- Dec 27, 2007
- 8,523 (1.37/day)
- Kansas City
System Name | The Dove Box Rev 5.0 |
Processor | 9800x3D |
Motherboard | Asus 870E STRIX |
Cooling | Custom Water |
Memory | 32 GB 6400 MTs |
Video Card(s) | Asus 3080 TUF |
Storage | 2TB Crucial T705 |
Display(s) | 32" LG 1440p 180hz |
Case | Lian Li O11 Dynamic |
Audio Device(s) | ON BOARD FTW |
Power Supply | Corsair 1000W |
Mouse | Corsair something |
Keyboard | Steelseries |
Software | Win 10 64x |
you did a big mistake.....
the big radiator is not in the right position , the heat is at the top so waters that goes out of it , drains the heat [again]
you should flip the big radiator upside-down
here is the plan :
with a box like that
having two holes for tubes and one for letting in the power cable . that is a security to prevent an accident that would cause water to get out of the loop
here is a pc of me looking like your :
i changed the mainboard for a sli one
look at the temp playing rage , i live in south of france with 17*c [not under the sun ;']
40 *c in the cpu , above 50 *c the loop should be reworked and optimized ...
Personally I wouldn't listen to a word this guy said. Flipping the rad upside down isn't going to do anything, and I'm not sure you understand that he has not only the external rad but another one along the top. Sure his loop order could be optimized, but its not that big of a deal.
One critique I saw was the tubing size, it looks like very small Outer Diameter tubing like 3/8" or 5/8". Sure it bends easier but it restricts water flow and increases pressure on the pump.
But, from what I'm guessing, OP didn't make the loop himself. I assume he ordered the PC with this setup, hence my suggestion not to touch the loop order and mess with it. Its a shame you have a ton of radiator space but are seeing more than ideal temperature deltas.
If the OP did buy the PC premade(loop included), I completely understand his concern. I know if I paid $200 over air cooling, I would like to see noticeable results(which you are).
