Water cooling problem
888 (0.15/day)
System Name Serenity
Processor Intel i7-4770K
Motherboard Asus Maximus VI Hero
Cooling Xigmatek Dark Knight II SD1283
Memory 16GB Kingston DDR3
Video Card(s) Gigabyte GTX 770 4GB
Storage 2x Samsung 840 Pro 256GB SSDs, RAID0
Display(s) 2x 27" Samsung curved
Case Coolermaster HAF 932
Audio Device(s) HT Omega Striker 7.1
Power Supply Thermaltake 1200w
Before anyone freaks out, I'm home with my wife now. :)
I ran into a problem. I have Zalman VF900s on my 4850X2. If I put the card in the first PCIe slot on the M4A79T, the cooling fins are hitting the next PCI slot down. The bottom slot is the only one it will fit in, but if I put it there, it's touching the pins on the bottom of the motherboard for the reset switch, etc.
I'm not sure what to do. I don't want to put the stock fans back on because they were loud as hell. I'm also not sure I want to add them to the loop at this point. I have two MCW60 R2 blocks for it, but it's cool and silent with the VF900s so I had decided against it originally.
I can take a pic if it will explain better.
Also, with the card in, the EK res won't fit in the only place I can see that it would, right in the middle between the mobo and the drive cages. So now that positioning is messed up too.
Binge
Overclocking Surrealism
6,979 (1.16/day)
PA, USA
System Name Molly
Processor i5 3570K
Motherboard Z77 ASRock
Cooling CooliT Eco
Memory 2x4GB Mushkin Redline Ridgebacks
Video Card(s) Gigabyte GTX 680
Case Coolermaster CM690 II Advanced
Power Supply Corsair HX-1000
why not take some non-conductive material and cover the pins in question?
sneekypeet
not-so supermod
29,685 (4.31/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
can we get an image?
I realize this is a multi-core card, but basic instalation of these should not interfear with the mobo at all really. I'm guessing you have them rotated 90* to make them fit or something?
_jM
1,453 (0.24/day)
Ocala,FL
System Name The money pit v.2 (v.1 is the wife!)
Processor Core2Quad-Q9550@3.9ghz/1860mhzFSB @1.344v
Motherboard ASUS Maximus II Formula = best damn P45 OCer out there!
Cooling CoolerMster V8-- Custom WC system on the way! =]
Memory 8GB DOMINATORS @1100mhz 5-5-5-18
Video Card(s) EVGA GTX 280
Storage 150GB WesternDigital Velociraptor OS Drive/1 WD 500AAKS for Storage
Display(s) SAMSUNG 2243SWX 22" LCD
Case Cooler Master Cosmos S w/custom lighting and cable management
Audio Device(s) X-Fi Titanium (Fatality edition) - paired with RAZER Barracuda's
Power Supply CORSAIR HX1000W modular PSU
Software Windows 7 RC 7100--eats vista for breakfast lunch and dinner!
Benchmark Scores Coming to a theater near you!
Im wondering how he mounted these as well.
Can we get a CLEAR img of the inside of the case to see where your putting the res. Also get another img of the VGA itself so we can see the cooler(s) that are mounted aswell?
1,644 (0.27/day)
System Name Black Killing Machine
Processor Delidded NO IHS mount Intel i7-4770k
Motherboard Gigabyte Z87X-OC
Cooling Swiftech DIR655 pump, Watercool HEATKILLER® GPU-X³ 79X0 Ni-Bl gpu, DT SNIPER CPU block, UT60 420 RAD
Memory Gskill Trident 2400mhz CL9 Samsung IC9
Video Card(s) SAPPHIRE HD7950 OC 950mhz Edition, VaporX HD7950
Storage 2xM4 Crucial 64GB RAID 0, 1 OCZ AGILILITY 3 60GB, WDCB 500GB x2RAID0, WD Green, Hitachi 1TB
Display(s) Samsung SyncMaster 226BW and 24" 120hz BenQ gamer
Case SilverStone Raven rv-02
Audio Device(s) Audio Technica ATH-AD900 headphones, Topping D2 DAC/Headphone AMP
Power Supply Seasonic Platinum 860
Software Windows 7 Pro 64bit
Benchmark Scores http://hwbot.org/user/sonda5/ Delidding is magic. http://valid.canardpc.com/2878462
That fan is slightly offset. Have you tried spiining it around in different position?
Will the new Accelero 3 fan fit on there?
Probably a much better air cooling solution.
888 (0.15/day)
Thanks for the responses. Video card pics below. Sorry they're kind of crappy.
1.
2.
The fans on the video card are oriented right and left. The one on the right is offset to the right and the one on the left is offset to the left. I haven't tried seeing if they'll fit facing upwards or something, but it looks like they will hit the passive cooler. I suppose I could just take the fans off and see if they'll fit that way.
As for the res, I set it up to be almost exactly like this guy's set up:
I guess the 4850X2 is a lot longer than a gtx285.
888 (0.15/day)
Here is how it looks at the moment. Any thoughts?
I moved the card to a lower slot, which puts it right above the power supply, but it's not hitting anything else and my res fits.
Don't mind the res placement now. It's only hanging there so I can measure and cut hoses.
5,976 (1.03/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
poor pete lol, you know what would make life easier? a bay reservoir or EK 150. pete how come you didn't unscrew the top power supply plate? extra ventilation. stick your hard drives at the bottom of the rack and remove unused brackets. that video card doesn't look too healthy, I wish I could help you with your video card but if it was me I would of had the MCW60 on them already. you have to move the video card back up it's too close the power supply housing, heat is going to radiate up into the video card if not get sucked in before it gets exhausted out the expansion slots, probably don't need the 1200 Watt Toughpower (might consider a trade down the road) try flipping the radiator 180.
PS, what kind of heatsinks are on your memory?
10,989 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
yeah man that vid card looks bent.
1,644 (0.27/day)
Like I first posted.
Try spinning them around at different angles till you find the best position.
IMO you should sell those and get a new Accelero with the 3 fans. I'm sure it is much better.
1,644 (0.27/day)
Try spinning them till they fit like mine.
111 (0.02/day)
MA, USA
Processor AMD Phenom II 940 @ 3.5 Stock voltage
Motherboard Gigabyte GA-MA790GP-DS4H
Cooling Water Cooling in a ACTS 840
Memory 2x 2048 MB DDR2, 5-5-5-15, 1066 Mhz
Video Card(s) ATI RADEON HD4890 1gig
Storage C: 74gig raptors (Raid 0) D: 150gig raptor E: 320gig seagate
Display(s) 22" Widescreen V7
Case ACTS 840
Audio Device(s) Audogy 4
Power Supply OCZ 700 watt
Software Windows 95a
I got a simple solution, unless you are really set on the reservoir, make a drive bay extension that feeds back into the mobo area, change to one of these bad boys:
and boom prob solved, you even already have the pump so all u need is the reservoir section of it.
_jM
1,453 (0.24/day)
Ocala,FL
This is what I would do if I were you....
888 (0.15/day)
Awww, you guys don't like my water cooling. lol
1,644 (0.27/day)
Not that i don't like it. I think people are just trying to help you make the most of your set up.
Your case does look a little small.
I like that pic with the loop going to the cpu then the GPU. That is a sweet set up. Much larger case and another water block for the GPU would be needed.
888 (0.15/day)
I have two water blocks for the video card. I was just debating on whether or not to use them. XSPC also just came out with a full cover block for the 4850X2.
My case is the HAF 932. It should be big enough for this! I've never seen a bigger case. :D
5,976 (1.03/day)
Case Corsair 550D
forget full coverage waterblocks they are restrictive, expensive and limited to one card. sell the Zalman's and Reservoir. by the way in my Cooling Guide I mention removing the Hard Drive Rack look at how much extra room you get and as you can see you don't need a EK 250 reservoir lol oh and look a Corsair Power Supply, see where the Hard Drive Rack is supposed to be? see indents on the back panel? you could mount 2 of those little reservoirs there or lay your EK 250 horizontally.
1,644 (0.27/day)
From my experience the Zalman VF900 doesn't work very well for cooling the HD4850.
Use your water blocks and be done with your build.
:cool:
888 (0.15/day)
I don't see where the hard drive racks should be. I don't see any hard drives in that pic.
I was considering selling the 250 and getting a 150. I don't like the res tops. I like the looks of the EK res too much. Maybe a 150 will fit better.
The other problem with using the MCW60s is that 1/2 inch tubing kinks pretty easily, and the gpus are so close together that it seems impossible not to kink it. There also might a clearance issue with the big side fan.
I have an idea how to make it work, but it's hard to explain. In to the inner port on the right block, out to the outside port of the left block, then out from there to the CPU or rad, depending. (That's a lot of heat to be putting into the loop with one radiator.)
I forgot to mention, I did rotate the VF900s so that clearance to the PCI ports isn't an issue anymore. It's just the res. So I guess my only option is to sell it and get something smaller.
Thanks for all of the help so far. Keep it coming! I wish I could make my case look like the ones above. :)
5,976 (1.03/day)
Case Corsair 550D
forget the side 230mm it has no static pressure it's useless use 4x 120mm, this case has almost zero air flow at stock the temperature reduction people experience is due to it's size and ventilation. you could drop down to 7/16" tubing and try to compensate for flow loss. you could also sell the 4850 X2 with the Zalman's should net you a penny. there is no hard drive rack that was my point it gives you more air flow and space, you pop it out with a drill..
888 (0.15/day)
Where would you put the hard drives then?
I thought of using 4x120 but the noise seems like it would be too much unless I threw them on a fan controller.
I had been thinking of selling the 4850X2 for a little while now. Not sure what I would get in its place. It's just so damn long. It's a kickass card, don't get me wrong, but I think there are smaller, comparable cards out there that might not even need after market cooling.
779 (0.13/day)
Sydney, Australia
System Name Gearbox || Server
Processor i5 3570K @ 4.0Ghz || E8400 @ Stock 3Ghz
Motherboard Gigabyte Z68XP-UD3 || Gigabyte EP41-UD3L
Cooling Stock || Stock
Memory 8GB G.Skill RipjawX DDR3 @ 1600mhz || 4GB Kingston Value DDR2 800Mhz
Video Card(s) ASUS R9 270X Direct CU II TOP @ 1120/1500 || N/A
Storage Samsung 840 EVO 250GB || 1TB WD Green, 2TB WD Green, 3TB WD Red
Display(s) HP x23 LED 23" Full HD Panel
Case Corsair 200R || Open-Air
Audio Device(s) Audioengine D1 + Logitech Z623/Audio Technica ATH-M50 || N/A
Power Supply Antec EarthWatts Platinum 650 W || Antec Neo Eco 450 W
Software Windows 8.1 Update 3 Pro 64 || Ubuntu Server 14.04 64
Any chance of you getting a Nvidia 260 GTX,250GTS, or a 285GTX? Then remove the HD bays and cut a hole in the side panel, Mount the HD bays outside and it will still look good.
You could go the next step up and cut a 230mm hole under the HD bays for cooling too. :toast:
5,976 (1.03/day)
Case Corsair 550D
look in my signature for my Cooling Guide and give "230mm Fans" and "Modifications" a quick glance. you use a 5.25" to 3.25" Hard Drive Adapter it's kinda like the 3.5" to 5.25" Adapter that comes with the case but suited for Hard Drives you mount the Hard Drives in the top bays the Adapters are $2-4 a piece the only problem is they are hard to track down. alternatively you can purchase one of these and install it in your 5.25" bay it will take up 3x 5.25" bays and you can mount 4x Hard Drives in it with a extra 120mm in the front of the 4:3 module you can also take the front off so it should fit even with the drive bay cover on and since it only takes up 3x 5.25" drive bays you can still have 2x Optical Drives and 1x Fan Controller.
1,745 (0.26/day)
The Nevada Wasteland
System Name 9th Level
Processor AMD Ryzen 5 5600X
Motherboard MSI X570 Carbon wifi
Cooling EK Basic 360, x2 250mm, x1 140mm, x1 120mm fans.
Memory 32GB Corsair Vengeance 3200mhz.
Video Card(s) EVGA RTX 3080 12GB FTW3
Storage 500gb ssd, 2tb ssd, 6tb HD.
Display(s) MSI 27" Curved 1440p@165hz
Case HAF 932
Power Supply Corsair HX850W
Software Windows 10 64bit
Rotate the VF900's 90' degrees you have them sideways.:shadedshu
888 (0.15/day)
