Why is my GPU saying 7000Mhz @ Idle!???
179 (0.19/day)
47.1301417 -119.2780771
System Name FronkenSteen!
Processor Intel(R) Xeon(R) CPU E5-2640 v3 @ 2.60GHz, 2601 Mhz, 8 Core(s), 16 Logical Processor(s)
Motherboard X99-UD3P-CF
Cooling The Refrigerator
Memory 16GB
Video Card(s) r9 390x 8GB, RX 580 8GB, RTX 3060 (Barely Functional), An RX 5500 XT and a little cheap ati card ;D
Storage 960GB Kingston
Display(s) one
Case Nun! xD
Power Supply 1200 Watt.. 'Nuff Said!
Mouse Flashing Red Dragon
Keyboard Flashing Rainbow Dragon
VR HMD HP
Software Windows 11 64-Bit (Version: 10.0.22000 Build 22000)
I wanted to play one of my space games but noticed when i opened a simple program like steam, the GPU SPIKES terribly!?
I just cleaned it and applied thermal paste to it too..
Anyone know why?
4,820 (3.86/day)
Colorado, U.S.A.
Power Supply EVGA 500W1
Software Windows 11 Home
Try GPU-Z
Double Data Rate (DDR) can be confusing on how one counts the memory clock rate.
2,789 (2.16/day)
Germany
System Name Sunk Cost Fallacy
Cooling Thermalright Phantom Spirit 120
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Streacom BC1 V2
VR HMD Oculus Rift S
and what exactly is the problem?
179 (0.19/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
the problem is as stated the gpu spikes when a program.. even on steam, and paint etc. lol???
Try GPU-Z
here is a screenshot:
i'm also up to date on the drivers too..
2,789 (2.16/day)
Germany
yeah that's normal behaviour of a GPU when it switches between 2D and 3D Mode when you use your PC...
500 (0.28/day)
Processor i9-9900K @ 5.1GHz (H2O Cooled)
Motherboard Gigabyte Z390 Aorus Master
Cooling CPU = EK Velocity / GPU = EK Vector
Memory 32GB - G-Skill Trident Z RGB @ 3200MHz
Video Card(s) AMD RX 6900 XT (H2O Cooled)
Storage Samsung 860 EVO - 970 EVO - 870 QVO
Display(s) Samsung QN90A 50" 4K TV & LG 20" 1600x900
Case Lian Li O11-D
Audio Device(s) Presonus Studio 192
Power Supply Seasonic Prime Ultra Titanium 850W
Mouse Logitech MX Anywhere 2S
Keyboard Matias RGB Backlit Keyboard
Software Windows 10 & macOS (Hackintosh)
Anyone know why?
because it's supposed to....lmao
that "simple" program like Steam is still rendering a buttload of images and videos that are all likely turning on at the same time with auto play.
179 (0.19/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
sooo it's OK to try and play games without crashing you mean?
4,820 (3.86/day)
Colorado, U.S.A.
GPU-Z says memory is clocked at 1750 GHz, so all is good.
500 (0.28/day)
Case Lian Li O11-D
yes, of course.
if you minimize Steam and return to just the desktop the card would downclock again. restore the Steam window and card will ramp up again, it's doing what it is designed to do. displaying those programs isn't as "simple" as you would like to think. the GPU does need to do some work, hence clocks go up, but it's not like it turns into an oven with top voltage and power draw as those will be very low which is why temps stay low even though the clocks went up
2,466 (4.53/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / RX 480 8 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / Viewsonic VX3276-MHD-2
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / FSP Epsilon 700 W / Corsair CX650M [backup]
Software Windows 10 and 11
Yeah, I approve of guys' words. Your card's behaviour is absolutely normal. No need to worry.
179 (0.19/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
ok thanks everyone i will keep you guys posted on this! :D
723 (1.35/day)
System Name BarnacleMan
Processor 14700KF
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast 5600 cl36
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte 850w
Mouse Some piece of shit from China
Keyboard Some piece of shit from China
Software Yes Please?
I think nvidia counts all the vram modules together so the frequency seems way higher than it actually is. Thats what I assumed anyway, I'm not actually sure. But that is definitely normal. Mine goes up to 10,500mhz just from opening steam.
I mean the math kind of makes sense, but not really. My 4090 has 12 chips of 2gb vram, right? GPU z says mem clock is 1313mhz. Times that by 12, thats just over 15,000mhz. Yet when I run heaven it says memory speed is 10,500mhz. Anybody able to shine some light on this? Where does that 10,500mhz number come from exactly? Its clearly not from a single module, but its not from all of them running at rated speed either. So maybe the load just isn't heavy enough, or what?
Deleted member 182555
gddr6x 16x 1313x16 = 21gbps x384bit /8byte = 1tbyte/s
21gbps = 10500 ddr
gddr6 8x, gddr5 4x, ecc
723 (1.35/day)
Processor 14700KF
2,198 (0.47/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Try GPU-Z
IIRC, it's quad-data-rate. (7000/4) Looks like it's the same as the GTX 1660 Super.
5,798 (4.34/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
I mean it's an RTX 2070, not exactly an uncommon sight... standard GDDR6 card.
If OP wants to conserve GPU usage they should enable low performance and low bandwidth mode on Steam.
