What Wattage do I Need for Ryzen 3700x and GTX 1080 Ti?
Status
Not open for further replies.
phill
16,792 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
2xGPU+ 2xCPU = 4 eight pins connectors. When we need 4x8 + 24 for a CPU we need more windmills/solar. Even 2x8+24 is more then 650 W if maxed out I saw some where and that in my mind is overkill, but if the board run like shit with only one...
The five year I got from EVGA homepage. There could be a sticker in the box that give additional five year upon registration.
Ah apologies sir, I thought you just meant CPU :) On some of the motherboards I've got, they are all dual 8 pin connectors and I just use them :) I'm glad I've already got the solar panels at home else I wouldn't be doing half of what I'm currently doing!! :)
I'm surprised as most of the units I thought where at least longer than that.. I wonder if it was because I've had them from the USA.... Ah well, 12 years I think should cover it anyways :D
Just took a look and it seems that it just depends on the unit you go for...
124335
I've got a couple of the ones in the middle for my WCG rigs, they are brilliant units :)
275 (0.13/day)
Processor AMD Ryzen 7 3700x
Motherboard Aorus X570 Elite
Cooling EK AIO 120 D-RGB
Memory Corsair Vengenace LPX 2x8GB @ 3000MHz
Video Card(s) Aorus GTX 1080 Ti
Storage 1x 1TB PCIe 4.0 NVMe, 2x 1TB hard drive, 1x 120 GB SSD
Display(s) Aorus FV43U
Case Corsair 110R
Audio Device(s) Sound Blaster Z Card, Sennheiser GSP 600, Razer Nommo
Power Supply be quiet! System Power 9 600W
Keyboard Logitech G915
VR HMD Oculus Quest 2
I'm not 100% sure on which unit you where looking at, please post up a link for us/me :)
Also, keep an eye to one of these units, EVGA 650w G+ they are brilliant units and for the money, even better :) Keep an eye out for offers on them, I've seen them go for as low as £50 :)
The one I went with is a Be Quiet System Power 9 600W, as it at least has the 2 8 pin connectors unlike my current one, it's 50 more watts, and it's actually £3 cheaper than the CX550 I was planning on going with.
19,371 (3.57/day)
Did you look at any reviews?
It's serviceable... that's about it. At least it has all your connectors. Enjoy!
4,499 (0.82/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
This one has ONE eight pin ESP connector! That might put a limit to which X570 board he can use. Over and out.
19,371 (3.57/day)
Typically those are optional, additional EPS connectors, but I hear ya and that is a good call.
4,499 (0.82/day)
Denmark
One might be optional. I saw some prices from MSI (now retracted) and the cheapest X570 Gaming Plus (8+4 ESP) was 220 Euro. If +£20 on a decent PSU is a problem for OP then I doubt he is going to get a X570 anyway. In the 400 series the 450 and below was with only one 8 pin ESP so that's where he lands (H or B 550 or whatever they will be named), eventually. There are no mentioning of them yet.....
19,371 (3.57/day)
Yes, obviously the second one is optional, LOL. ONE is obviously a requirement. You inferred a second and I played my post off yours and even said "additional EPS connectors"...I didn't think it needed further clarity, but thanks!
275 (0.13/day)
Case Corsair 110R
I've been actually discussing what PSU I should get in a Discord with some other people for a while now, and this one came up pretty often as a good one, but I could never find it for cheaper than the CX550, but now I finally have.
27,338 (6.61/day)
What wattage psu should I get for a Ryzen 3700x, a GTX 1080 Ti, 2 hard drives, 1 SATA cable SSD, 1 optical drive, 2x8gb ddr4 RAM sticks, and a Sound Blaster Z sound card? Though I am already running an fx-8350 with that same graphics card, storage and sound card with a 550w psu and that doesn't seem to have any issues, yet I've seen some people suggest I need a 650w instead, even though ryzen will use far less power than my current processor.
I know I'm late to the party, but thought I'd offer my 2 cents.
I'd go for 750w to 850w PSU. Two reasons;
A. PSU's that greatly out class the equipment running on them generally last much longer because they never get pushed to, or even near, their rated limits.
And
B. Future proofing your system. If you already have a high wattage PSU, if/when you look at upgrading it will be one less component you need to consider for replacement if you choose to use parts requiring higher power requirements
Given that your current PSU is working likely means you could get away with a direct upgrade to Ryzen. However, you have to ask yourself how stressed the PSU has been running that combination of parts for so long. My personal and profession recommendation is replace that 550w PSU and go with something quality and of much higher wattage than you really need which will give you and your system a lot of breathing room.
4,561 (0.93/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
This is true although most people greatly exaggerate their power needs and often look at peak numbers as if they are an average not realizing power needs are fluid. A solid PSU should not be pushed at all at 40-60% max power. Remember a corsair PSU with a seven year warranty means the company stands behind 24-7 use at peak for seven years. Very few people would ever push a PSU to this limit.
And
This is a part that I don't understand since SLI and cross are going the way of the dodo. If you have a 650w unit and only push it to about 300w tops; even if you upgrade to more power hungry CPU and GPU you more then likely won't even break 375w.
27,338 (6.61/day)
I'm thinking more of TR CPU's and/or high power RTX/Navi GPU's. Where PSU's are concerned I always advocate playing safe then sorry. As general rule, with my clients we calculate an estimated power usage need and try to triple it for PSU selection, but at minimum double. This methodology ensures that a PSU will rarely, if ever, be stressed thus providing solid power performance for years with very little chance for stress induced failure.
4,561 (0.93/day)
I figure anyone building a TR workstation has a general awareness of power needs especially if they also plan to have GPUs.
8,253 (1.20/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
if your thinking is correct.. people who spend up to £4000 on a really high end laptop (desktop replacement) are being short changed with the 340 watt power brick they come with.. :)
trog
19,371 (3.57/day)
Reviews > some random schmos on discord. ;)
27,338 (6.61/day)
Different kind of electronics standards as a rule. Those PSU's are usual manufactured to much higher standards and upgrade to laptops are less frequent. So they afford to keep tolerances tighter. However, I agree. They are under-powered generally.
275 (0.13/day)
Case Corsair 110R
It's not random people though. It's all enthusiast system builders in a Discord dedicated to that...
275 (0.13/day)
Case Corsair 110R
mmhmm. Reviews > people on chat. Come on kiddo...use your head.
And I am, that's why I went with this PSU because many trusted people suggested it...
4,499 (0.82/day)
Denmark
And still nobody mentioned that it only have one ESP connector and you need two.....trust these people with your life.
275 (0.13/day)
Case Corsair 110R
Because I don't need two ESP connectors.
4,499 (0.82/day)
Denmark
275 (0.13/day)
Case Corsair 110R
bogmali
In Orbe Terrum Non Visi
9,534 (1.57/day)
Pacific Northwest
System Name Daily Driver/Part Time
Processor Core i7-13700K/Ryzen R5-7600
Motherboard ASUS ROG MAXIMUS Z790 APEX/Asrock B650 Pro RS Wi-Fi
Cooling Corsair H150i RGB PRO XT AIO/Deep Cool LS-520 White
Memory G-Skill Trident Z5 Silver 2x24GB DDR5-8200/XPG Lancer Blade 2X16GB DDR-5-6000
Video Card(s) MSI Ventus 3X OC RTX-4080 Super/Sapphire Radeon RX-7800XT
Storage Samsung 980 Pro M.2 NVMe 2TB/KingSpec XG 7000 4TB M.2 NVMe/Crucial P5 Plus 2TB M.2 NVMe
Display(s) Alienware AW3423DW
Case Corsair 5000d AirFlow/Asus AP201 White
Audio Device(s) AudioEngine D1 DAC/Onboard
Power Supply Seasonic Prime Ultra 1K Watt/Seagotep 750W
Mouse Corsair M65 RGB Elite
Keyboard Adata XPG Summoner
Software Win11 Pro 64
Benchmark Scores Xbox Live Gamertag=jondonken
OK I think the OP got the idea and some of you are just arguing for the sake of arguing. Closing shop
Status
