XFX Double D Radeon HD 7970 BE cooling advice
182 (0.04/day)
System Name midnight toker
Processor i7 Skylake QHQF (6700K ES) @ 4.2GHz
Motherboard ASRock Z170 Pro4S
Cooling Corsair H100i
Memory 16GB (2x8GB) Samsung DDR4 @ 3200MHz
Video Card(s) Gigabyte Geforce Gtx 1080 Ti Gaming OC @ 2080MHz
Storage 128GB SSD, 75GB & 2TB HDDs
Display(s) Acer Predator XB1 XB271HU 27" 1440p 144Hz G-SYNC Monitor
Case Cooler Master MB511
Audio Device(s) Philips SHP2000 headphones
Power Supply EVGA SuperNOVA 1300W G2
Mouse Microsoft Wireless Desktop 3050
Keyboard same
Software Arch Linux, Windows 10 Pro 64-Bit
Being used to that Ghost Thermal Technology thing by XFX, I can't seem to find Gelid noisy at all, even at 100% as it seems. Mine is rev A though.
I guess I'll be able to set fan speed if I plug the power cable into the motherboard, I'm not getting in the mood for more hard mods for a long while...
PS: Water cooling would be kind of useless in my case. My GPU won't overclock higher than 1150MHz (core) under normal temps (<70C) without freezing games after a few seconds. Icy is perfect for me.
Edit: I managed to make it stable @ 1180/1575. Temps always < 64C.
1,609 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Well, to each their own.
182 (0.04/day)
Keyboard same
@coozie78, thanks for the tip once again. I'm glad I took some time before I made my mind as to which set I should get.
182 (0.04/day)
Keyboard same
The fans on the Icy Vision run where they are supposed to run. No need to adjust them.
Neat... I'll go with that for now. I'm still amazed about how good temperatures got: <68C @ the max overclocking this card can handle. I'm talking about hours of Furmark and Crysis 3 (1080p, very high settings, fxaa).
On "lighter" gaming (hitman absolution, max payne 3, saints row IV, all maxed out also), temperatures will keep around 56C.
As my card performance doesn't lower at all until core temperature reaches 96C, I'm really happy with current results.
85 (0.02/day)
System Name The Endless Road.
Processor R9 5900X under EKWB Quantum Velocity2 block.
Motherboard asrock x570 phantom gaming 4
Cooling EK-XRES 100 Revo D5, EK Quantum Surface 420M (case roof) with 3x140m.m. case fans, pull config
Memory 32Gb DDR4 3600/14 cas
Video Card(s) Zotac RX4080 Trinity, waterblock cooled.
Storage 2 Tb WD Black sn770
Display(s) 32" Gigabyte M32UC 4K/144 Hz
Case Corsair 7000D airflow
Audio Device(s) MB audio feeding a HyperX Cloud 2 wired headset
Power Supply Koolink Continuum 850
Mouse one
Keyboard also one
Software Win 11 Home 64 bit
Benchmark Scores I don't play benchmarks.
The fans will run at 100% if you power them through a unregulated header or connector. They are not PWM controllable, but they do have a tacho signal so should give accurate readings if run off a motherboard header.
If you plug them into the motherboard you can control the speed through BIOS although the control can be coarse, my MB only allows 25, 50, 75 and 100 percent.
You can run then through a separate controller unit, I'm using a Zalman FanMate , which is in turn, powered from a motherboard header, an arrangement that gives (possibly) accurate speed readings from BIOS and Speedfan.
Or you could get a 5.25" drive bay multi fan controller giving you a 'one stop' control of the main ventilation system, a neat solution but not as cheap as the FanMate. ;)
