5800x (and other Zen 3 chips) PBO settings/Temperature fix
Mussels
Freshwater Moderator
58,413 (8.16/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
The windows ultimate power plan and the 1usmus plan are terrible ideas, windows updated the stock plans for a reason.
You only need the windows balanced plan on any ryzen CPU to be perfectly fine, if the AMD chipset driver changes you to the ryzen balanced (3000) the difference is small anyway, it really just slowed some timer checks down to prevent monitoring programs spiking temps.
966 (0.48/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
I use Ryzen Custom Power Plans by ManniX-ITA
Works great for me. If anyone is interested you can find more info here. Power plans available for Windows 10 and 11.
Screenshot 2023-07-31 at 08-02-14 Ryzen Custom Power Plans for Windows 10_11 (Snappy.png
3 (0.00/day)
System Name MCP-PC
Processor Ryzen 7 5800X step B2
Motherboard Asus B350m TUF Gaming
Cooling LiquidMaster 120mm AIO with 2nd fan
Memory 4 x 8GB Micron E-die = 32GB 3866 CL16
Video Card(s) GTX 3070
Storage Adata 850 Lite PCiE, Samsung EVO 840, 850
Display(s) 1 x 2560x1440 + 2 x 1920x1200
Case Coolermaster MB311L mid tower. Fans Sickleflow 3x120mm + 2 x 140mm
Audio Device(s) Creative 5.1
Power Supply Coolermaster 650W modular
Mouse MX-518 (new)
Keyboard Hyperx Alloy FPS Pro Red Switch
Software Windows 11 Pro Beta
Benchmark Scores CB23 16312
Ryzen 7 5800X, stable and as fast as I could get both MC and SC.
CB23 in a clean windows and real-time priority goes to 16200+
CB23 with normal daily use PC gets 15800 anytime.
Max temp Blender Benchmark 82C, 120mm AIO.
1,521 (0.88/day)
Processor Ryzen 5600X@4.85 CO
Motherboard Gigabyte B550m S2H
Cooling BeQuiet Dark Rock Slim
Memory Patriot Viper 4400cl19 2x8@4000cl16 tight subs
Video Card(s) Asus 3060ti TUF OC
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores CB20 4710@4.7GHz Aida64 50.4ns 4.8GHz+4000cl15 tuned ram SOTTR 1080p low 263fps avg CPU game
Very nice ram timings :)
freeagent
7,622 (3.70/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I just use the balanced plan and have it set for no sleep.
1,526 (0.64/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Cooling D5 clone, 280 rad, two F14 + three F12S bottom/intake, two P14S + F14S (Rad) + two F14 (top)
Memory 2x8 GB Corsair Vengeance bdie 3600@CL16 1.35v
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@The King
unless its a laptop, you dont need any power savings enabled on desktops, besides the fact that i can do 2 profiles,
and use the battery icon (you do have a proper USV, right?!) to quickly switch between them.
one for light duty, with no power saving stuff on, but max cpu perf limited to 50% (limiting clocks) and actually making a real difference,
for power consumption and temp, without any affects on usb or pcie bus.
there is no magic which makes any "custom" power plan do something it cant do stock, so, yeah...
966 (0.48/day)
@The King
I live in a rural part of India where the power supply is not the best. Sometimes I have to run on my UPS for more than 10 hours a day.
Power saving profiles can extend battery backup time significantly in this scenario.
I also have a Laptop but still prefer to use my Desktop even when the power is out. I also game running on my UPS when there is no power.
So having the best energy efficiency for both the CPU and GPU helps with that.
1,526 (0.64/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@The King
sure, but thats not going to be the case for most.
and there is a difference between power savings (profile), and using power saving "features" like usb/pcie sleep (within profiles),
which will slow down bus(es) so most tasks will take longer, with minimal gains on power use.
not running on any of those (features), but limiting (max) cpu perf to say 50%, will reduce consumption by a lot,
without making win behave sluggish..
ignoring for a moment, that power profiles/UPSs arent designed to make up for improper power (quality).
then your better off with solar power/generator etc, as UPS are not designed to run equipment past the time it takes to save/shutdown.
you will run down the battery, hurting it (lead batteries dont like discharge beyond 10% of its capacity),
and reduce its service life and requiring early replacement (ignoring reduced runtime).
either way, its not the "normal" situation for majority of users, so it should be a (general) recommendation (to use power saving features within a profile),
unless ppl know why/how to use it (on desktops).
966 (0.48/day)
@The King
Unfortunately your knowledge is somewhat limited to smaller UPS systems which is commonly sold at most online store.
The system I have is capable of running longer than 24 hours by design. I am aware of those smaller UPS that are for saving your work and shutting down your PC safely.
I am not using one of those systems and the batteries I am using and designed to last for several discharge and recharge cycles.
The custom power plans have also got me several HWBOT records as well a few records here on TPU with my Ryzen system. It works great for me.
Several highly knowledgeable enthusiasts on Overclock.net use these custom profiles. I posted it for anyone who maybe interested in trying them out.
Has far as whether they work or not I achieved my highest Bench-mate scores using these custom profiles so yeah...
1,526 (0.64/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
nope
did IT, worked with servers/mainframes/workstations, running (multiple) different UPSs.
short of hydrogen based unit, all UPS use batteries, in one form or another, so the type of battery makes a difference,
not the size/type of UPS, and using them (down to low capacity) will always hurt lifetime, just depends on how "fast" they will degrade.
when did i say it doesnt work?
im just careful recommending settings/profiles used under specific circumstances/situations,
that dont (generally) apply to the masses, especially in forums,
where some (non experienced/outside reader) user might do stuff that doesnt gain them (much) (best case)..
ignoring for a moment that there is no "magic" on those custom plans (as in no one else can do this)
outside ryzen core affinity etc, you have to "turn off" something (to say it easy), to gain in efficiency, its not coming out of thin air.
966 (0.48/day)
nope
I see mostly positive posts from people using these custom plans.
Most recently this.
Screenshot 2023-08-03 at 12-34-19 Ryzen Custom Power Plans for Windows 10_11 (Snappy.png
I'm sure if you want to contact the author he will respond, he is a very friendly guy who helped me tune my Ryzen system for peak performance and efficiency.
He would be much more knowledgeable to address your concerns about running custom power plans, I am just an end user. :)
1,526 (0.64/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
oh no, dont get me wrong, its not about you or the custom pp,
just thinking about inexperienced users (that dont know what they are doing), glancing over posts and doing stuff useless/unneeded for their use/application,
especially when i see how many ppl have trouble reading, and need to see a YT vid, to know how to do things..
(not complaining, but the power plan stuff has nothing to do with PBO/temp fix, discussed here)
e.g. past experience:
i recommended 1usmus ryzen power plan and ram calc in the early days, until i realized some stuff is based on random/made up info.
e.g. claiming to have "read-out" spd's, when none matched when i had the actual sticks in my rig,
or recommending settings that made zero sense (1.65v for a kit doing same clock/timings at 1.45v, or soc at 1.15, when 1.05v is 800% HCI stable ).
to say it differently, just because some folks use nox for increased HP on their track cars, doesnt mean its a good idea for all (everyday) cars to use it. :D
Mussels
58,413 (8.16/day)
Oystralia
For a B350 board, that's a really good ram speed
I see people using windows hidden ultimate performance power plan, despite it being well known it breaks multi CCX CPU's and any intel chip with E-cores.
They may work better for someone with a static OC and worse for someone on auto, or the inverse - or it may work for one CPU design and harm another like with CCX counts.
preventing sleep states for someone with PBO maxed out changes nothing, but could cripple someone with a 45W or 65W chip because the sleeping cores are now awake and eating their power budget for lower thread loads.
They can and do help people - but it's usually fixing a problem with their setup, rather than universally being good.
16,216 (4.64/day)
Processor Ryzen 7800X3D -30 uv
Motherboard AsRock Steel Legend B650
Cooling MSI C360 AIO
Memory 32gb 6000 CL 30-36-36-76
Video Card(s) MERC310 7900 XT -50 uv
Display(s) NZXT Canvas IPS 1440p 165hz 27"
Case NZXT H710 (Red/Black)
Audio Device(s) HD58X, Asgard 2, Modi 3
Power Supply Corsair RM850W
I don't understand why my 5600X3D chip runs so cold. I thought for sure with x3d cache it would run hotter, but I never see it break 59 celsius in games, even very demanding x3d cache hungry games. I just run -30 CO all core in BIOS and no other changes. it boosts to its max frequency all the time which is 4350 all core. I'm happy with that though, great performance and temps.
:toast:
Mussels
58,413 (8.16/day)
Oystralia
:toast:
It's sensitive to voltage so they clock lower than non-3D versions of the same chip
The cache doesnt run as hot as the rest of the cpu.
In gaming they run cold because they dont need to do all the math again, frame by frame the content is so similar they've got high odds the answers are already in the cache - if they are, it doesn't have to do any work. Less work, less heat.
67 (0.01/day)
North-east Italy
System Name Main Build
Processor AMD Ryzen 7 5800x
Motherboard MSI x570s torpedo max
Memory 32 Gb Crucial Ballistix 3200MHz CL16 @ 3800MHz
Video Card(s) Gigabyte RTX 3060 ti OC Pro
Storage Kioxia 1TB NVMe - Crucial P3 2Tb NVMe - WD Red 2+3TB
Display(s) Philips 325E1C (32" 1440P) + Vertical 24" 243V7Q
Case Corsair 4000D Airflow
Audio Device(s) Indiana Line TH260, TPA3116D2 Amp
Power Supply Seasonic Platinum 660W SS-660XP2
Mouse Logitech Performance MX
Software Win 11 Pro
What temps do you get under cinebench 10 min crunch?
I've tried your same settings (143W / 95A / 120A) on my 5800X, and so far it's been one of the best results I managed to get. Thanks for the data in the reply!
Running the same setup, with CO -29/-29/-29/-14/-18/-29/-29/-4, +150MHz boost, -0.1V vcore offset and 2x16Gb DDR4 running at 3800MHz CL16 cinebench yields 15928, Blender 3.6.0 does 234.5 under a "normal" windows install with a few apps stopped (and cinebench set to normal affinity). Cooling is a Thermalright Peerless Assassin with the two stock fans in a corsair 4000D airflow with 3 intake fans and a single exhaust, all running well below 45% during the tests. Max temp I've got in cinebench is 81.4°C, with room air at 25.5°C. I've got a profile for FanControl that pushes the fans more, torwards 70%, but I get at best a 1°C difference in temperature and no real performance improvement with this config.
I've tried pushing the ram a bit more (Crucial Ballistix BL2K16G32C16U4B, serial begins with E71D6), at 3800MHz it takes already 1.38V and a hefty 1.0625V on the SOC. I can boot fine at 3866 or 3933, but probably I need a lot more voltage or less tight timings to keep it stable. Currently both at 3866 and 3933 I get random crashes and errors running 1usmus ram test in testmem 5.
:toast:
I'm not that surprised.
While the 5600x3D is still a 105W tdp chip, it does have "only" 6 active cores active in the chiplet itself. These 6 core variants do run a lot colder than the 8 cores ones, mostly due to the limited ability of today's cooling systems to sink heat away fast enough from the cores. The Zen 3 ccd die is just 83mm2 (11.2 x 7.4mm), It's actually so small the thermal resistance added by both the solder and heatspreader are significantly relevant to the overall core temperatures.
Most of the temps shown in this thread are under extreme AVX2 / AVX512 workloads (cinebench or blender rendering, prime95, or similar) which will push the cpu to the absolute maximum power allowed by the limits. Normal in-game temps are usually in the 60-67°C here as well. My brother is running a 5600g and it's far colder than my 5800x.
Mussels
58,413 (8.16/day)
Oystralia
Looking at the PBO settings in the post above, it's unlocking PPT for multi threaded while capping the ST a little bit.
That'll control the ST temp spiking, but requires a boards VRM's and CPU cooling to handle the full 142W sustained.
Probably an ideal setup for "good CPU cooling and VRM" users.
14 (0.00/day)
limitaiton isn't the board
limitation is the thermal density of the chip
unless you are using direct-die cooling you just can't get the heat out of the chip fast enough beyond 150w
I was replying to the post talking about "relaxed EDC throttling" and other related settings. TDC and EDC settings have almost nothing to do with the CPU control itself (CPU performance is a side effect) and are entirely about motherboard VRM safety limitations. A 5800X should not be overtaxing board VRMs, even cheaper and older ones.
As with the arguments about my CPU settings in this thread months and months ago, it seems like you people just have to be right about everything, to the point of willingly not paying attention.
For that matter I've been 100% stable since October, after several people Mussels included, told me it was impossible. So I'll take everything I read here with a gigantic grain of salt.
tabascosauz
7,672 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Memory 64GB 6000CL30┃32GB 3600CL14
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Most recently this.
I used to use Mannix on Win 10 because it got me my best and most consistent scores on 5900X. But after Win 11 came around it basically rendered all the plans useless. I recall seeing on his OCN page that even he admitted that the Win 11 scheduler basically invalidated what his power plans did.
Then on the 5800X3D, it's pretty straightforward and low Fmax all around means not much point experimenting with plans.
:toast:
Even the 5800X3D shouldn't break 70C in vast majority of games. It just doesn't draw nearly enough power in games. It's when you run synthetics that it turns into something entirely different.
Density is still very much a thing, better optimized games that don't crank everything on 1 core run easily in the 50s. New F-15E in DCS has a slider for thread count dedicated to APG-70 radar calculations - drag the slider up to 10 threads to see the 5800X3D chill at sub-60C barely breaking a sweat, drag it down to 4 or 6 threads and see one core on the 5800X3D breaking 80C.
Mussels
58,413 (8.16/day)
Oystralia
Ah, i see.
Problem is that EDC doesnt seem to actually get any readings from the motherboard - EDC lowers the current as the CPU approaches it's thermal throttle rather than the VRM temps. It's designed to lower the CPU clocks to keep the CPU away from it's throttle point, not the VRM's throttle point.
And sadly... a lot and i mean an awfully large amount of AM4 boards cant even handle that ~142W limit of a 5800x.
Theres a ridiculous amount of budget 3+1 and 4+1 VRM boards out there in product lines they shouldn't be
HUB and GN have great stuff on this, so much it's hard to find the specific things i'm looking for to reference them
Having an asus x570, the lack of a VRM sensor is quite annoying
yes, it's a high wattage test but when you add GPU heat to a gaming machine its closer to stock temps than you might assume.
They did this which is hard, when board prices vary a lot but the idea that you get what you pay for is thrown right out the window - pay $20 more and double your VRM temps!
Other videos included the CPU performance (especially on the intel side) because it turned out a lot of colder running boards were simply limiting performance instead of running hotter.
Feels like reviews need to include the graphs that include R23 performance and VRM temps side by side to have the faintest idea how they actually behave, because one set of information alone is never enough.
2,428 (1.39/day)
System Name Not a thread ripper but pretty good.
Processor Ryzen 9 5950x
Motherboard ASRock X570 Taichi (revision 1.06, BIOS/UEFI version P5.50)
Cooling EK-Quantum Velocity, EK-Quantum Reflection PC-O11, EK-CoolStream PE 360, XSPC TX360
Memory Micron DDR4-3200 ECC Unbuffered Memory (4 sticks, 128GB, 18ASF4G72AZ-3G2F1)
Storage Samsung 2TB 980 PRO 2TB Gen4x4 NVMe, 2 x Samsung 2TB 970 EVO Plus Gen3x4 NVMe
Power Supply Corsair RM750x
Mouse Logitech M575
Benchmark Scores Typical for non-overclocked CPU.
Ah, i see.
That ASRock x570 Steel Legend sensor must be in a really terrible place to be so far off the mark.
Mussels
58,413 (8.16/day)
Oystralia
That is the big problem. Been discussing this with @ir_cow and motherboard reviewers on how they test VRMs and the answer came back that it's bascially a nightmare
Some VRM's can safely run at 120C, others thermal throttle at 80C.
Some can handle 50A at any temp, others are 80A at 25C and 20A at 80C.
On many boards, the hotspots are where you expect - others it must seep away through the traces in the PCB and heat up seemingly unrelated areas, especially in a blank spot between those heat sources where that heat may simply accumulate due to lack of airflow
@ir_cow made the silly mistake of getting me thinking on how to judge motherboards completely and fairly, so here's an in-depth teardown on that board above and why so many AM4 users had issues they couldn't resolve without a board swap.
This is that board with it's high VRM temps and shoddy marketing, but tended to be actually liked by it's owners. How can a high VRM temp board with weird claims not be trash?
I mean honestly, look at the marketing for this - DDR4 4666+ on AM4?
10 phase power design (later called 8+2) that's downright false
We've got a dedicated thread to trying to get people to 4000 stable, let alone that huge number.
Quad crossfire?? I'm sensing a basic math problem with that
VRM's look beefy, but its a basic 4+1 setup (general rule is inductors divided by 2)
They say 8+2, but this is when people started to get annoyed if they failed to mention doublers in marketing
Next slide is about "premium" 60A chokes
Cheating a little here since someone else identified the parts for me but throwing in my interpretations on top.
A quick google on this board shows it has a PWM controller that can only do 7 phases
That article covers that it's been used in a 4+2 (doubled) setup
The x570 Taichi that people loved had the same VRM's but used 10 of them (and four weaker ones for the SoC)in a 6+2 setup covered here on TPU.
Problem is that most VRM's are a rated a little dishonestly as Asrock says they're 60A, but the spec sheet says 50A - with 55A burst capabilities for only 10 milliseconds while the spec sheets show a realistic limit of 45A before they start pumping out heat
These are at least safe to high temperatures, showing they can handle upto 110C problem free - as long as you're under 50A. Full power, always? Nice.
The efficiency chart shows why that limit exists - because passing 20A, the sweet spot is gone - and past 30A you're at 15% of your power thrown to heat.
AM4's default PBO *on* limits are TDC: 95A and EDC: 142A with PPT: 142W
(At some point an "EDC" bug was introduced in AGESA that stopped boards passing these amperage limits, my guess as a failed safety limit - that's been corrected)
8 of those VRM's at AM4's stock 142A with a 5800x would be 17.75A each, quite happily in that sweet spot... before board makers bad decisions get involved with BIOS settings.
5800x uses the same power limit as 5950x with double the cores - so in theory if nothing like thermals or BIOS settings limited you a 5950x could use double the values of a 5800x.
(Same voltage, double amperage and wattage to twice as many cores)
My 5800x on an Aourus B550-i ITX ran at 130A in R20 and R23, while kitgurus review of a 5950x with unlimited PBO went upto 215A - close to that theory
From an engineering perspective, that board gets a pass - that'd be very hard to overheat to 120C, and the VRM's should in theory handle even a power unlocked 5950x.
215A / 8 = 26.875W, within the VRM's happy place let alone their 50A maximum.
But you see 90C and you think oh god it's bad, because OTHER vrm's overheat at 80C or less
Ironically this chart shows an x570 steel legend with another 32c left on it's VRMs going by it's sensor readings while some of these others may be toeing the line to overheating or already throttling the CPU
As another metric that's ignored, the inefficiency of designs can lead to extra power wasted as heat - a 30W difference is huge for a small CPU like a Ryzen 2600
I get the feeling the checklist to actually test boards is a relatively large one with everything needing to be tested simultaneously to be useful
1. VRM specs, especially the temperature they start to lose efficiency
2. All testing done with the highest power consumption CPU you can get, to find a boards actual limits
3. Also testing within recommended limits - AMD's stock PBO and Intels PL1/PL2 targets.
R23 test runs would need all the relevant data slapped together in one graph somehow:
  1. CPU's effective sustained clock speed (indicator of throttling)
    R23 score (performance loss vs competitors)
  2. Maximum amps drawn by CPU (HWinfo)
  3. Wattage used by system (Wall reading)
  4. VRM temps (and their rated maximums)
I also just ran into an issue on my ITX system where "PBO disabled" boosts harder than PBO with maxed out settings because ?!?!?
Crap like that is why people have issues with 90c at stock
tabascosauz
7,672 (2.37/day)
Western Canada
System Name ab┃ob
I thought we've been over this before, real vs doubled/parallel phase count literally doesn't matter for VRM thermal performance and current handling capacity, when comparing relevant DrMOS configs that make sense in 2023. It can have smaller effects on electrical performance like efficiency and volt reg, but that's besides the point. All board vendors these days advertise doubled/parallel phase count, not true phase count, which is just fine for what they want to convey.
There's also only a few controllers that have that much phase support. XDPE, that RAA229131 that Intel boards like.......true 14 phase boards like Unify weren't better just because they didn't double/team phases. Z790 and AM5 all have adopted teamed phases as standard in the 10+ phase count segment, with only a few exceptions.
I agree what is really dumb about ASRock is that they keep advertising that choke current rating - not like it's completely irrelevant, just not nearly as useful info.
I'm not sure why we're still looking at B450 HUB testing - all except one on that chart are discretes which basically don't exist anymore in 2023, and the only one that isn't (Aorus) is a special case with only 4 phases that actually had quirky power issues with >100W CPUs.
Not sure why we're hating on the Steel Legend QVL, 4666 was not that hard with the right kits. Pretty sure BZ was up to 4800 with B-die. It's an especially strong 4 layer. You can't just expect to max out the board on Hynix MJR.
Mussels
58,413 (8.16/day)
Oystralia
I didn't say it was bad at all - in fact, i state at the end that the design works well with room to spare.
It's perception that's the issue, because one piece of the information alone gives misleading ideas about the product - and shitty marketing makes you trust them even less
Quad crossfire from two slots? Seems unlikely.
(yes its because AMD had a dual GPU card out back then, but it's pretty misleading to claim it supports quad crossfire when that normally meant four regular GPUs)
ir_cow
3,856 (0.67/day)
USA
That's the hard part about VRM thermal testing. Finding the data sheets. Because while one can handle say 50A, that isn't linear (usually) and efficiency goes down as it heats up. Suddenly you are at 110c and in a thermal runway scenario.
