- Dec 17, 2005
- 448 (0.06/day)
System Name | Desktop |
Processor | 7800 x3d |
Motherboard | Giga b650i aorus ultra |
Cooling | pk-3 | conductonaut | AC LF II 280 |
Memory | 64g Gskill X5 ddr 6000 cl30 |
Video Card(s) | 7900 xt |
Storage | 2Tb Inland Premium |
Display(s) | Armada 27 1440p 165 + 25 1080p 240hz |
Case | Tt Black Armor : Phantek Evolv shift xt |
Audio Device(s) | Ae-7 |
Power Supply | Aresgame 850 sff |
Mouse | Razer Viper ulti |
Keyboard | Saitek Eclipse I, II, & III |
Benchmark Scores | assd 6600|x5675 Cne11.5 -1102|Timespy 24000 | TS Extreme gpu 1 - 87 fps |
qpi/vtt at 1.35 is definitely not fatal. iN FACT, too low of qpi/vtt was one reason my overclock to 4.8Ghz was unstable all the damn time. if i found the x58 xeon overclocking thread about all settings i will post it for you. No one has brought up what is your cooling solution? give that a read. https://www.techpowerup.com/forums/threads/overclocking-the-x58-a-practical-guide.108526/
Also your running way to high a voltage for lower than 4.4Ghz. I was stable at 1.32v @with 4.3Ghz and i still thought that was a tad high. I needed 1.45-1.5v for 4.6Ghz and 1.55v for 4.8Ghz. Neither were done without a good air cooler keeping temps down too.https://www.techpowerup.com/forums/attachments/untitled-png.90192/
go into hwbot(32nm westmeres)-look through cne 11.5, cne15, cne20 benchmarks-pick the ranking apart and search for images posted by those users that show what settings the used to achieve the overclocks. check out x5650,x5660,x5670,x5680,x5690 chips as well for more rankings since they are based on the same westemere precessors.
cne 11.5 rankings
Cne 15 rankings
cne 2 rankings
cne 11.5 rankings
Cne 15 rankings
cne 2 rankings
