unplayable mouse problem
2 (0.06/day)
hi i have a g203 mouse and its stuttering like crazy and i tried those solutions:
1 restart pc
2 uninstalling mouse from device manger
3 updating driver
4 installing g hub
5 unplug it
6 try another usb ports
7 upgrading to windows 11 (i was devastated)
so any solutions.......please
edit: i added a video how the cursor moves like as a zip file because the website doesn't accept video attachment
  • video.zip
12,915 (1.94/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
It helps if we know what hardware we are talking about so please fill out your TPU System Specs so everyone has a better understanding of the problem.
Have you tried a different mouse?
2,925 (0.52/day)
MN
System Name Personal / HTPC
Or at least tried the mouse on another computer?
41,577 (6.59/day)
1 restart pc
3 updating driver
4 installing g hub
5 unplug it
Flip it over and clean the sensor, dont use a reflective surface, try a different mouse
Upload videos on youtube
403 (0.36/day)
Processor Ryzen 7 9700x
Motherboard Asrock B650E PG Riptide WiFi
Cooling Underfloor CPU cooling
Memory 2x32GB 6200MT/s
Video Card(s) RX 7900 XT OC Edition
Storage Kingston Fury Renegade 1TB, Seagate Exos 12TB
Display(s) MSI Optix MAG301RF 2560x1080@200Hz
Case Phanteks Enthoo Pro
Power Supply NZXT C850 850W Gold
Mouse Bloody W95 Max Naraka
1 restart pc
3 updating driver
4 installing g hub
5 unplug it
You can try to lower the polling/reporting/rate, if you exceed 1000, sometimes stuttering may occur, try to lower it to 250 Hz. Or you can try to look for workarounds.
41,577 (6.59/day)
In hardware properties, man some old tweaks never die it seems, like no drive type autorun in 98, that tweak still works in 11.
1,598 (1.79/day)
G-City, UK
System Name AMDWeapon
Processor Ryzen 7 7800X3D
Video Card(s) Powercolor 7900 GRE Red Devil
Case Montech 903 MAX AIR
Audio Device(s) Corsair void wireless/Sennheiser EPOS 670
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Software Windows 11 Pro 24H2
Benchmark Scores Fast Enough.
I had the same problem for 2 logitech mice. My solution? Bought a Glorious model D wired. Perfect.
2 (0.06/day)
Have you
yes i tried and the same problem still
i tried it on a laptop and it worked fine
specs:
windows 11 pro 23h2
i5-12400f
gpu gtx 1060 6gp
ddr4 16gp
asus prime h610m-e d4
ok
No damaged USB ports
no the motherboard is brand new
