5800x (and other Zen 3 chips) PBO settings/Temperature fix
20 (0.02/day)
Germany
System Name sadness
Processor 5800x 4.4 1.2V
Motherboard MSI B450M Mortar Max
Cooling NZXT Kraken V53
Memory 2x 8GB G.SKILL TridentZ 3200 not B-Die
Video Card(s) Zotac RTX 2070 Mini 2050MHz OC
Storage 1x Samsung 970 Evo Plus 2x Seagate 2TB HDD 7200RPM
Display(s) 1x BENQ 60hz 1x 144hz AOC C24G1
Case idk some rando Corsair one
Audio Device(s) DT 770 Pro 250Ohm on Fiio DAC
Power Supply China-D Boeller
Mouse Glorious Model D White
Keyboard custom built
Mussels
Freshwater Moderator
58,413 (8.16/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Here are a few pictures of my bios. It looks like it's not even showing the cpu fans so I'm not sure how I can control those if there is no readings? Also seems like the case fans 3,4 are DC.. Also for the 3,4 fans I can't seem to control the curve at all. It only allows me to choose smart fan. I'm currently controlling the cpu fans via the corsair software but it not showing up here in bios I'm wondering if something is wrong and that is why the fans keep ramping up in speed randomly. Maybe the sensor corsair is using is not the cpu sensor?
Your BIOS cant show fans that aren't connected directly to the motherboard
Mussels
58,413 (8.16/day)
Oystralia
Came up with something discussing motherboard settings in a PM, and its worth sharing here - help getting the wording accurate for clear understanding would be useful before it goes into the OP
AMD's default is that EDC is 1.5x TDC, at least in the examples i've found listed.
The problem here is that "Thermally constrained" isn't explained properly, in that you can set a value too high for the VRM's and they rely on their own internal throttling which tanks CPU performance massively vs negotiating a lower value - so it seems TDC must be manually set to work correctly, rather than something that automatically triggers based on a temperature readout many boards lack, or don't expose to the end user.
It's worded like it's a time limit, or something that negotiates based on VRM temperatures but seems to behave like a 'dumb' feature instead that needs to be accurate in the beginning, and most boards simply enabling PBO to access settings like the curve undervolt defaults these to maximum "Motherboard limit" values, negating what the users went in there for in the first place.
I get the feeling these features often do not work correctly, because the board manufacturers never enter accurate values for the boards, but instead something that looked good in quick benchmark tests or just straight to AMD's maximums.
Originally from AMD/Gamers Nexus
Package Power Tracking (“PPT”): The PPT threshold is the allowed socket power consumption permitted across the voltage rails supplying the socket. Applications with high thread counts, and/or “heavy” threads, can encounter PPT limits that can be alleviated with a raised PPT limit.
  1. Default for Socket AM4 is at least 142W on motherboards rated for 105W TDP processors.
  2. Default for Socket AM4 is at least 88W on motherboards rated for 65W TDP processors.
Thermal Design Current (“TDC”): The maximum current (amps) that can be delivered by a specific motherboard’s voltage regulator configuration in thermally-constrained scenarios.
  1. Default for socket AM4 is at least 95A on motherboards rated for 105W TDP processors.
  2. Default for socket AM4 is at least 60A on motherboards rated for 65W TDP processors.
Electrical Design Current (“EDC”): The maximum current (amps) that can be delivered by a specific motherboard’s voltage regulator configuration in a peak (“spike”) condition for a short period of time.
  1. Default for socket AM4 is 140A on motherboards rated for 105W TDP processors.
  2. Default for socket AM4 is 90A on motherboards rated for 65W TDP processors.
And how this applies to us:
PPT: Maximum wattage - Volts + Amps combined, mostly relevant to heavy all core loads (This and undervolting arehow to get more MT performance)
EDC: electrical limits of the VRM in Amps - short burst maximums - Like Intels PL2
TDC: long term Amp limit, designed to prevent the VRM's overheating - like Intels PL1
PPT:
Lower to reduce sustained heat from the cooler, in constant heavy loads (like R23/benchmarks)
Raise to increase benchmark scores for all-core max load performance
EDC:
Lower to reduce high voltage/temp spikes at low core count load
Raise to increase low thread, boost performance (Games, 3D benchmarks)
TDC:
Lower to reduce VRM temps in sustained medium loads (like gaming)
Raise to overheat your VRMs :mad: (If set too low, it will limit the other two options as well.)
The best values vary by core count and CCX count, because of how much physical space each CPU design has to spread the heat out over.
Having one value too low could prevent the others reaching the limits you want
162 (0.17/day)
System Name Mypc
Processor AMD Ryzen 5 5600x
Motherboard MSI MAG B550M BAZOOKA
Cooling Coolermaster Hyper 212 Rgb
Memory Corsair 3600 mhz Cl16 ddr4 8x2
Video Card(s) Asus RX 6750 XT Rog Strix OC Edition
Storage Samsung 990 PRO 1TB + Samsung 980 Evo 50gb
Case Coolermaster TD500 Mesh White
Power Supply Corsair CX-650F RGB
What about BIOS settings such as, SVM mode, NX mode, PSS support, global c states and CPPC, CPPC preferred cores ? I heard those make huge cpu performance gains especially in games.
65 (0.15/day)
Processor Amd 5800x
Motherboard MSI MAG X570 TOMAHAWK WIFI Motherboard
Cooling Corsair h100i
Memory 32gb
Video Card(s) 3070ti
Storage Nve, SSD,
Display(s) 27 inch
Power Supply 850 watt
PPT:
EDC:
TDC:
Is there any app out there that can test each core and find the overall best values for PPT, EDC, TDC and co? I kinda just tried to choose what seems most stable. My current values are ppt 120 tdc 75A EDC 110A co values are all different but mostly -24 with two others being -17 and -16.
50 (0.06/day)
UK - Sheffield
System Name Maddogg Custom Build
Processor i9 14900KF 5.7ghz (ALL P CORES) 4.5ghz (ALL E CORES)
Motherboard ASUS PRIME Z690
Cooling Deepcool LT720 360mm AIO
Memory 32GB G.SKILL Trident Royal 4000mhz DDR4
Video Card(s) NVIDIA RTX 3090 FE
Storage Samsung 970 EVO NVME
Display(s) Gigabyte G32QC 31.5" 165hz 1440p
Case Lian Li O11 Dynamic EVO XL
Audio Device(s) Corsair Virtuoso 7.1 Headset
Power Supply Corsair HX1200
Mouse Corsair M65 ELITE Gaming Mouse
Keyboard Corsair K70 RGB mk2 SE
Software Windows 11 Pro (Ghost Spectre)
Benchmark Scores 3DMark Timespy - 21139 https://www.3dmark.com/spy/46840624
Set the following in your BIOS, under "CPU Features" or "AMD_CBS":
  • Global C-state Control = Enabled
  • Power Supply Idle Control = Low Current Idle
  • CPPC = Enabled
  • CPPC Preferred Cores = Enabled
  • AMD Cool'n'Quiet/PSS Support = Enabled
  • PPC Adjustment = PState 0
  • NX Mode = On (ALWAYS ON ITS LIKE BUILT IN ANTI VIRUS)
If you can't find certain settings, such as "AMD Cool'n'Quiet/PSS Support" or "PPC Adjustment", do not worry, they are of secondary importance. Some motherboard manufacturers just hide them.
Test for yourself i tried them with other settings and lost Score in Cinebench dramatically.
Also i run the 1usmus Universal Powerplan which goes hand in hand with these settings - https://www.techpowerup.com/download/1usmus-custom-power-plan-ryzen-3000-zen-2/
65 (0.15/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
  • CPPC = Enabled
What is this for???
50 (0.06/day)
UK - Sheffield
What is this for???
Sort of a question is this?? You can clearly see its Bios Settings in response to electronicworld's post. also the thread is clearly labeled 5800x & other Zen 3 Chips PBO Settings and temp fix .... :nutkick:Im trying to stay sane but some of your questions are off another planet dude.
65 (0.15/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Chilly willy man lol. So these settings you mentioned all make an actual difference in gaming performance, like a noticeable 10fps? I've never seen anyone post these before, everyone just says tinker with pbo settings and curve op that's why I'm asking.. Are any of these default and they all must be changed to these values?
Mussels
58,413 (8.16/day)
Oystralia
I made a long post in the generic Zen Garden thread, covering a lot of PBO settings. I'll edit this into the first post as well as a link, but it's worth viewing as it's covering a bit of why these PBO settings are defaulting too high, especially on zen3 CPU's (where they raised the internal hard-coded limits for overclockers, only to find motherboards just default to them all the time)
Ryzen Owners Zen Garden | Page 236 | TechPowerUp Forums
50 (0.06/day)
UK - Sheffield
@Mussels @freeagent or anyone in the know what PPT/TDC/EDC would you reccomend for R9 5900X?
Iv tried 170/118/140 (I dont think you can go above 140 EDC now with the new AGESA 1.2.0.8 without crashing) I get Kernel Power 41 (Task 63) Crashes on this setting now i'm dialling down to 142/95/140 (What i believe is stock) for 105W TDP CPU's?
PSU seems good. I can monitor my efficiency and power draw in iCue i did this while running OCCT POWER stress test and it stayed above 93% efficiency.
freeagent
7,622 (3.69/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
tabascosauz
7,674 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Memory 64GB 6000CL30┃32GB 3600CL14
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
What exactly do you want to do with this 5900X? Chase benchmark scores all day? Or just a solid daily? Yes, 142/95/140 is the default profile for it and is plenty with a bit of curve optimizer sprinkled on top. PPT and EDC are dependent on what your sample+board+BIOS wants, not what other people can do. Something around 160W might give a nice little boost without the V-F curve becoming too steep. With a bit of CO you can come down to say 130/x/120 without any performance loss compared to no-CO stock, stands to reason expanding PPT and EDC a bit in the other direction is fine too.
To help with tweaking, HWInfo will tell you how much PPT/TDC/EDC are limiting you under load. Otherwise there's nothing stopping you from setting 200-240W but no promises the 5900X you have will actually have much to show for it. Lot of heat, still doesn't catch a stock 5950X.
93% seems about right for the AX860i between 200-400W.
freeagent
7,622 (3.69/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Yeah pretty much, I use those limits to reach peak sc/mc boost.. fails hard in core cycler though.. but good for everything else :D
You probably wouldn't like how it will make your fans behave..
tabascosauz
7,674 (2.37/day)
Western Canada
System Name ab┃ob
got my hearing protection ready, hit me :cool: and 10 layers since it's cold as balls over there
freeagent
7,622 (3.69/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I have to say, those T30s are a really good fan! Even at "just" 2K they are fairly quiet.. they really put iPPC to shame in the db dept. :D
Its not cold anymore :laugh:
Its a good case for air cooling :rockout:
Edit:
Not sure if you have a PA120.. if you dont, you should check out a PS120SE.. I think you would be surprised :)
50 (0.06/day)
UK - Sheffield
I’m not trying to chase benchmarks cooling wise im good the EK block keeps it below throttling even at 200/200/160 I can’t get it stable though, at such high settings even with voltage llc, I also worry about the VRM temps at this extremity’s too,
So basically I’m chasing high single core not MT performance I game a lot and very occasionally for work I do a bit of AUTOCAD, but that’s about it. So single core performance is more what I’m chasing so what I’m asking is where would you advise as a starting point. I’m using 1usmus HYDRA for core optimisation too. I found a good curve with it for my 5800x so I trust it, I’m just trying to find a good starting point regarding ppt/tdc/edc really.
65 (0.15/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
I’m not trying to chase benchmarks cooling wise im good the EK block keeps it below throttling even at 200/200/160 I can’t get it stable though, it such high settings even with voltage curve I worry about the VRM temps at this extremity’s too,
What pbo and curve ops are you using in your 5800x?
50 (0.06/day)
UK - Sheffield
Core 1 to 8 (HYDRA 1.2F STABLE) Max Boost +150mhz
PPT/TDC/EDC
142/95/125
0 / 1 / 2 / 3 / 4 / 5 / 6 / 7
-10/-0/-20/-18/-12/-24/-16/-22
So i just ran HYDRA with 142/95/140
I got the following core offsets
Core 1 to 12 (HYDRA 1.3G) 50mhz boost 142/95/140
0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10/ 11
-22/-30/-24/-24/-20/-30/-24/-30/-30/-30/-20/-26
Does that look good to you? Just about to test stability running a core cycle with OCCT will report back when i learn more
Mussels
58,413 (8.16/day)
Oystralia
When I have it installed, I roll back from 1208 to 1203 and I run 240/160/190
I'll add that to the OP
Remember that PBO values do nothing for stability. They're power limits, NOT voltage limits.
Your stability is going to be the undervolt curve being too low and unstable at load transitions (low/zero load, crashing at idle etc) - or it's going to be DRAM/IF stability related.
Stress tests will never show undervolt related instabilities, because they're unstable at LOW load, not high load. They lower voltages at all power states.
Post a zentimings screenshot, if you havent altered your SoC or IOD voltages that'll explain instability even if you have the undervolt disabled.
People with the EDC limit - do your boards/that BIOS have this feature?
Buildzoid mentioned it. "Enabled" loosens AMD's EDC limits.
Part-specific EDC throttling could explain the issue, where it's limiting one specific part, rather than the value for the whole
50 (0.06/day)
UK - Sheffield
Thanks @Mussels , I contacted the guy i got the 5900X from he swapped it me for another brand new one. Even let me test it on his test bench, This one is now stable. Has a modest CO negative offset -16 all cores and -6 on the 2 CPPC Cores.
RAM is Optimised using DCFR Feature on Hydra 1.3G with XMP disabled, running 3600mhz and CL14-15-15-15-30 @ 1.45V (1.43 in BIOS)
14 (0.00/day)
Proper TDC setting (maximum for VRMs, not how the ratio of ppt/edc/tdc affects performance) requires knowing your Mboard's VRM components. So for example my board has 12 physical CPU vrms in a tripled-up, 4-phase design. The VRMs are rated for 50 amp, which should theoretically give a 600amp limit. But, VRMs are typically best at their 50% load (and Mboards typically built for such). The board is built to handle a 5950x, which even at a 250w, 1.35v load would demand ~185 amps. At 185 amps across 12 units, this works out to ~15.4Amp per VRM. Well within tolerances and within a "VRM efficient load" point. The Vishay ViC634 datasheet also shows that ~15 amps per unit at 500khz with 12v input is the ideal efficiency point, wasting roughly half a watt as heat. So as it looks my motherboard was literally built to handle an overclocked 5950X with the VRM bank operating entirely inside of the optimal efficiency zone.
With all of this taken into account I can know for certain that the motherboard itself is physically no limiting factor for my 5800x's performance, and I can play with EDC/TDC and never have to think about VRM stress or heat influenced performance limits. The limits solely rest on my CPU and how well it can be cooled.
As someone once said, knowledge is power.
OneMoar
There is Always Moar
8,748 (1.70/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
limitaiton isn't the board
limitation is the thermal density of the chip
unless you are using direct-die cooling you just can't get the heat out of the chip fast enough beyond 150w
Mussels
58,413 (8.16/day)
Oystralia
^ That
1,526 (0.64/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Cooling D5 clone, 280 rad, two F14 + three F12S bottom/intake, two P14S + F14S (Rad) + two F14 (top)
Memory 2x8 GB Corsair Vengeance bdie 3600@CL16 1.35v
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@MaddoggMiranda
unless your using win7 and/or pre 5xxx series cpu, the 1usmus power plan is improving nothing vs what win already has.
