- Oct 6, 2004
- 58,413 (8.16/day)
- Oystralia
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
I know from blasting my 1400 and 1700x that not all cores would OC the same, or even come close. Some would do 400MHz higher than others at the same voltage, and the highest clocking ones were not always the best undervolting ones either.That much i could think of too , higher clocks = higher voltage but the best cores need more voltage for the same speed , i guess they are programmed with lower VIDs from the factory, i thought they all came with the same VID.
It could be they're the closest to the power delivery and have more stable voltages, or the opposite (the furthest away could have smaller transients, smoothed by the distance) - this stuff would need AMD engineers to know and they don't like sharing without lots and lots of alcohol.
(Disabling cores in the BIOS and OCing with just 1-2 cores active - sketchy barely stable stuff on early AM4)
