Ver. 3.0.2.5 Firmware Update to NEC(Renesas) USB 3.0 controller-unloading fix
2,344 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
michial
1 (0.00/day)
I have a new HP laptop dv7-6143cl qe. It has renesas 3.0 on two ports. It doesnt show up when you click start,programs,etc. It is in the device mgr and prog files though. My version is
2.0.32.0. Which driver can I update to? I click on update driver in device mgr and it says it sthe most recent. But not according to this site. THanks
2,344 (0.44/day)
Keyboard Dell
I would try HP website for updated drivers...first.
HP does often use proprietary software.
Use Piriform's "Speccy" to find out motherboard manufacturer.
http://www.piriform.com/download
If no update, then you should be able to run the updates listed here...check chip numbers to be sure.
Each chip supports two ports.
Hope this helps.
Mussels
Freshwater Moderator
58,412 (7.84/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
after updating these it seems my USB ports no longer charge my devices through USB... i'ma have to look into why that is.
2,344 (0.44/day)
Keyboard Dell
My usb 3.0 charges my cell phone fine...doing it now after reading your issue.
Does it fail for 3.0 or 2.0 ports or both?
Mussels
58,412 (7.84/day)
Oystralia
sorry i missed a word or something there, it no longer chargers when in S3 sleep mode.
2,344 (0.44/day)
Keyboard Dell
Have not tried sleep mode due to Folding...will try later and post back.
716 (0.13/day)
C:\Kitteh
Processor i7 2600K | Phenom II 840
Motherboard ASUS P8Z68 Deluxe | ASUS M4A88T-M
Cooling Corsair H60 | Scythe Samurai ZZ
Memory 4x4GB Samsung Green 1600 @ 1866 | 2x2GB Corsair XMS3 1333
Video Card(s) Evga GTX 670 FTW | On Board AMD
Storage 2 x 64GB Samsung 830, Velociraptor 300GB,1TB Black,1.5TB Black |10TB server
Display(s) HP 2509m 25" 1080p
Case Lian Li PC-V1020A | Lian Li PC-V354A
Audio Device(s) Azuntech Bravuria 7.1 | On-Board (Disabled)
Power Supply Seasonic X-series 760 , Seasonic X-series 760
Software Windows 7 Ultimate X64 | UnRaid (CentOS)
Phone charging fine, all working well.
Check your BIOS as well, I know some gigabyte boards have power over USB settings, or something similar.
2,344 (0.44/day)
Keyboard Dell
716 (0.13/day)
C:\Kitteh
2,344 (0.44/day)
Keyboard Dell
NEW 3.0.2.8.0.8 Firmware
I tried sleep mode with this newer driver and tried charging some spare cell phones and it went OK.
Did not try 3.0.2.7.
Mussels
58,412 (7.84/day)
Oystralia
3.0.2.8 works on my iphone4 - if its plugged in when i sleep the PC.
plugging it in after, it does really slowly charge (like, 15% overnight) but the phone doesnt think its charging.
i wonder if that tickbox to disable the power saving stuff is related when firmware flashing.
2,344 (0.44/day)
Keyboard Dell
I think you can put a check in that box after you flashed from whatever newer version that incorporates it. Have not tried it that way, as I did not understand the function, so left it stock... All phones are charged right now and no other appliance to test right now.
Will try and post back.
Also, I set comp. to sleep then plugged in.
Mussels
58,412 (7.84/day)
Oystralia
my 'dumb' nokia N95 recognises that its getting power/charging, however it too charges a lot slower.
this is relevant, as its part of my motherboards features regarding this:
http://www.gigabyte.com/microsite/186/images/amd800-charge.htm
2,344 (0.44/day)
Keyboard Dell
http://www.gigabyte.com/microsite/18...800-charge.htm
So are you saying that the hardware and firmware 3028 don't work with the "ON/OFF Charge Driver Download" software.
It smells proprietary.
Your board has a proprietary red usb 3.0 pinout? From picture in link.
What about keeping the 3028 firmware and reinstalling older Gbyte driver? Maybe cr*p idea? (just to link the "special" software with driver?)
Mussels
58,412 (7.84/day)
Oystralia
that whole on/off charge is so poorly documented... no i was using the onboard ports. i think this is a combination of apple being weird, and gigabyte not documenting shit right.
95Viper
Super Moderator
13,173 (2.20/day)
+1 on that...:toast:
I have that on my board, too.
I installed the drivers, updated the bios, the rest of the stuff they recommended and get the same.
Sometimes charges fast sometimes not.(my phones will quick charge, on the wall charger and auto charger, when off anyways in about 25 to 30 mins.)
It charges perfectly when the PC is on. I have seen no real difference between the MB being off or on. It is the other modes that are wierd.
You did notice all the little *notes on the page about due to, user's maybe, results vary, current may vary, etc.
I don't think the bugs have totally been squashed and the linens ironed out.
So, I'll just keep on using the wall charger.:)
Goodluck there, Mussels!:)
2,344 (0.44/day)
Keyboard Dell
Does the PSU standard matter? Perhaps the variation is with how the PSU is constructed, and how the +5 volt works in sleep mode.
Sounds like GByte should have a QVL list for PSU's that are compatible with these new features.
18,169 (2.45/day)
If you enable ErP in the BIOS, then devices don't charge, it's got nothing to do with USB 3.0 or On/Off charge.
228 (0.04/day)
System Name Adult Entertainment
Processor i7 2600K 4.4Ghz
Cooling CM Hyper 212 Evo with two Noctua 12cm fans
Memory 8GB (2x4GB) Corsair Vengeance LP 1600
Video Card(s) EVGA Geforce GTX 690
Storage two 3TB hard drives
Display(s) 27" Asus
Case Bitfenix Prodigy
Audio Device(s) Motherboard Soundcard FTW!
Power Supply Seasonic X850
Software Windows 10 64bit | Linux Mint | Windows XP 32bit
Benchmark Scores Score: OMFGWTFBBQSPEED!
I too have this problem. I use Asrock x58 Extreme6. I get the plural host controller detected error message. I hope someone fixes this soon. :(
228 (0.04/day)
Display(s) 27" Asus
Nice, do we know what is new about this driver?
95Viper
Super Moderator
13,173 (2.20/day)
There was no info in the driver package.
I am still trying to find release notes for it.
Someone or I will post them, as soon as, we can get the info.
I installed the newer driver (Version 2.1.19.0), but have seen no changes on the face of it.
2,344 (0.44/day)
Keyboard Dell
95Viper
Super Moderator
13,173 (2.20/day)
