Whats best for me Air Cooling or Water cooling (for 4790k!)
230 (0.04/day)
North of Iran
System Name Main system
Processor Intel Core-i7 4790K @4.5
Motherboard Asus Z97-Pro Gamer
Cooling Cooler Master Hyper 212 EVO
Memory 32 Gig (16 GigADATA XPG V2 DDR3 2400 + 16 Gig Geil Evo Veloce DDR3 1600 CL11)
Video Card(s) Gigabyte GTX1080 G1 Gaming
Storage Western Digital Blue Cavier 500 and 1 Terabyte + 1 Terabyte Green Cavier + Samsung SSD 860 EVO 500G
Display(s) ASUS ML238 LED Monitor
Case Green Viper X3
Audio Device(s) Onboard-Realtek
Power Supply Green 700watt (Its a rebranded psu from highpower/kolink I guess)
Software Windows 10 /Ubuntu 16.04
Hello everyone.
this is a follow-up question about my CPU. (link which I asked couple of days ago).
Short story :
I dont know if I really need Air-Cooling or Water-Cooling?
Long story:
I got my 4790K yesterday and with stock fan, I ran some of my tests.
It easily hit 90 C (194 F) and I noticed throttling happening (cores clocks would go back to 3.5, 3.2, 2.8 and then 4.2 and then back to 3.2!)
My room was hot, maybe 35/40C (95/104F), when the temps hit 90C. I then opened my rooms door to the outside and the cold air gushed in and temps went down to 65-75C and kept going back and forth.
Today I turned off the heater in my room again, the temps outside is 6C(43F) now, I guess the room temp is about 20C (68F) ( I don't have a thermometer, I'm guessing here, the rooms air is cool, but not chilly or uncomfortably cold!) and the temps fluctuate between 55~65C.
my current temps (a test is being run) :
When I increase the work load by executing a 1-minute-long function,:
Now this is in winter! when the temp is around 5~15C (41~59F) at its highest , and the workload only takes less than a minute, yet I'm facing throttling !
I can't image how severe this can get in spring and summer time when the temps are around 35/40C and my tests last for days non-stop!
In my previous thread, some of you gentlemen did me a favor and suggested getting a CoolerMaster Hyper EVO 212 .
Now what I need to know is that, whether this suggestion still holds or I should be looking for a water cooler instead ?
By the way, I looked for the EVO version and found out, it is not being sold here anymore , instead, a replacement version called Hyper 212X is being sold here which they claim is the newer and better version, there is also a Hyper D92 version .
Thanks in advance and please excuse me for being this long and boring!
43,243 (6.74/day)
Grab an aftermarket Air cooler and call it a day.
Check out my signature Rig, its considered a slim cooler. My chip is also supposed to be hotter than any Intel Offering but look at the OC I have.
Kursah
Super Moderator
14,732 (2.21/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I run a big air cooler (Noctua U14S) with dual fans on my main rig's 4790K and a CM 212EVO on my server's 4790K. Both stay cool for what they are. Water will be more effective. I am starting operation delid on both CPU's this weekend for even better cooling performance on air. :D
If I run OCCT I can hit the low to mid 80's on either rig. My main rig's CPU is OC'd to 4.8GHz, otherwise it'll load in the upper 60's or low 70s.
You might look at Cyrorig for a good CPU solution, I prefer their H7 over the EVO.
Your CPU won't start to throttle until 100C, then it'll throttle back a little bit. Or that's how it should work and has worked in my experience with Haswell and Devils Canyon CPU's.
What are you performing load tests with? I've ran my CPU at 90C at 4.8GHz and it doesn't drop...so it could be work load scaling.
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
Pretty much any decent air cooler will be fine. I suggest Be Quiet Shadow Rock Slim, since it easily cools down my OC'ed i7 6700K and has a slim profile. It keept my i7 6700k @ 4,6GHz/1,344V under 82°C with ambient temperature of around 28°C (hot!) during 30-minute Prime 95 28.9 test. Just make sure that you have more than 161mm space inside your case - width from CPU to the opposite side pannel.
Other options are Arctic Freezer i32, Cryorg H7, Thermalright Ture Spirit 120 Rev A, all of which will fit in pretty much every mid-tower case.
230 (0.04/day)
North of Iran
Case Green Viper X3
Where do you live? Do you also have a graphics card in your case ?
The actual test that I'm talking about, is training my CNN architecture on different datasets, such as CIFAR10,SVHN, and ImageNet. (CIFAR10 takes 1 day, imagenet takes more than a week)
I'm also doing some random stuff such as this snippet of code, which is for dataset whitening :
Code:
mean = np.mean(data_train, axis = (0,2,3)) # zero-center
for i in range(data_train.shape[0]):
    for j in range(data_train.shape[1]):
        data_train[i,j,:,:] -= mean[j]
first_dim = data_train.shape[0]
second_dim = data_train.shape[1] * data_train.shape[2] * data_train.shape[3]
shape = (first_dim, second_dim)
cov = np.dot(data_train.reshape(shape).T, data_train.reshape(shape)) / data_train.shape[0] # compute the covariance matrix
print cov.shape
Kursah
Super Moderator
14,732 (2.21/day)
Missoula, MT, USA
Montana, USA. Currently -7F, averages 85-95F in the summer, with 10-30 days going over 100F in recent years.
I have a 980Ti in my case. My case fans are on low so it dumps A LOT of heat into my case.
Ahh playing with datasets, nice. I don't play in that pool. :toast:
230 (0.04/day)
North of Iran
Case Green Viper X3
Thank you
By the way this is my case, What do you think? Is there something wrong cooling-wise here? I mean something that may cause air cooling less efficient or something I should keep in mind when getting the air cooler suggested in this thread ?
(the actual dimensions are : (525mm x 225mm x 540mm)
Kursah
Super Moderator
14,732 (2.21/day)
Missoula, MT, USA
If you're running stock, a Cooler Master 212EVO or Cyrorig H7 should do the trick. A Noctua U12S or U14S would work well too...but are premium coolers and more expensive. There are other options as well but the 212 has been the go-to budget tower cooler for years. The H7, when available is an excellent lower-profile, yet more effective alternative to the 212EVO.
Your picture is missing a lot of the rest of your case but maybe you could explain what else you have going on.
How many intake fans? Any more exhaust fans?
I don't see anything major around the CPU area that will cause issues...so a better air cooler will be fine.
230 (0.04/day)
North of Iran
Case Green Viper X3
there are two intake and two exhaust fans. the intake fans are 120mm and are mounted in the front of the case.
there is one 120mm fan which is visible in the picture(the white one) and another one in the top (220mm) which exhausts the heat out,
these are the pics :
case back top and full_details
Kursah
Super Moderator
14,732 (2.21/day)
Missoula, MT, USA
That should provide sufficient airflow then.
Get a better CPU cooler if you want to reduce your temps and call it a day. :)
Do know that these CPU's are capable at running at the limit. I've sent out a few systems where the owners didn't want to pay for aftermarket cooling and they're running great with stock cooling. But 4790Ks will breach the thermal limit on stock cooling under heavy loads and high ambient temperature conditions.
But the thermal throttle limit is 100C, these CPU's handle it very well. Not that you should run at that limit, but you could. I prefer not to, hence the extra cooling. :)
230 (0.04/day)
North of Iran
Case Green Viper X3
Thank you very much :)
Kursah
Super Moderator
14,732 (2.21/day)
Missoula, MT, USA
You're welcome! Please update us on what you decide to go with and your results after swapping. We always like to see how things turn out. :)
230 (0.04/day)
North of Iran
Case Green Viper X3
Sure thing,I'll update the thread when I get my cooler :)
9,915 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
Thank you
maybe you could consider lapping the heatsink and using better thermal paste and test it again to see how it improves
before considering after market cooler. yeah noctua is good , i used to put deepcool assasin to cool my processor but the weight is kinda worrying
Toothless
Tech, Games, and TPU!
9,713 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
The stock cooler is a joke and even lapped with the best paste in the world wouldn't fix it.
I used a Deepcool Lucifer on my 4790k and it worked pretty well, though at stock (4.4ghz turbo with 1.2v) a Hyper 212 would be perfectly fine.
1,025 (0.33/day)
Croatistan
Thank you
Yes, it is. Intel's stock cooler. If you are on a budget, buy Arctic Freezer i32 and you'll see drastic improvement. It's a very good cooler with attractive price (note: it's cheaper than official 46 €): https://www.arctic.ac/eu_en/freezer-i32.html
12,328 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
H80i V2
peche
Thermaltake fanboy
6,709 (1.80/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
well, the cooler is just doing its best, if possible upgrade to a Hyper 212Evo or the 212X you said, that will give a break to your high temps,
Also giving some hours to manage the cables will make a better space for the airflow, your case seems to be pretty well designed according the given information on previous post, so be sure to have the correct airflow and quality fans, that will finish your temp issues for sure,
Airflow chart:
Also the option of using a AIO watercooling will be a terrific idea, even a cheap-ass Corsair H60 will do the job, you case supports watercooling according previous information about it,
So both, air and water coolers are supported by your case, so you decide if you want to add a little bit moar aesthetics to your rig with an simple and elegant water cooler or go easier and simple with air cooler!
PD: great case indeed, seems well designed if possible bring an actual photo of yours to see how its inside!
Regards,
7,090 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Get a Phanteks PH-TC14PE or Noctua NH-D15 instead of a watercooler.
43,243 (6.74/day)
Thermalright Macho. Cyrorig. Scythe Ashura For Air
Kanan
Tech Enthusiast & Gamer
3,517 (1.02/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
A big air cooler should be easily enough, Noctua NH-D15 for example. I always prefer air coolers until water becomes necessary, but the 4790k won't need it.
484 (0.13/day)
Fort Sill, OK
Processor Intel 7700K 5.1Ghz (Intel advised me not to OC this CPU)
Motherboard Asus Maximus IX Code
Cooling Corsair Hydro H115i Platinum
Memory 48GB G.Skill TridentZ DDR4 3200 Dual Channel (2x16 & 2x8)
Video Card(s) nVIDIA Titan XP (Overclocks like a champ but stock performance is enough)
Storage Intel 760p 2280 2TB
Display(s) MSI Optix MPG27CQ Black 27" 1ms 144hz
Case Thermaltake View 71
Power Supply EVGA SuperNova 1000 Platinum2
Mouse Corsair M65 Pro (not recommded, I am on my second mouse with same defect)
Software Windows 10 Enterprise 1803
Benchmark Scores Yes I am Intel fanboy that is my benchmark score.
I still used my 6+ year old Noctua NH-D14. I used it to cool my old 3770, 4770K-> 4790K -> 6700k -> 5930K and now sitting on 7700K ( w/ Gelid GC-Extreme paste). Always used it as a passive cooler, never installed the included fans since I don't OC my CPU's that much (nothing over 1.3v). I plan to get many more years out of it. With CPU's architecture getting more efficient, will I ever purchase a Liquid CPU Cooler? Perhaps not.
I made up my mind to purchased Corsair Hydro series liquid cooler on many occasions but it was not easy to let go of the fact that my Noctua generates no noise.
But Noctua NH-D15 gets my vote plus the included 140mm fans are of high quality.
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
"What do you think? Is there something wrong cooling-wise here?" yeah the stock cooler on an i7, for $25 get a decent cooler to chill that CPU n be done. I know its not overclocked but those temps need cooling either way. I'd never consider 1 without the other.
Kanan
3,517 (1.02/day)
Europe
VR HMD Still nope
I concur with that pretty much. But as I'm on the LGA2011 those HEDT 140w CPUs with OC generate a lot of heat, so I always needed both fans for the CPU to stay cool. Mid 2016 i switched to a 6 core on same platform and since then the Noctua is kinda holding my OC back, I can't achieve a save 5 GHz OC with it, it gets too hot and shuts the whole PC down, so I'd need water to do more, hence what I posted earlier about "as long as air is good enough, stay away from water". The way I see it, air coolers help with surrounding CPU stuff, cooling down vrms etc. too, whereas a water cooler just cools the CPU, so is kinda uncompromosing and extreme.
230 (0.04/day)
North of Iran
Case Green Viper X3
OK here is the update,
I've finally bought a CoolerMaster Hyper 212X (the EVO version was sold out).
I had a bit of trouble getting it installed(I have Asus H87M-E which is tiny! and also fastening the darn screws where hard!) but Thanks to God, I finally did it .
I ran prime95 (v25.8). on stock fan I reached 100 C in immediately!
and then I ran it again after installing the Hyper 212X, I get 59,60 to 65! C . (its been one hour since I started the test) here is a screenshot :
Though I dont know why the cpu frequency is stuck at 4.1!(I did not overclock it , its at default config, whatever it was I did not change anything!)
I thought it would go on to reach 4.4Gh! but it hasn't! and the utilization is 100% as you can see . is there a problem here ?
In any case Thank you everyone again for your great help. I appreciate it
God Bless you all
