Thermaltake Launches the World's First CPU & Memory AIO Liquid Cooler
872 (0.14/day)
Copenhagen, Denmark
System Name Ryzen/Laptop/htpc
Processor R9 3900X/i7 6700HQ/i7 2600
Motherboard AsRock X470 Taichi/Acer/ Gigabyte H77M
Cooling Corsair H115i pro with 2 Noctua NF-A14 chromax/OEM/Noctua NH-L12i
Memory G.Skill Trident Z 32GB @3200/16GB DDR4 2666 HyperX impact/24GB
Video Card(s) TUL Red Dragon Vega 56/Intel HD 530 - GTX 950m/ 970 GTX
Storage 970pro NVMe 512GB,Samsung 860evo 1TB, 3x4TB WD gold/Transcend 830s, 1TB Toshiba/Adata 256GB + 1TB WD
Display(s) Philips FTV 32 inch + Dell 2407WFP-HC/OEM/Sony KDL-42W828B
Case Phanteks Enthoo Luxe/Acer Barebone/Enermax
Audio Device(s) SoundBlasterX AE-5 (Dell A525)(HyperX Cloud Alpha)/mojo/soundblaster xfi gamer
Power Supply Seasonic focus+ 850 platinum (SSR-850PX)/165 Watt power brick/Enermax 650W
Mouse G502 Hero/M705 Marathon/G305 Hero Lightspeed
Keyboard G19/oem/Steelseries Apex 300
Software Win10 pro 64bit
I've seen many useless products but this one takes the cake.
200 (0.07/day)
Germany
Cooling MO-RA3 420 LT | 4x NF-A20
Memory F5-6400J3239G16GX2-TZ5NR
Video Card(s) Asus 4090 TUF
Storage 1TB NM790 | 2TB SN850X | 1TB SN750
Display(s) AW3423DW | S2721DGFA
Case Hyte Y70
Audio Device(s) FiiO K11 | DT1990 Pro | Rode NT-USB
Power Supply FSP Hydro Ti Pro 1000W
Mouse G502 X Plus | GPX Superlight 2
Keyboard Keychron Q6 Max
There is an A.I.O. with ancillary, centrifugal fan on the side of the pump block to add air flow, on the market, but I can't find it now.
I don't think the fan is large enough to be effective though.
Arctic Liquid Freezer?
62 (0.03/day)
Germany
Processor Ryzen 5 3600
Motherboard MSI B450M Gaming Plus
Cooling EK Supremacy EVO, Bykski N-GV1080TIG1-X (Gigabyte 1080TI Turbo) [280mm front, 240mm top, 120mm back]
Memory 16GiB 3600Mhz CL16 Patriot Viper
Video Card(s) Gigabyte GTX 1080Ti Turbo
Storage 4TiB Seagate Baracuda + 256 GiB Samsung 970 Evo Plus (StoreMI) & 500GiB Intenso SSD
Display(s) MSI Optix MAG271CR
Case CoolerMaster NR600
Power Supply Seagate Focus Plus 650 Watt GOLD
Mouse Sharkoon SHARK Force
Keyboard ReIDEA KM06
The Arctic Liquid Freezer II and Cryorig A40/A80 both have that feature. The fans do help with VRM and RAM Temperatures, but i doubt that the reduction in temps will be that useful when it comes to stability...
3,655 (0.67/day)
Portugal
O...
...m....
......G..........
Next up... submersible mobo's, where your case is a big liquid-filled tank and EVERYTHING is underwater ....:roll:..:eek:..:clap:
And the questions is: "What is mineral oil cooling?" ;)
14,302 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Found an old review of the Cryorig. Quoted as written.
The hybrid airflow fan is a great idea; however, in my testing, it did not contribute all that much in terms of reported temps. Sure, the VRM section was a few degrees cooler, so it does work, but it didn't really make a difference. On Intel's mainstream offerings, the CPU might get hot, but power draw is still so low that it makes the extra cooling feel a bit gimmicky and unnecessary most of the time. There are, however, instances where it can make a difference. In those situation, such as with SFF and HEDT systems or extreme memory, it likely will have a far greater impact.
My how times have changed for Intel, now they consume more power on mainstream than previously, I guess every little bit of cooling will help.
5,690 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
dont understand all the negative comments, would this not allow for higher voltages and therefor better clocks/timings?
or is it a case of more voltage wont help and you will reach the limit of allowed voltage way before you reach the limit of temperature on passive cooling?
752 (0.44/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
Higher voltage brings instability in general way before temps do. You can easily run sammy b-die on 1.5v and sit under 60C on passive cooling, I've personally never seen DRAM reach more than 65C before getting unstable (not because of temps, but because it was at like 1.55/1.6v), and there's much more room for temps there. The temp is never really the limiting factor in overclocking DRAM, there's just a sort of voltage ceiling where DRAM becomes unstable or it reduces lifespan drastically without any improvement.
2,750 (0.67/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Seriously? Does your RAM really get hot enough to need liquid cooling?
Sometimes it gets toasty, I mean shoving 3.6 - 4.0v's through DDR for example will make 'em warm and the cooling is needed to keep them stable - and alive during longer runs.
Don't be suprised, if you do the extreme you need the extreme stuff to go with it.
209 (0.11/day)
That’s the one from Arctic right? I watched the gamers nexus review and it made little difference in temps unless you’re using a cramped case. There’s also the Asus ROG Ryujin but it’s crazy expensive with sub par build quality.
2,750 (0.67/day)
Alabama
Memory C.R.S.
Good Grief!! I'm not sure I believe that. I don't wish to say you're lying, however that much voltage should fry any modern RAM, even old DDR1.
You can only do that with DDR sticks that's either BH-5, CH-5 or Hynix B IC'ed.
All others will fry on the spot.
The main set I do that with is rated stock at 3.2v's so they can handle 4.0 or more as long as temps are kept in check.
56 (0.03/day)
"Thermaltake, the leading PC DIY premium brand" What? They make crappy knock-offs of others products.:kookoo:
29,100 (6.86/day)
Ah, ok! That makes more sense. Still though, 4 freakin' volts? Damn!
