Water cooling problem
2,863 (0.47/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
888 (0.15/day)
System Name Serenity
Processor Intel i7-4770K
Motherboard Asus Maximus VI Hero
Cooling Xigmatek Dark Knight II SD1283
Memory 16GB Kingston DDR3
Video Card(s) Gigabyte GTX 770 4GB
Storage 2x Samsung 840 Pro 256GB SSDs, RAID0
Display(s) 2x 27" Samsung curved
Case Coolermaster HAF 932
Audio Device(s) HT Omega Striker 7.1
Power Supply Thermaltake 1200w
I know, right? I want my case to look exactly like that. lol
888 (0.15/day)
Ok, I just ordered an EK 150 and one of those Coolermaster drive bays Bumblebee recommended. We'll see how that turns out.
I just want this to look neat. I might even trade my Thermaltake PSU, even though it's a kickass psu. It's just HUGE!
Naekuh
503 (0.09/day)
Miko Fox? Fire Miko? Its FireFox-Tan!
System Name Nadeshiko
Processor i7 980X @ 4.2ghz /w HT ON 24/7
Motherboard eVGA Classified E759
Cooling Custom H2o
Memory Corsair Dominators 6 x 2GB
Video Card(s) 2 x HD4870X2 in Xfire
Storage 3 x X-25V in Raid 0 (OS) + 3 x Raptors in Raid 0 (Game)
Display(s) Dual Gateway 2485
Case MM U2
Power Supply Ultra 1.6KW
Software Win7
ohhh u got a ek res...
I would recomend something like this... instead of using a D5.
if this interests you, let me know, you just need a XSPC top + Koolance 1 card sli bridge.
Deleted member 24505
Does the water in the res's swirl like that,or does the short tube in the bottom stop it? I may get one o them res's for my setup,is the xspc res top better or one of these?
Thanks naekuh.
888 (0.15/day)
If I were to sell this 4850X2, what's a comparable card? GTX285?
Also, I'm thinking of trading or selling the Toughpower 1200 and getting a Corsair 1k watt or something. Do they have a smaller footprint?
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
Thanks naekuh.
well if he got the new ek res, it has a anti votex.
So if he uses top inlet, and bottom outlet, you can avoid the vortex.
888 (0.15/day)
Does anyone know if there is a build log for this case? I definitely want to see it.
5,976 (1.03/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
just pop the HAF 932 hard drive rack out all you need is a drill with 1/8" bit 4 rivets on top and several on the bottom I think. easy. I don't like the 90' fittings they are restrictive. forget that check out http://www.million-dollar-pc.com
888 (0.15/day)
I will pop out the rivets when I get home from the hospital. I already got that drive bay adapter you linked in the other post.
Any thoughts on the video card and power supply? Should I sell and get others?
5,976 (1.03/day)
Case Corsair 550D
you could purchase a Corsair 850TX the housing is shorter, I don't think a Geforce GTX 285 will be noticeable in performance the benefits to this would be slight performance gain at higher resolutions, aesthetics, cooling and less tubing. you have the MCW60-R2? you can purchase the GT200 retention kit and the GT200 heatsink from Swiftech see here. I'm sure you could do a straight trade 4850X2 with 2x Zalman VF900 for a GTX 285, I would do it if you paid for shipping if they try to get cute throw in that extra Swiftech MCW60-R2 that you wont need. I would volt mod that GTX 285!
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
888 (0.15/day)
I don't do 90 degree fittings myself, but what else would you have tweaked? I'm trying to get a lot of input here so that my final product is a result of lots of advice. Thanks.
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
First off a DD fullcover block instead of the swiftech. Has a nice low flow drop and would make tube routing simpler.
Also id get a DDC over a D5 anyday. And the cpu block is quite old... So there are better cpu blocks on the market.
What parts do you have now? and what did you look at getting? Maybe i can help you tweek it in the middle.
888 (0.15/day)
DDC355 pump w/XSPC top
Dtek Fuzion V2
XSPC RX360 rad
Feser blue UV tubing
EK res (was 250, ordered 150 to test)
Same pump i'm using,good pump/res combo.I've seen people running that with 3 rads and a couple of blocks with no problem.
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
Dtek Fuzion V2
XSPC RX360 rad
thats good hardware yet why havent you set it up yet? :toast:
I would use a coupler, or a rotary coupler to join your res with your DDC.
Try to keep the loop as short as possible. The fusion should go after pump in loop order.
888 (0.15/day)
Cause I'm at the hospital with my new daughter. :D
I have it mostly set up. I just ran into a few snags. See the first page for a pic of my setup as it stands currently.
5,976 (1.03/day)
Case Corsair 550D
aww congratulations. really think you should go for the GTX 285 and 850TX Power Supply. Full Coverage Waterblocks have more surface to cover which makes them restrictive, expensive and inefficient. and it doesn't matter how low the restriction on a 90' fitting is they will still be restrictive it's physics.
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
oh wow congrats !!! :toast:
u gonna overclock your daughter too? i know she comes watercooled. :nutkick: :D
888 (0.15/day)
Thanks!
Part of the problem with asking for help on the internet is that everyone has a different opinion. :D I was thinking a GTX285, then people say the 275 a tad overclocked is just as good and saves $100, and then people saying wait for the 4890 Atomic edition, which outperforms the 285. (The Atomic does look pretty kickass to me!)
And honestly, I cannot stand non-modular power supplies. I only use two or three of the cables total, and even with the HAF it's hard to hide all that extra cabling. Also, there's no need to replace the power supply if removing the drive cage gives me enough room to route the tubing. If I could come out maybe $100 on top after everything I would consider it, since I'm trying to save up for a 24" monitor as well. So if I could sell the Toughpower for like $300, spend $200 on a new psu and be $100 in the green, I would probably still do it. No full coverage blocks, I agree.
Hehe thanks. Thankfully she's dry now. We just have to see how our 2.5 year old is going to handle this. :D
5,976 (1.03/day)
Case Corsair 550D
you could get the new 750HX it's modular. you can volt mod either the GTX 275 or 285 doesn't matter what Vendor or Model get the cheapest one. take a one time hit of $40-60 USD for a soldering iron, solder, pot, electrical tape, etc. then stick a MCW60-R2 on it.
888 (0.15/day)
I would feel kinda scared buying a brand new card and then soldering it. I think I want something that will work out of the box. That would either be a 275, 285 or the 4890 Atomic.
And I will keep my power supply if removing the drive bay gives me enough room to work with the pump without too much trouble.
5,976 (1.03/day)
Case Corsair 550D
yes but the power supply is covering the bottom fan mount which is the second most important fan mount. and soldering a video card is not hard. practise on a old or dead video or audio card.
888 (0.15/day)
The bottom fan mount? I mean I know there's a fan mount there, but everything stays nice and cool as it is. Could you please elaborate a little bit?
