- Nov 12, 2007
- 750 (0.12/day)
- RI, USA
Processor | FX 8150 4.41Ghz |
Motherboard | Asus Crosshair V Formula |
Cooling | Custom Water |
Memory | 16GB GSkill Ripjaws X 1600 |
Video Card(s) | Diamond Multimedia HD7970 3GB |
Storage | 2x WD Black 640GB, WD Black 2TB, Samsung 830 256GB SSD |
Display(s) | Samsung 32" LED |
Case | Cooler Master Cosmos (new version) |
Audio Device(s) | Platronics 777 |
Power Supply | Corsair AX1200 |
Software | Windows 7 Ultimate Signature Edition x64 |
Benchmark Scores | Geekbench: 10,136 3DMark 11: P7792 |
That explains it then.
Thanks for the info. For some reason I thought they would have been on a more efficient die and generate less heat. I am going to put a 120mm fan in the Lian Li case this morning, mount it on the side bracket and aim it down at the card. I hope that helps.
Thanks for the information!
No problem.. unfortunately, I found out the painful hard way. haha I do believe the die is more efficient, it's just the combination of having double the shaders and such, and GDDR5 with higher gpu and memory speeds that make it more work for the cooler.
