Zotac 4070 ti super uses AD102-175, but core power is 9+2. Is it bad?
Scraper
2 (1.00/day)
TDP 285W
MAX 314W
It has a bigger cooler than most 4090
Will it perform poor in overclock, with this low power supply?
7,624 (5.02/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Inconsequential, most of this AD102 chip is fused off, it should have similar characteristics of any regular 4070 Ti Super built on the usual AD103 core. Might clock a bit worse, might not.
Scraper
2 (1.00/day)
Thanks for your answer, I didn’t get 5070ti. I have to take this.:shadedshu:
7,624 (5.02/day)
São Paulo, Brazil
Really, don't worry about it. It is not a bad card, quite contrary. Besides, despite forking over the cash, most of us who purchased 50 series cards did not get our orders fulfilled yet, especially RTX 5090.
Ruru
S.T.A.R.S.
13,405 (3.01/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
I wouldn't be worried. Like Dr. Dro mentioned above, the GPU is so much cut that it's not even nearly as a bad power hog as it would be with 4090's configuration.
It's not that rare to have a card with higher tier's GPU with disabled units, it's better to use them in lower tier cards than throw them away. I remember EVGA RTX 2060 KO using a TU104 for example.
