Zalman CNPS9900 LED CPU Cooler
3,285 (0.44/day)
Sunny California
Processor AMD Ryzen 7 9800X3D
Motherboard Gigabyte Aorus X870E Elite
Memory 4x16GBs DDR5 6000MHz Corsair Vengeance
Storage 2TB Samsung 990 Pro OS - 4TB Nextorage G Series Games - 8TBs WD Black Storage
Power Supply beQuiet Straight Power 12 1500W
VR HMD Pimax Crystal Light/DMAS
Software Windows 11 Pro 64bit
Hmm... :p
After doing some research myself, I found the 9900 has about the same fin area as the 9700, and it runs around a couple or more deegrees celsius below the 9700, so I think I'll keep my current cooler; was asking because of a new build I just put together, and was considering getting a new cooler from Zalman...
Thanks for the review anyways :)
5,105 (0.75/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
Thanks for the review!
I have one question only, how does this cooler compare to Zalman's previous top of the line model, the 9700?
Thanks! :D
Don't have the 9700 to test against :(
The review over xbit labs shows that it doesnt even beat the age old SI128 from thermalright, yet the review i see here seem its like a pretty decent performer.
There are too many factors that affect CPU coolers and their performance. Unless the two review sites use exactly the same techniques, you wont find similarities.
An example; I know for a fact that most review sites simply measure the cooler performance and subtract results from ambient, or do some maths to get the same ambient. I don't do this. I control the rooms ambient to a certain degree and test the cooler at that. I have tried the subtraction method and it was always a few degrees off, so I stuck to controling the room temp. (To a relatively high temperature)
Higher and lower room temps also make a difference. A higher room temp may cause the CPU to heat up more, causing the fan to spin up more and therefore giving the cooler better performance. It could be the opposite as well. Some coolers may do better with cooler air flowing through the fins.
Thermal paste is also another factor which needs to be considered. Some sites may use the same paste for each cooler - I use whats given to me in the box, as 9 times out of 10, thats what the user will use.
So yeah...there are many factors ;)
1,074 (0.16/day)
System Name My Current Desktop
Processor i9 12900KF
Motherboard Asus ROG STRIX Z690-E GAMING WIFI
Cooling ARCTIC Liquid Freezer II 360
Memory G.Skill Trident Z5 RGB Series 32GB (2 x 16GB) DDR5 6400 F5-6400J3239G16GA2-TZ5RS
Video Card(s) RTX 3090 FE
Storage SAMSUNG 980 PRO SSD 1TB
Display(s) Samsung G80SD
Case Fractal Design Torrent White
Audio Device(s) Schiit Bifrost2
Power Supply Corsair HX850
Mouse Razer Basilisk v3 pro
Keyboard Keychron Q6 Max (brown)
Software Win 11 Pro
what is the street date for this?
932 (0.13/day)
Ireland
System Name "Run of the mill" (except GPU)
Processor R9 3900X
Motherboard ASRock X470 Taich Ultimate
Cooling Cryorig (not recommended)
Memory 32GB (2 x 16GB) Team 3200 MT/s, CL14
Video Card(s) Radeon RX6900XT
Storage Samsung 970 Evo plus 1TB NVMe
Display(s) Samsung Q95T
Case Define R5
Audio Device(s) On board
Power Supply Seasonic Prime 1000W
Mouse Roccat Leadr
Keyboard K95 RGB
Software Windows 11 Pro x64, insider preview dev channel
Benchmark Scores #1 worldwide on 3D Mark 99, back in the (P133) days. :)
Hi Pinchy,
QQ: Did you try running it with the fan on full (direct connect to 12v) (i.e. bypassing the PWM on the MB)?
Were the comparison fans also using PWM on the same board or direct connected?
I'd also not put no fan control as a con, as you can always connect it to your fan controller if you wish. ;-) (Although maybe at the price they could include one <G>).
Cheers!
5,105 (0.75/day)
Sydney, Australia
System Name UltraPC
Will ask for you now. :)
Hi Pinchy,
Cheers!
Nope, they have all being plugged into the four pin PWM connection on the motherboard. Reason I don't bypass this connection and go straight for a 3-pin is because most end users would plug it into the four pin, not the three pin. Hence going into the three pin wouldnt give "real world" results, if you get what I mean.
A good suggestion would be to have both PWM controlled and max fan speed in the results though. (Might do this on my next review :)).
About the fan controller: I put it as a con because I would think with the amount you spend you should get something extra (as you said :p). I personally prefer PWM to fan control, as I never bother adjusting it anyway, but yeah as I said for the price, id want something "more".
5,105 (0.75/day)
Sydney, Australia
System Name UltraPC
Reply from Zalman is sometime in February.
He will forward me the exact date when he gets the info from his US department.
