Water Cooling in a Obsidian Series 900D
43,619 (6.43/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Just finished putting mine together. Camera battery is recharging... I think I need to go with some bigger reservoirs and a bigger radiator up top to fill this thing out better.
457 (0.11/day)
St. Louis MO
I'm like this open test bench fanboy, it's gonna be hard to part from it...
I'll have to figure out where to put my 9x120 radiator... I'm going to probably hang it on the backpanel of the case.
Any suggestion?
The first thing that comes to my mind is some how cut the back side panel and build a place to hold the rad. The problem is the panel lock was not made for that and will probly not hold that. You could also build a stand alone cooling rolling cart. Take your rad and mount it on a frame and then have it able to roll around or not. Then have lines going out the computer to it.
43,619 (6.43/day)
That kind of defeats the purpose of this mammoth case. I'd trade in the 9x120 radiator for a couple of 4x120's
3,145 (0.65/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
I have a couple of 420 too :roll:
3,145 (0.65/day)
Mouse Logitech
Keyboard Corsair
Software Win10
The 420 has more surface area than a 480, no point in swapping them.
Less fans, less noise, bit more performance.
43,619 (6.43/day)
420 = 3 x 140mm fans? That'll be nice!
1,125 (0.17/day)
Florida
System Name Blackwidow/
Processor Ryzen 5950x / Threadripper 3960x
Motherboard Asus x570 Crosshair viii impact/ Asus Zenith ii Extreme
Cooling Ek 240Aio/Custom watercooling
Memory 32gb ddr4 3600MHZ Crucial Ballistix / 32gb ddr4 3600MHZ G.Skill TridentZ Royal
Video Card(s) MSI RX 6900xt/ XFX 6800xt
Storage WD SN850 1TB boot / Samsung 970 evo+ 1tb boot, 6tb WD SN750
Display(s) Sony A80J / Dual LG 27gl850
Case Cooler Master NR200P/ 011 Dynamic XL
Audio Device(s) On board/ Soundblaster ZXR
Power Supply Corsair SF750w/ Seasonic Prime Titanium 1000w
Mouse Razer Viper Ultimate wireless/ Logitech G Pro X Superlight
Keyboard Logitech G915 TKL/ Logitech G915 Wireless
457 (0.11/day)
St. Louis MO
Almost done with the computer. I made the motherboard back plate and have small things left. I am going to put corner covers on all the corners and places were panels come together.
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
OH yes! Looks awesome!
im thinking on a new case, it may be because ive seen this!
457 (0.11/day)
St. Louis MO
Thanks. Almost done with this build. will put everything together tonight and fill the loop and let it run all night then check for last leaks. Then done....:)
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
ive just gone and bought a few things as my case is too small, and id like to have a decent water loop which wouldnt fit.
hopefully be together in a month or so.
youve done a great job btw!
457 (0.11/day)
St. Louis MO
Thanks. Your talking about your new computer the one you cut the case in half that your working on not the last one with the water loop and all?
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
the one in my sig, the one cut in half is being sold off to fund my main rig lol
this is too addictive! so should have a totally new project soon enough, wish i had the components for it but this stuff will do lol
457 (0.11/day)
St. Louis MO
O ok cool. Ya water cooling is addictive. When you go with water cooling you never go back to air. What parts did you get?
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
ive got a 800D, phobya 250ml res and hardware labs black ice gt xtreme 360 rad coming.
i will probably end up getting more fittings, fans etc later on.
MxPhenom 216
ASIC Engineer
13,066 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
I think it would have been better if you didn't put carbon fiber on the motherboard tray. Makes the motherboard look a bit out of place now.
Better get some 120x38mm fans for that radiator. FPI on those things are really high, and excel at like 1800+ RPM fan settings.
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
ive got 3 sp120 performance fans to go on it. im not sure about push/pull as its only cooling the cpu atm.
i know its overkill but its hunting season lol
MxPhenom 216
ASIC Engineer
13,066 (2.48/day)
Loveland, CO
I am on the fence and even the carbide looks good 540 that is
I hope they make an updated version of the 800D by next summer or something. and allow a bit more radiator options rather then 360 and a 240 at the bottom and allow 1400mm fan radiators at the top as well and actual radiator spot down at the bottom otherwise you have to do a little bit of modding at the bottom or have it lay down but on its side.
457 (0.11/day)
St. Louis MO
I wanted the mother board to pop and stand out along with the fittings etc.
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
ill be modding mine soon as it comes, i want to try and copy my current mod but better.
the waterloop doesnt fit, hence the new case. maybe the opposite colours to kinights as i dont want mine looking like his and i bet he doesnt want the same.
builds look so much bettter when everything is tucked away and only the good is shown.
457 (0.11/day)
St. Louis MO
I do not mind a copy just for people to ask me. That sucks about your last case. You put so much time into it with paint etc. I had a 800D and loved it. I really like the small version of the 900D the 350D case. It would make for a bad ass small water cooling build.
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
knight.... its that damn girl again! i bet she's sold sooooo many cases lol
mines going bright red again, the last mod did look good. well its documented and logged for history lol
i cant wait to see your build lit up and coolant in there.
it actually inpsired me to go bigger and better lol
457 (0.11/day)
St. Louis MO
Thanks. Yes it is that HOT girl... I could watch her all day talk about computers... hot girl and computers...OMG...A NERDS DREAM....I should get a discount from Corsair or something. I sold TWO cases from building my case.... One 900D and a 800D... not bad for someone that does not work for them.... ;)
Hint hint "Grey_beard" who happens to be a Corsair Rep....just saying..:p:toast:
