- Oct 15, 2006
- 14,732 (2.21/day)
- Missoula, MT, USA
System Name | Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022) |
Processor | R7 5800X @ Stock | i7 12700H @ Stock |
Motherboard | Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231 |
Cooling | Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling |
Memory | TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16) |
Video Card(s) | Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W |
Storage | 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD |
Display(s) | Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in |
Case | Corsair 600C - Stock Fans on Low | Stock Metal/Plastic |
Audio Device(s) | Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29) |
Power Supply | EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light) |
Mouse | Logitech G502 | Logitech M330 |
Keyboard | HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW) |
Software | Windows 11 Pro x64 | Windows 11 Home x64 |
Looks good!
Turbo works like this, 4.4GHz for 1 core, 4.3GHz for 2 cores, 4.2GHz for 3 cores, and 4.1GHz for 4 cores under default turbo rules. In your EFI/BIOS, you should have a setting to unlock or sync turbo frequencies. Keep in mind that Intel does this to meet their power consumption specs for OEM ratings which is why it works this way. There's some articles out there if you need more info, but really I think all you want to do is get your i7 operating the same on all cores and I don't blame you.
I have a Asus Z87-Pro, I'll try to look up the value to change when I get home...it'll allow all 4 cores to run at max turbo (stock is 4.4GHz). Your temps and power consumption will increase a little further, but its worth it IMHO.
Edit... I did a quick Google and found that it is the Asus Multicore Enhancement setting you need to enable if your board has it. I have attached a screenshot I found from that Google search for reference.
Nice work!
Nice work!
