Xigmatek Launches Thor's Hammer Heat-Pipe Processor Cooler
43,617 (6.44/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Seven heatpipes on this cooler btw. Four on the outside and three on the inside.
alexp999
Staff
8,012 (1.25/day)
Dorset, UK
System Name Gaming Rig | Uni Laptop
Processor Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz
Motherboard ASUS P5Q Deluxe (Intel P45) | HP 6715b
Cooling Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans
Memory 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz
Video Card(s) XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250
Storage 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5"
Display(s) Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution)
Case Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000
Audio Device(s) Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio
Power Supply Corsair TX650W | HP 90W
Software Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64
Benchmark Scores 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0
I noticed :D :drool: lol.
Thats why I'm so :confused: over the weight.
7,704 (1.16/day)
System Name Back to Blue
Processor i9 14900k
Motherboard Asrock Z790 Nova
Cooling Corsair H150i Elite
Memory 64GB Corsair Dominator DDR5-6400 @ 6600
Video Card(s) EVGA RTX 3090 Ultra FTW3
Storage 4TB WD 850x NVME, 4TB WD Black, 10TB Seagate Barracuda Pro
Display(s) 1x Samsung Odyssey G7 Neo and 1x Dell u2518d
Case Lian Li o11 DXL w/custom vented front panel
Audio Device(s) Focusrite Saffire PRO 14 -> DBX DriveRack PA+ -> Mackie MR8 and MR10 / Senn PX38X -> SB AE-5 Plus
Power Supply Corsair RM1000i
Mouse Logitech G502x
Keyboard Corsair K95 Platinum
Software Windows 11 x64 Pro
Benchmark Scores 31k multicore Cinebench - CPU limited 125w
iirc, the finish they added to the dark knight caused a slight drop in cooling performance over the standard S1283
Indeed... But I highly doubt that the S1284 was outperformed by the S1283..
So says personal tests and plain and simple logic.
*Yes I know the pipes are not dead aligned but that shouldn't matter especially when an IHS is intact.*
Personal tests between the two I always get "slightly" better results from the S1284, and have used 5 S1284's on Q9550s and 6 S1283's on Q9550's.. Now I know someone is going to say the quad makes a difference..
I have also used 4 S1284's and 9 S1283's on E8500's and get the same results.
All of these were setup with the bolt through kit.
3,779 (0.64/day)
Latin America, Uruguay
System Name The Lizard v2.4
Processor Intel Celeron G1840 (for the time being
Motherboard Gigabyte GA-H81-S2PH
Cooling Intel Stock Fan
Memory 16GB Kingston HyperX 1600
Video Card(s) MSI Gaming GTX 750Ti (For the time being)
Storage 500GB Samsung F1, 160GB Maxtor "Older than god"
Display(s) AOC 28' LCD
Case Coolermaster N200
Power Supply Antec VP500P
Benchmark Scores No crashes in the last 24 minutes.
dunno how it cools but its name its great and it looks great
spearman914
3,338 (0.54/day)
Brooklyn, New York 11223
System Name Mine | Dad + Mom
Processor E8500 E0 Wolfdale @ 4.6GHz 1.5V | E2180 M0 Allendale @ 3.0GHz 1.3V
Motherboard Asus Maximus Formula (X48) w/ Rampage BIOS | Asus P5Q Pro (P45)
Cooling Xigmatek Rifle HDT-S1283 w/ SFF21F Fan | Arctic Cooling Freezer 7 Pro
Memory G.Skill Pi Black 2x2GB 1.02GHz CL5 | OCZ Reaper 2x2GB 1.05GHz CL5
Video Card(s) Sapphire 4870X2 2GB 820/1020MHz | Sapphire 4850 1GB 700/1100MHz
Storage WD VR 150GB 10K RPM + WD 500GB 7.2K RPM | WD 200GB 7.2K RPM
Display(s) Acer P243WAID 24" 1920x1200 LCD | Acer V193W 19" 1440x900 LCD
Case Cooler Master HAF 932 Full-Tower | Antec Twelve Hundred Mid-Tower
Audio Device(s) Fatal1ty Xtreme Gamer w/ Z-5500 5.1 | On-Board Audio w/ S-220 2.1
Power Supply PC Power and Cooling 750W Non-Modular | Corsair HX-520W Modular
Software Windows Vista Home Premium X64 | Windows Vista Home Premium X64
Benchmark Scores Not Wasting Time!
But how does 2 same coolers ( but color ) come 2nd and 4th ?. Does the paint they use make such a difference ?.
It has a different fan so it's not the same.
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
TRUE is #1 but not worth the price.
trust me, i've compared them personally and the TRUE is way behind the modern xigmas. The achilles gets approx 5C lower on all 4 cores compared oto my lapped TRUE. (using bolt through kit)
AsRock
TPU addict
19,153 (2.98/day)
UK\USA
Ok so it's black and cost much more and does not work as well.. WTF
It does look really nice though but i'm against new looking stuff normally as it looks melted lol. This i like but from i am seeing would be a downgrade.
6,959 (1.04/day)
Australia, Sydney
Thor's hammer... first Xigmatek cooler to be for premium users? Those four heatpipes, since they each have symmetry will mean it will work well, but those two inner heatpipes are entirely redundant; almost all the heat that can be transferred will be transferred by the closely packed array of HDT pipes under.
Doesnt look like it comes with a fan. A TRUE of Xigmatek?
All the xigmatek coolers generally have difference performance, not because of the finish, the heatpipe configuration (well to some extent, but when you have three heatpipes or more that are 8mm thick and use HDT the performance increases, are like comparing thermal paste brands), but because of the fan. See the standard HDT S1283 used to use a 2000RPM fan which spun down to 1.2k RPM under normal conditions. However as soon as they released the HDT scorpion I noticed how the HDT S1283 then used a 1500RPM fan, with the low speed setting being at 900RPM; hence less airflow and performance.
In a nutshell the Xigmateks have such a variety in peformance mainly due to the fan.
Now just note, all of the previous xigmatek HDT coolers use the same construction method; slide fins onto heatpipe array without solder. This seems to be something comparable with the TRUE in terms of quality, but definately not performance.
Anyway HDT > TRUE end of story. As I've said many times, in many cases the HDT performs better. They're very close however but the cost of the TRUE isnt justifiable when you also need to purchase a fan! A HDT + Crossbow + Superior fan will leave the TRUE in the dust.
3,175 (0.52/day)
Brockport, NY
System Name Is rly gud
Processor Intel Core i5 11600kf
Motherboard Asus Prime Z590-V ATX
Memory (48GB total) 16GB (2x8GB) Crucial Ballistix Sport 3000MHZ and G. Skill Ripjaws 32GB 3200MHZ (2x16GB)
Video Card(s) GIGABYTE RTX 3060 12GB
Storage 1TB MSI Spatium M370 NVMe M.2 SSD
Display(s) 32" Viewsonic 4k, 34" Samsung 3440x1440, XP Pen Creative Pro 13.3
Power Supply EVGA 600 80+ Gold
VR HMD Meta Quest Pro, Tundra Trackers
sneekypeet
not-so supermod
29,666 (4.32/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
This is a pre release example. With the completed retail package I would assume it to come with a fan or even two.
7,704 (1.16/day)
Processor i9 14900k
Is this something that has changed, because I can understand a weakness there because of that... Almost enough to make me want to solder the fins.
Have not paid much attention to that..
6,959 (1.04/day)
Australia, Sydney
You see the issue with soldering is that you'll damage the heatpipes VERY easily-too much heat will probably cause the seal at the end to break, so DON'T do it. Thermalright I'd assume solder the whole cooler together, then seal the heatpipes.
And it doesnt even look like as if soldering really helps performance anyway. Note the fins are only there to carry heat away from the the heatpipes so that the vapour cools down and sinks back to the heat source (In less than a blink of an eye). A 120mm fin array will be sufficient, if the lack of soldering really was an issue then the Xigmateks would be poor peformers with hot heatpipes. Theres contact between pipe and fin (a pretty large surface area in fact) so its a non-issue. Sure you can "adjust" the fins a bit by just pushing it.
Why dont you try thermal paste instead, like inject it in the gap (probably impossible, and not paying for any damages).
5,250 (0.86/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
really i need Xigmatek cooler
Odin Eidolon
920 (0.15/day)
Rockclimbing somewhere in Italy
Processor e6300 @ 3000, stock Volts
Motherboard msi p35 neo2-FIR
Cooling HDT-1283
Memory 2gb tracers 1066 micron d9GMH, cooled by a modded CoolIt Memory Cooler
Video Card(s) HIS 4850 ICEQ4
Storage WD Caviar 16 320gb WDAAKS + 640gb WDAAKS
Case CM RC-690 sligthly modded
Power Supply Bequiet darkpower PRO 850W (say overkill? :D)
Software kubuntu 8.10 + Windows XP, soon Windows 7 too
looks good, the shape of he fins reminds me the new Thermolab Baram, which got good reviews. but the three internal heatpipes are gonna be useless IMO. reviews will tell.
Mussels
58,413 (7.87/day)
Oystralia
dont forget the deadspot in the heatsink behind the motor of the fan. The heatpipes may be designed to get the heat to travel out of that area, and into the areas the fan actually cools.
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
looks really nice & I would buy it in a heartbeat but Since when is Thor's Hammer BLACK. I could see if it was called (Evil Thor's Hammer)
Odin Eidolon
920 (0.15/day)
Cooling HDT-1283
WarEagleAU
Bird of Prey
10,812 (1.59/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
I am on water but I so want one of these bad boys. 7 heat pipes FTW :rockout:
3,301 (0.53/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + 2400 RPM push pull
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G200
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
I thought they were going to the Greek mythos path.. Looks like its norse mode also hehe
