Water cooling parts advice for a beginner?
1,770 (0.36/day)
Cussing desert
System Name Torquey Vulture
Processor Ryzen 5 2600
Motherboard Gigabyte B450 MiniITX
Cooling DDC water loop, EK block
Memory 16GB Patriot Viper RGB
Video Card(s) EVGA 1070
Storage 500gb NVME; some Phat HDDs
Display(s) Achieva Shimian 27" 2560x1440
Case Thermaltake V1 MiniITX
Power Supply EVGA supernova 850 G2
Mouse Corsair Harpoon
Keyboard Possibly the cheapest you can buy. Shift key broke recently. Space sounds like I'm kicking a ham
So heres a quick rundown again:
EK Supremacy CPU block
Alphacool xt45
Swiftech maelstrom pump/res
Primochill red tubing 1/2ID 3/4OD
Monsoon fittings 1/2ID 3/4OD
Corsair SP120 fans
Heres some of my mad paint skillz at work; lol. Anyone see anything wrong with placement?
I know its dirty. I need to clean it up. I'm planning on getting the parts end of the month maybe, Have a couple paychecks coming in late
MxPhenom 216
ASIC Engineer
13,041 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
Alphacool xt45
Corsair SP120 fans
http://i.imgur.com/wflbbrp.jpg
Looks good man.
Loop order going to be something like this?
Bay pump/res > XT45 > CPU block > back to res pump?
EDIT: I see you have been treating my (well yours now) HAF well. Yo buy one of these kits when you do this. Itll look sweet
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=35307
1,770 (0.36/day)
Cussing desert
I was thinking It was gonna go the other way, forgot arrows lol. Pump/res> CPU block> Rad> back to res. That way warm water from the block would be cool by the time it got to the pump/res. Is there any reason to go the other way?
I've been looking at single sleeved cables like that. I would kinda like to single sleeve it myself, It would probably take me a couple days though.
Ya that case has been good. I think I might paint the inside of the back panel, the shiny shows thru the cable slots
Here's the order page. I 'll have money for it in a few days, lol.
1,927 (0.43/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
pump/res>rad>block could give your CPU a small improvement in temps but if you have a high enough flow rate it really doesn't matter as you only have one major heat source that being the block. If you had a bunch of water blocked GPUs in the loop then the first part from the rad would get 1-2C° better temps then if it was the last however with enough flow this could also be minimized to the point where it doesn't matter.
1,770 (0.36/day)
Cussing desert
Oh ok. That makes sense.
Well, it looks like that will be the finished product. I'll be back with a little build log whenever I get the parts. Thanks everybody for the input
2,894 (0.48/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
May need to go with a dual rad in the top.
Will a triple fit in that case?
MxPhenom 216
ASIC Engineer
13,041 (2.48/day)
Loveland, CO
The only real reason I think from what ive gotten at in going to the radiator first from the pump/res combo is the cool the water from the pump since the pump tends to warm it up a bit, so the water is fully to ambient temps before hitting the CPU. Make sense.
But honestly, either way will do, loop order doesn't matter all that much. When you have a lot of parts to cool, loop order is something to consider. It can get you the shortest routes, and cleanest look.
I always thought that having radiators inbetween blocks was actually a good practice, but this past week ive found it to be not so. (you won't have a problem with that though since you are running a single big 360)
Sure will, when the case was released (He actually has my old HAF. I gave it to him for cost of shipping :) ) it was one of the few cases that actually allowed 360 radiators to be mounted inside by design. A lot of people got it because of that.
