mainstream 4-DIMM slots.
752 (0.46/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
I almost can't think of anything less necessary. Hopefully next we'll see motherboard IO watercooling included in our AIOs!
27,404 (6.62/day)
Does anyone actually need something like this? Total props to TT for doing the engineering and making it work, but who needs to cool their RAM like that?
273 (0.10/day)
Processor Intel i5-13600k
Motherboard MSI MEG Z690i Unify
Cooling Noctua NH-C14S
Memory G.Skill Ripjaws V F5-5600J2834F32GX2-RS5W 64GB
Video Card(s) Asus RX6800XT TUF
Storage Samsung 980 Pro 500GB x2
Display(s) Samsung U32H850
Case Streacom DA6 XL chrome
Audio Device(s) Denon PMA-50
Power Supply Corsair SF750
Mouse Logitech MX Master 3
Keyboard Microsoft Surface
Software Win 11 Pro
Wait, is the memory "watercooling" just a copper piece on the top? That's sad
62 (0.03/day)
Germany
Processor Ryzen 5 3600
Motherboard MSI B450M Gaming Plus
Cooling EK Supremacy EVO, Bykski N-GV1080TIG1-X (Gigabyte 1080TI Turbo) [280mm front, 240mm top, 120mm back]
Memory 16GiB 3600Mhz CL16 Patriot Viper
Video Card(s) Gigabyte GTX 1080Ti Turbo
Storage 4TiB Seagate Baracuda + 256 GiB Samsung 970 Evo Plus (StoreMI) & 500GiB Intenso SSD
Display(s) MSI Optix MAG271CR
Case CoolerMaster NR600
Power Supply Seagate Focus Plus 650 Watt GOLD
Mouse Sharkoon SHARK Force
Keyboard ReIDEA KM06
I like the idea, but RAM? Cooling multiple components with one AIO is sensible, but seriously RAM? ID-Cooling made one that includes the GPU imho make so much more sense than RAM... like 4 Sticks of overclocked DDR4 draw maybe around 10 Watts TOPs. That can easily be cooled passively... :confused:
1,187 (0.27/day)
Processor AMD Ryzen 3700x
Cooling Deepcool LS520 SE
Video Card(s) RTX 3070 FE
Display(s) LG GL850
Case Dan A4 H2O
Power Supply Corsair SF600
Mouse MX master 3
Keyboard Master Key Mx
Software win 11 pro
I wish that gpu layout could be more standardized so that cpu+gpu aio could become a thing. If you get a gpu were the vrm are near the I/O, you are out of luck when it comes to after market cooling.
14,056 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Nope, the pump block on the CPU has a copper base plate, the rest is alloy.
6,143 (1.52/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
O...
...m....
......G..........
Next up... submersible mobo's, where your case is a big liquid-filled tank and EVERYTHING is underwater ....:roll:..:eek:..:clap:
287 (0.10/day)
Processor Ryzen 3900x
Motherboard B550M Steel Legend
Cooling XPX (custom loop)
Memory 32GB 3200MHz cl16
Video Card(s) 3080 with Bykski block (custom loop)
Storage 980 Pro
Case Fractal 804
Power Supply Focus Plus Gold 750FX
Mouse G603
Keyboard G610 brown
Software yes, lots!
Am I the only one who thinks that a memory module which absolutely tops at 2.5W (over a relatively large surface area) doesn't need any cooling whatsoever?
I always rip off these ugly heatspreaders from modern memory modules, because I use huge CPU coolers with huge fans and often these so called memory cooler are just in the way ;)
Last time I brute-force liberated some trident X from their ugly cover, i ripped off a tiny capacitor from the corner of two modules. Memory worked fine without the caps and without the heatspreader!
Newer had any problem running overclocked memory without any kind of heatspreader. Some air circulation within the case does the trick any time!
6,143 (1.52/day)
Motherboard AZW SEI
Never had any problem running overclocked memory without any kind of heatspreader. Some air circulation within the case does the trick any time!
^^THIS^^ same here !
1,736 (0.59/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
Depending on how the pricing works out, perhaps this could me made to be worthwhile if you were to use the cheapest, green PCB, no heat spreader RAM you can find and cover up its ugly with this? I don't know, just trying to find a silver lining.... With rgb backlighting....
2,699 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Me. :D
Either that or better TBH.
It's actually a nice thing to have and could help extend the life of RAM in some cases too. I don't care for the RBG crap but the functionality itself is nice.
943 (0.43/day)
Seems like a good idea to let people buy their aio and memory from themselves. Clever marketing.
287 (0.10/day)
Storage 980 Pro
Case Fractal 804
Mouse G603
Keyboard G610 brown
Software yes, lots!
Me. :D
Well, tbh prolonged life from cooler hardware is more in the ballpark of decades. I have an Devils Canyon i5 4690k here, that runs 5ghz on all cores instead of the regular 3.5ghz, its air cooled and has been transcoding videos non stop for 5 years now, running continuously at about 80°C it doesn't throttle, it doesn't stop. I suppose it will just die one day, but not today!
So for normal Hardware, that get warm like 8 hours a day, the prolonged lifespan from better cooling must be in the decade range. And do you think you will be running 10 year old hardware in 10 years?
Just keep your hardware at the point where it won't throttle and runs stable and you're good. Anything more will just produce more noise from cooling for no real purpose. I can only laugh at people that think its necessary to keep their CPU at cosy 60°C at the price of either expansive water cooling or noisy air cooling.
773 (0.34/day)
Germany
System Name FATTYDOVE-R-SPEC
Processor Intel i9 10980XE
Motherboard EVGA X299 Dark
Cooling Water (1x 240mm, 1x 280mm, 1x 420mm + 2x Mo-Ra 360 external radiator)
Memory 64GB DDR4
Video Card(s) RTX 2080 Super / RTX 3090
Storage Crucial MX500
Display(s) 24", 1440p, freesync, 144hz
Case Open Benchtable (OBT)
Audio Device(s) beyerdynamic MMX 300
Power Supply EVGA Supernova T2 1600W
Mouse OG steelseries Sensei
Keyboard steelseries 6Gv2
For most users that is actually a RAM-heater. Given how hot the water in these AiO units run when you got a power hungry CPU. The water will be around 40°C and most DDR4 will not even reach 40°C with XMP profiles.
189 (0.07/day)
Germany
Cooling MO-RA3 420 LT | 4x NF-A20
Memory F5-6400J3239G16GX2-TZ5NR
Video Card(s) Asus 4090 TUF
Storage 1TB NM790 | 2TB SN850X | 1TB SN750
Display(s) AW3423DW | S2721DGFA
Case Hyte Y70
Audio Device(s) FiiO K11 | DT1990 Pro | Rode NT-USB
Power Supply FSP Hydro Ti Pro 1000W
Mouse G502 X Plus | GPX Superlight 2
Keyboard Ducky Shine 7
This could be interesting for RAM overclocking with voltages at 1.45+V. Right now I have a fan sitting on the graphics card pointed at the RAM because otherwise it would exceed 60°C.
287 (0.10/day)
Storage 980 Pro
Case Fractal 804
Mouse G603
Keyboard G610 brown
Software yes, lots!
Guys, memory cooling is a myth!
For example, look at the Datasheet of Samsungs B-Die, it is rated for operating temperatures of 85°C so at your 60°C it's not even close to exceeding that.
189 (0.07/day)
Germany
Case Hyte Y70
The specsheet only tells you operating temperatures at JEDEC settings. It doesn't tell you that B-die is more stable the closer it is to 20°C.
8,254 (1.33/day)
Mouse Logitech G604s
Literally no one wanted this. This is almost as bad as the RAM fans you could get about 15 years ago. At least then you could get it with blue LEDs for added flair if nothing else. But this...? :confused:
773 (0.34/day)
Germany
Memory 64GB DDR4
Yes BUT as I mentioned the water in an AiO, especially the 240, will be closer to 40°C. That is not cooling the memory, that is heating it up.
Now to add on top of that there will be a delta across the heatsink from the DRAM chip to the point the water is touching.
So the Chip will internally be 50°C already before the top of the heatsink reaches that 40°C. So you only get some kind of cooling effect after 50°C internal DRAM temperature.
You are far better off just cooling it with airflow, which inside the case will likely be around 35°C-40°C and make direct contact to the sides of the module, closer to the DRAM chip which means less deltaT to the point of transfer on the heatsink...
2,373 (0.58/day)
Audio Device(s) A LOT
This cooler is only compatible with one line of memory, from the many lines they sell, and no others...
2,699 (0.68/day)
Alabama
Memory C.R.S.
I understand you're trying to be helpful and it's all good But.....
Obviously in reference to me - you have no clue because THIS is what I do.
Example:
Bones`s wPrime - 1024m score: 4min 29sec 375ms with a Phenom II X3 720 BE
Bones`s SuperPi - 32M score: 9min 47sec 235ms with a FX-9590
I wasn't kidding when I said "Me". ;)
As for how long I'll have it, I've got pieces around the 20 year old mark I still tinker with and setups I could use now as a daily that's at least a decade old.
206 (0.12/day)
Would've been better if they designed something to cool the CPU and motherboard VRM's, although that's easier said than done.
27,404 (6.62/day)
Me. :D
Seriously? Does your RAM really get hot enough to need liquid cooling?
14,056 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
There is an A.I.O. with ancillary, centrifugal fan on the side of the pump block to add air flow, on the market, but I can't find it now.
I don't think the fan is large enough to be effective though.
