OnBoard
- Sep 16, 2006
- 3,033 (0.45/day)
- Finland
Processor | Core i5-750 @ 3.6GHz 1.136V 24/7 |
Motherboard | Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby! |
Cooling | Alpenföhn Brocken HeatpipeDirectTouch |
Memory | Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24 |
Video Card(s) | Gigabyte GTX 460 1GB OC (mostly stock speeds) |
Storage | OS: Samsung F3 500GB Games: Samsung F1 640GB |
Display(s) | new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD |
Case | new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans |
Audio Device(s) | new! ASUS Xonar DG & JVC HA-RX700 headphones |
Power Supply | Cougar CM 700W Modular |
Software | Windows 7 Home Premium x64 |
Benchmark Scores | Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging |
And seems performance isn't there if it's mounted horizontally (doesn't fit). 4C more Delta T, compared to the other test where it was vertically. edit: Except with bottom mounted PSU cases this thing could be fine.
http://www.bit-tech.net/hardware/2008/10/10/thermaltake-v14-pro/4
Looking at this picture it's not wonder mounting it like this is bad for performance. Rear fans doesn't help one bit in cooling as the fins are blocking the hot air. What's worse it sucks the air out of the cooler, airflow must be real funky. Plus the added fact of making the PSU noisy with all the hot air pushed there, or flipping it 180degrees and pushing the hot air to GPU (and fighting the with PSU for the same intake air)
