Unofficial 12V-2x6V Power Connector Melts NVIDIA GeForce RTX 5090
1,687 (0.77/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
Der8auer got the card & cable & PSU.
Observed and compared the results with his own 5090.
Finds out there are 2 wires carrying 20A in stress testing. (Other wires carried ~5A)
It makes those 2 wires extremely hot and dangerous.
52 (0.20/day)
United States of America
Motherboard ASUS B650-F ROG STRIX GAMING WIFI ATX
Cooling DeepCool AK500 ZERO DARK
Memory TeamGroup T-Create Expert 32GB Kit (2 x 16GB) DDR5-6000 CL30
Video Card(s) Gigabyte RTX 3050 Gaming OC
Storage WD Black SN850 1TB PCIe 4.0
Display(s) ASUS ROG Swift OLED PG27AQDM
Case Fractal Design North
Audio Device(s) Topping DX3 Pro+ DAC/AMP, Byerdynamic TYGR 300R, HyperX QuadcastS
Power Supply MSI MEG Ai1000P 1000W 80+ Platinum
Mouse LAMZU Maya X
Keyboard DURGOD 65% Gateron Yellow switches
This does seem like the interesting part in this case. While burning 4090 GPUs seem to have been common enough I do not remember that many pictures of the same thing burning on PSU side.
This is the PSU used:
It only says PCI-E 16-pin but also ATX 3.1 that would imply 12V-2x6.
Also, as the PSU already implied, this is an SFF build.
I mean, a 5090 into this space? I would be quite worried about the heat by itself.
ASUS's product page is mislabeled. It is not ATX 3.1. It is 3.0, because for the PSU to be 3.1 it must have the revised 12V-2x6 socket.
145 (2.23/day)
Missouri
System Name Don't do thermal paste, kids
Processor Ryzen 7 5800X
Motherboard ASUS PRIME B550-PLUS AC-HES
Memory Silicon Power 32GB (2 x 16GB) DDR4 3200
Video Card(s) GTX 1060 3GB (temporarily)
Display(s) Gigabyte G27Q (1440p / 170hz DP)
Case SAMA SV01
Power Supply Firehazard in the making
Mouse Corsair Nightsword
Keyboard Steelseries Apex Pro
Fortunately something like that already exists, but it’s unfortunate that nVidia couldn’t use it on the FE because… cost?
This is from some AIB variant:
Per pin current monitoring!
When you have this available it’s not difficult to write an instruction to shut down the load after it detects a discrepancy (beyond a threshold) in current between the pins for a couple of seconds and prompt the user to check or replace the connection.
Problem solved!
Lets not forget this is the same NVIDIA that disabled the hotspot sensor. They probably did both of these on purpose, presumably
