WHY cant i find a modded Bios for a GTX Titan Z card anywhere? HELP please?
Status
Not open for further replies.
20 (0.01/day)
System Name My Build Asus Deluxe X99 3.1
Processor i7 Intel 5960
Motherboard Asus Deluxe X99 3.1
Cooling Corsair H100i V2 and Corsair Dominator Airflow Platinum RGB LED Memory Fan Cooling
Memory Corsair DOMINATOR® Platinum Series 16GB (4x 4GB) DDR4 DRAM 3200MHz C15 memory kit for DDR4 Systems 1
Video Card(s) 2 GTX Titan Z GPUs overclocked bios
Storage Samsung 950 PRO -Series 512GB PCIe NVMe - M.2 Internal SSD AND 2 WD 4 T HDDs AND 1 Samsung 512g SSD
Display(s) Samsung Monitor LCD
Case ThermalTake
Power Supply 1500 W power supply ATX Corsair
Mouse Alienware TactX Mouse
Keyboard Alienware TactX keyboard
Software Windows 10 Pro modified with Winreducer.net
Benchmark Scores 27703 3Dmark
The title says it all........any help would be greatly appreciated because I MESSED up and flashed it with what I thought was a titan Z bios to find out it was not. /sigh
qubit
Overclocked quantum bit
17,865 (2.84/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Check out TPU's BIOS database, it might just be there. If not, just RMA it.
3,014 (0.63/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
20 (0.01/day)
Case ThermalTake
20 (0.01/day)
Case ThermalTake
Well.....that's a bit tough to do......I have had a NIGHTMARE situation with Dell and they want me to send in my whole system and let them diagnose it, I have latterly almost punch they guy through the phone lol.....they have been horrible and I refuse to deal with them anymore. I called NVIDIA and shockingly they tell me that they don't make that card, they only make the chipset? I asked Dell and Dell says they buy them from NIVIDA but NIVIDA says they just make the chipset for that card? That is horse shit......the card is only 6 months old and I am almost certain Dell doesn't have a plant that makes NIVIDA Cards..........as usual no one wants to take accountability.
qubit
17,865 (2.84/day)
Quantum Well UK
Keyboard Yes
So your Titan Z came as part of a complete Dell gaming system, is that right? In that case, it doesn't surprise me that they want to deal with the whole PC as one unit, however inconvenient that may be for you, because the warranty applies to the whole unit, not just a component of it. Call them again and just RMA it, or maybe do it online in if you can.
Make absolutely sure that you back up your data before sending the PC in and then erase it from the PC so that nosy people at Dell don't end up going through it. Make at least TWO copies of that data or you could easily lose all of it. Three copies if possible is better.
NVIDIA are right that they only supply the GPU and that it's the board partner who makes it, so the warranty is with them. In this case the "partner" is Dell from your perspective although someone else physically made the card, so your warranty is with Dell.
Looking at your specs, it's not quite clear regarding your graphics card. Do you actually have two Titan Z cards in there, or do you mean the two GPUs on the one card? I think you mean the latter. Note that the specs should normally specify just the model of card, regardless of whether it contains one or two GPUs in it.
Finally, I wonder why you were flashing the BIOS on that card in the first place? It's hugely expensive to risk bricking it, as yours is and there's almost never a good reason to do it.
EDIT: As @the54thvoid said below, bricking a card with a flash also voids its warranty so you shouldn't be looking for support from Dell anyway. It's just that the warranty will often be honoured since proving that it's the customer who broke it and that it's not just a corrupted BIOS is difficult for them. In other words, you'll probably get away with it, but it's dishonest to claim warranty under this circumstance.
the54thvoid
Super Intoxicated Moderator
13,398 (2.41/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
I'm not being rude but that includes you. I had an original Titan way back and flashed that. I did it with great wariness because I knew, flashing a single BIOS chip card was (a)warranty breaking and (b)unnecessary.
You can't blame Nvidia or the partner. They have no obligation to help. I would persevere on your own trying to flash it back. You might need a 2nd Nvidia card to reflash or use a USB flash method, neither of which I've used. OCN are very good at helping but so too can some of our community. @Law-II (?) Is usually very helpful on TPU but not seen a post for awhile.
Good luck regardless and I imagine lesson learned.
12,333 (2.23/day)
Oregon
Keyboard EVGA / Logitech K400
Dell could refuse to fix it all together. So is it bricked or just not running to specs?
20 (0.01/day)
Case ThermalTake
Well the good news is, I sat down tonight and spent some time reading and trying a few suggestions people have offered AND I was able to fix it.
I must have been half asleep when I posted this thread because i was not thinking clearly .... I simply loaded up GPUZ and then put in one of the working Titans Z cards , downloaded it's bios and then put the semi bricked one in, flashed it with NVFLASH ..... Waaa laaaa ! It's good as new .... I think haha .
Now to find 2 water blocks ! Why is it so hard to find these ? Grrr.
Oh and yes I actually have 4 Titan Z cards, I'll just say this .... DELL inc are idiots . They will be out of business in less than 5 years.
qubit
17,865 (2.84/day)
Quantum Well UK
Keyboard Yes
That's great that you fixed it, but why did you flash it in the first place?
You're wrong about Dell going bust.
7,607 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Where are the golden mountains and milky rivers where you can fish out so much Titan too much Zeroes?
Tatty_Two
Gone Fishing
25,980 (3.72/day)
Worcestershire, UK
Software Win 11 Home x64
I just had a case of not reading the whole thread, read first couple of posts, went to our Bios collection and found 2, a reference NVidia one and an EVGA one, you have to specify "unverified" to find them though, there are hundreds in there that will not show on the normal search........then of course I have come back to a problem solved :oops:
3,014 (0.63/day)
Zagreb, Croatia
Cooling Corsair AIO
Great, had I known you had extra working titan z card (what are the odds?), that exact procedure would be my suggestion.
@Tatty_One good to know there is "Unverified" category
Read a little into that post and from what I read.........that bios bricked a card........
Oops, how evil of me :oops:
20 (0.01/day)
Case ThermalTake
ok so where did u see these bios? I thought mine was fixed but it seems that I might have only flashed ONE of the 2 bios in the card. one says TITAN Z and the other is missing the Z......../sigh. is there a guide to flash a duel card somewhere?
Because I wanted to?
and YES they will...........ill bet you my card!
the54thvoid
13,398 (2.41/day)
Software W10
I can't recall where I read it but I think the PLX chip can cause issues with flashing. Somewhere (on OCN?) said it can bee seen as a VGA itself (the PLX chip) and if flashed can entirely brick the card.
qubit
17,865 (2.84/day)
Quantum Well UK
Keyboard Yes
That doesn't explain anything. Well, why did you want to? For no reason? What? No one flashes a card, especially one this expensive for no reason. You wanted help with this problem and TPU helped you out. The least you could do is explain your reasoning to us.
I explained to you how the whole computer is treated as one unit and that's why Dell want the whole thing back to fix the card. Sucks, but that's the way it is. You can't tell me that that Dell are gonna go bust because you didn't understand how the returns process works, lol. :shadedshu:
dorsetknob
9,106 (1.25/day)
Now you have a bios copy archive it somewhere SAFE Ready for your next .................
Ps you can also upload it here to TPU just in case Dell done something non standard to the Bios
I'll take that bet
probably you wont have that card in 5 years anyway so i expect you to welsh on the Bet :)
Tatty_Two
Gone Fishing
25,980 (3.72/day)
Worcestershire, UK
Did you look at the picture? In our Bios collection. As for flashing, don't you only flash the Bios you are set to? If so when you have done the first, shut down, flick the switch, restart..... flash.
I should point out though, the whole point in having 2 is if you mess one up you have a backup plan, never a good idea to flash both in my opinion.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.95/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
Racial correction needed here.
To "Welch" on a bet is something to do with some bloke in England years ago and nothing to do with the Welsh.
I will bet you on it....:toast:
the54thvoid
13,398 (2.41/day)
Software W10
My Welsh mother likes this ^^
44 (0.01/day)
Processor Intel 14900KS
Motherboard ASUS Maximus Z690 Extreme
Cooling Custom water cooling with EK
Memory 2x16GB TForce 6800CL34
Video Card(s) ASUS RTX 4090 Strix OC
Storage SN850x 2TB, Intel 670p 1TB, 10TB HDD
Display(s) Dell U3415W (3840x1600)
Case Lian Li O11 Dynamic White
Power Supply EVGA 1600W T2
Mouse EVGA X20
Keyboard EVGA Z20
Would you be willing to send me a copy of the titan z bios (one bios for each gpu)? I've bought a used Dell Titan Z in need of a bios flash and I've tried all the unverified bios (in every combination possible) here with no luck. It appears in Windows 10 Pro 64-bit, allows me to install drivers, but as soon as I restart Windows the two GK110s are under a Code 43 in Device Manager and GPU-Z states both gpus have a revision of FF and the BIOS Version, Pixel Fillrate, Memory Type, Texture Fillrate, Bus Width, and Bandwidth are Unknown.
dorsetknob
9,106 (1.25/day)
your request sorted follow Tattys instructions
44 (0.01/day)
Mouse EVGA X20
Keyboard EVGA Z20
Thanks for the suggestion Dorstknob but I've already tried all bios uploaded here on Techpowerup (in every combination possible) as well as any other that could be found through an extensive Google and Bing search (including the Asus bios mentioned above). My problem is all uploads are unverified and most importantly none come as a pair. The Titan Z has two GK110s and each comes with its own separate, distinct bios (the two distinguished by the second GK110 having a number +1 numerically higher than the first GK110). I've contacted EVGA and they said they couldn't help since my Titan Z was a Dell OEM part. My only chance at this point is the community of Techpowerup to upload a pair of Titan Z bios, one for each GK110.
Tatty_Two
Gone Fishing
25,980 (3.72/day)
Worcestershire, UK
I know where you are coming from, in reference to "unverified" here in our downloads section, all that means is that it has not actually been looked at in detail and thereafter uploaded into the database, mostly because there is only one person checking GPU-Z Bios uploads and we probably get several hundred each month.
43,892 (6.80/day)
Status
