Water cooled rig - Push and pull setup done temperatures not clear, any help?
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi guys, today I I finished my push and pull setup but my temperatures are not clear, can someone help
Me?
manofthem
WCG-TPU Team All-Star!
10,960 (2.14/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
So what are you temps now with your setup complete?
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
No clear...
With real temp gt - between 22 and 27
With occt - between 30 and 33
With real temp - 29 and 33
What a mess
751 (0.16/day)
System Name My PC
Processor i7 4790k @4.4ghz
Motherboard Gigabyte z97m-d3h
Cooling Corsair H105
Memory 4x4GB Corsair Dominator Platinum 2133-9-11-11-31-1T
Video Card(s) GTX970 Stric oc
Storage Samsung 840Pro 512GB
Display(s) Asus ROG SWIFT
Case Lian Li 359
Audio Device(s) Denon DA-300USB / Denon AH-D5000
Power Supply Corsair AX860
Mouse Roccat Kone Pure Optical
Keyboard Corsair K70
Software Win10 64-bit home
From what I know RealtempGT is for 6core intel cpus. You have an i7 3770 in you system specs. Occt and normal real temp show you the same thing, so that's what I would trust.
manofthem
10,960 (2.14/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
I use real temp on my pcs and is always been pretty spot on, at least compared to Hardwaremonitor, which are pretty much all I use.
Besides, I'd be more concerned with load temps than idle temps. ;) what are your load temps?
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
load temps are 50 c
Here you can see better
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
No one else can help?
8,523 (1.37/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
load temps are 50 c
Your temps look fine, they are within 5Âş from monitoring program. Does it really bother you that one program tells you 32C and the other 25C? How about you contact the software developer and ask what they think.
There's nothing to help with though, its simply one monitoring program is telling you one thing and another one is telling you something else.
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Right now I am doing a 15 minutes full load test and temperatures keep going up and down
From 52 to 57 c it's that normal?
And it's the same in idle, temperatures goes up and down from 28 to 33 c
8,523 (1.37/day)
Kansas City
Processor 9800x3D
Software Win 10 64x
Yeah, its normal for temps to shift. Whats your loop consist of?
Typically the more radiators the more heat will be evenly dissipated. So unless you have like 3x120mm rads with push pull then I'd say your just fine. :)
3,634 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Run IntelBurn Test. Use HIGH setting and see what your temps are.
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
You're right but its ok to have 32 c when your system it's water cooled and you're just cooling a CPU and even you use a push a pull setup with fans running at 3000rpm?
I
manofthem
10,960 (2.14/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
I
It's fine. My 4770k sits in the 30s in idle with 2x 360 rads. All's well
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
COOLER SYSTEM
radiator #1
Black ICE GTX Extreme 480
Fans 4X - YS-Tech Fan 120x120x25 - 2,16W 3000rpm
Enermax T.B. Vegas Duo 120mm Blue - 1700rpm
Radiator #1 in push and pull setup
Radiator #2
Black ICE GTX Extreme 240
Fans 2X
Cpu block
innovatek XX-Flow rev2.0
Reservoir
XSPC 5,25" Bay Reservoir Alu Front
Pump
Alphacool VPP655
Fan controller
Lamptron FC6 fan controller
Koolance Radiator Montage Halterung
Ram cooler
Kingston HyperX RAM Cooling Fan
Tubing
innovatek Special
(UV-aktiv)
Front fan
Cooler Master MegaFlow 200mm Red LED
Right side panel
Fans 4 X
:respect:
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Done a test with interburn in high mode temperatures were 50c
Now I will do one more test in maximum mode
manofthem
10,960 (2.14/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Sounds like a nice set up. What are the chances we can get some sexy pc hardware pics?
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
43,617 (6.45/day)
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Looks good! Temperatures seem very good for a 3770.
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Thanks!!!
Btw nex Month I will upgrade
Motherboard, processor, cpu water block , ram and ssd
MxPhenom 216
ASIC Engineer
13,041 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
No clear...
What a mess
Different programs will read different temps (Just depends on how they read from the sensor). Try AIDA64. And use normal Real Temp, not GT (Normal real temp and OCCT are giving same temps).
You can try CoreTemp too, see what that reads.
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
I used Both temperatures are 30 and 31 c
2,693 (0.42/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
those extra fans will be like a drop of cold water into a fresh mountain spring dude.
it will have an effect but that effect will be small as there is already a massive amount of cooling ability there.
FireFox
The Power Of Intel
7,507 (1.88/day)
Germany
Agree with you!
There's just 2 or 3 c difference
155 (0.03/day)
you did a big mistake.....
the big radiator is not in the right position , the heat is at the top so waters that goes out of it , drains the heat [again]
you should flip the big radiator upside-down
here is the plan :
with a box like that
having two holes for tubes and one for letting in the power cable . that is a security to prevent an accident that would cause water to get out of the loop
here is a pc of me looking like your :
i changed the mainboard for a sli one
look at the temp playing rage , i live in south of france with 17*c [not under the sun ;']
40 *c in the cpu , above 50 *c the loop should be reworked and optimized ...
2,096 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Why all those radiators when you are using a 3770 which cant be OC'd like the K version. You could have gotten the same temps with some better AIO cooler.
