Samsung B-Die trying for 4000mhz
Deleted member 185158
I was on 3800 and they're Micron B die. I'm going to put it back on 3800 as I had the TRFC incorrect.
Micron B-dies should clock ok.
But the M-ATX boards seem to have their nuts chopped for memory overclocking.
For example, by B450-I ROG board stomps the living Fudge out of my Asus B450M-A for memory clocks. It is definitely a night and day difference.
The same holds true for the 2x DDR5 boards I have. A B660-I and a B660-G. The I-TX board will post up CL40 6400mhz all day no problem. The G model, with BCLK at least will not go over 6000mhz. Actually at this exact frequency, a lot of weird shit happens without a lot of dodgy tweaking and high memory voltages. This shouldn't be the case really... but it is.
That said, it's not your cpu or memory kit, it's the board. Just not designed well for memory OC, you've probably seen tons and tons of threads with B450 boards and Ryzen chips "can't enable XMP, defaults to 2133mhz"" which you NEVER see this issue if someone is running full ATX boards like Asus Hero or something like that.
50 (0.06/day)
UK - Sheffield
System Name Maddogg Custom Build
Processor i9 14900KF 5.7ghz (ALL P CORES) 4.5ghz (ALL E CORES)
Motherboard ASUS PRIME Z690
Cooling Deepcool LT720 360mm AIO
Memory 32GB G.SKILL Trident Royal 4000mhz DDR4
Video Card(s) NVIDIA RTX 3090 FE
Storage Samsung 970 EVO NVME
Display(s) Gigabyte G32QC 31.5" 165hz 1440p
Case Lian Li O11 Dynamic EVO XL
Audio Device(s) Corsair Virtuoso 7.1 Headset
Power Supply Corsair HX1200
Mouse Corsair M65 ELITE Gaming Mouse
Keyboard Corsair K70 RGB mk2 SE
Software Windows 11 Pro (Ghost Spectre)
Benchmark Scores 3DMark Timespy - 21139 https://www.3dmark.com/spy/46840624
dgianstefani
TPU Proofreader
4,374 (1.89/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus AMD Raw Copper/Plexi, HWLABS Copper 240/40+240/30, D5, 4x Noctua A12x25, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MHz 26-36-36-48, 56.6ns AIDA, 2050 FLCK, 160 ns TRFC
Display(s) 32" 240 Hz 1440p Samsung G7, 31.5" 165 Hz 1440p LG NanoIPS Ultragear
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel with pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, transparent full custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White & Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19053.3803
Benchmark Scores Legendary
Just because the RAM can do 4000 MT (not MHz) doesn't mean the CPU can.
966 (0.48/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
I'm currently in the same with the 4000 c19 series, did you manage to make it stable?
If you are running an APU like a 5600G or 5700G etc then 4000 should be attainable with some tweaking sadly I don't have an APU to give you settings.
If you are running ZEN3 5600X, 5800X etc then 3800 CL15 is the most easy to run on these sticks with just 1.45V.
G.Skill 4000 C19 I have 5 of these kits and all of them can do these timings.
While its possible to run at 4000 1:1 you will likely get WHEA errors without running high VSOC and VDIMM.
Best stability was around 3933 CL15 higher than this and random WHEA erros would pop up.
G.SKill 4000 C19 Samsung B-die
311 (0.05/day)
virginia, usa
....with fclk 1:1, at least!
B-Die is absolutely wild to play with when the CPU/IMC isn't a limitation. Even only 1.5v on bdie should get some pretty sweet frequencies and timings. I'd focus on figuring out what vSOC is needed for high fclk on that CPU
AMF
634 (0.58/day)
USA
System Name MR T System price 2280$
Processor Ryzen 9 3900x 4.7Ghz boost pbo +50 enabled 325$ - offset auto voltage llc auto cpu and soc
Motherboard ROG STRIX X570-E Gaming 125 $ open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.395v 16-19-16-20-38-58-1T $96
Video Card(s) Asrock RX 6950XT Oc formula Oc edition 705$ 2700 2800 boost 1090v 2376mhz mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie16x4
Display(s) V505-J09 Vizio 4k HDR 299$ oc 5hz
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) TV junk ewww
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Logitech ERGO Trackball 35$
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
