- Oct 6, 2004
- 58,413 (8.16/day)
- Oystralia
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
I just did this to a PSU, since i'd ran out of superglueI used nail acrylic in the past on a 8800GT. It was easy to apply and worked well. Not sure if acrylic has any degradation concerns though though it never gave me any issues and card was inexpensive enough that it wasn't too concerning at the same time. I'd probably do it again on a relatively inexpensive GPU unless there is a clear and obvious reason to avoid it and use something else instead that's just as simple and easy. That card had terrible coil wine under load before and was perfectly quiet after. It was easy to apply too due to the brush.
It's not as good at the wick effect part, but it does work
