WHEA LOGGER 18(Cache Hierarchy Error) KERNEL POWER 41. READ DESCRIPTION please help
1,751 (3.97/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Wasn't there an issue where this only happened to very-very-early Vermeer batches? (or other WHEA crashes) (pre-'21 batches)
Apparently, multiple people reported the issue. Even my first Vermeer purchase was clear from that period.
So, if later than 20xx, then it's just a fluke, it looks like.
Unlike Raptor Lake, where if crashes start, it's too late and the CPU must be replaced. The BIOS fixes in that case, must be applied before any symptoms. Yes, the Ryzen must be replaced if new symptoms occur, but crashes and/or errors, are not known to be a widespread issue, unlike 13th-gen and 14th-gen Core i.
No, the issue hasn't gone away. Just lower failure rates Zen2 to Zen3.
As we praise AMD for cache errors and blame Intel for similar, if not same exact issues.
As if everyone expects 100% fab without error. Gimme a break. Please don't be that click bait guy. You know better.
43,376 (6.75/day)
Ok lets wait and see what the op does next, no need to argue, both intel and amd flub sometimes, lets move on.
1,751 (3.97/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
This is peaceful conversation.
It's hard to come to terms with it. It's rare, but those are the posts where all diagnostics where exhausted, no extra hardware and at the mercy of warranty.
I only share what would work accurately as a resolve. I don't care what the OP does honestly.
43,376 (6.75/day)
Its sort of like having to explain to someone that certain vehicle suspension parts wear out over time like rubber, some understand, some don't.
1,751 (3.97/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
What man... was the click bait comment too much? I didn't mean to harm. I can easily be asked to edit my posts via pm, or while you seem to moderate, perhaps remove it for me quietly...
I have no idea why he can't Speak for himself, nor why you derailed the convo.
154 (0.02/day)
System Name CyberMania
Processor AMD RYZEN 7 5800X3D
Motherboard GB AORUS PRO AC B550
Cooling CM HYPER212 TURBO ARGB
Memory XPG D50 DDR4-3600 16X 2
Video Card(s) SAPPHIRE AMD RX580
Storage XPG M.2 NVME SPECTRIX D40 512GB 2TB
Display(s) SAMSUNG 43" QLED
Case CM ELITE 430
Audio Device(s) REALTEK HD
Power Supply CM WME GOLD 650WATT
Software Windows 10 21H2 LTSC 2021
whea 18 is amd ryzen 5xxx b1 cpu error.... mostly is cause by boost too high and cause the error...disable turbo boost or tweak to lower speed if no more rma.... or curve optimiser potive some golden core....
else rma it
1,775 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
I was getting Whea 18 and cache hierarchy errors on my 5700X/B450 Mortar max. My fix was moving to AM5. It stopped then.
6,177 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
I would expect to see it only if you're:
- running unstable memory OC
- have applied CO to the CPU and it isn't stable (CPU ID will match the logical core number of the core that crashed)
Update BIOS, run optimized defaults, turn on XMP and adjust DRAM voltage to 1.35V. Make sure you fabric clocks match the required frequency (1800 MHz) to match the XMP profile of your memory kit. Then run MemTest5 and check for memory errors.
So you changed out the entire platform to "solve" the issue. Great!
831 (0.41/day)
Processor Intel i9 13900KS
Motherboard z790 Apex
Cooling LT720 360mm + Phanteks T30
Memory 32GB
Video Card(s) RTX 3080
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Hx1200i
Mouse G502 X Plus
Keyboard K95 Platinum
Built a couple b450 pc's in the past (b450 tomahawk both) that also couldnt quite manage 1:1 with 1800 (3600mts ddr4) Maybe try 3433 as well and if ti goes away, well, there's your answer
2,561 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
8,644 (3.98/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
I've built hundreds of Zen2 and Zen3 systems, and I've RMA'd a dozen or so CPUs with cache heirarchy bluescreens.
You might be able to restore stability with a voltage bump and a negative boost override to stop it trying to reach the highest boost clocks, but AMD absolutely do swap these CPUs out because they're not stable at spec/stock speeds and voltages.
As long as you are within the returns window, it's faster to return for a refund and buy something else. If you are outside of the returns window, raise an RMA.
2,561 (0.53/day)
System Name KHR-1
Case Corsair 275R
Did the Vermeers have a pre-21xx date code? It seemed that my Ryzen 7 3700X (Matisse) (Zen 2) stopped having those episodes.
