Technical Issues - TPU Main Site & Forum (2023)
Status
Not open for further replies.
1,066 (0.87/day)
System Name The Sparing-No-Expense Build
Processor Ryzen 5 5600X
Motherboard Asus ROG Strix X570-E Gaming Wifi II
Cooling Noctua NH-U12S chromax.black
Memory 32GB: 2x16GB Patriot Viper Steel 3600MHz C18
Video Card(s) NVIDIA RTX 3060Ti Founder's Edition
Storage 500GB 970 Evo Plus NVMe, 2TB Crucial MX500
Display(s) AOC C24G1 144Hz 24" 1080p Monitor
Case Lian Li O11 Dynamic EVO White
Power Supply Seasonic X-650 Gold PSU (SS-650KM3)
Software Windows 11 Home 64-bit
It doesn't happen in normal use, only like I said, when I press Back and then send a message.
My clock is in sync.
1,066 (0.87/day)
Of course, and they are the anti-DDOS industry leaders (like every other company out there).
Sure.
5,323 (0.76/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
The standard extortion tactic. I really wish people who did that would die in the world's slowest fire, because they are the lowest of human garbage.
17,955 (2.68/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
W1zzard
Administrator
27,076 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
I think it got moved by a moderator
2,742 (3.01/day)
Knoxville, TN, USA
So they won't be able to see any responses?
Solaris17
Super Dainty Moderator
25,938 (3.79/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard MSI MPG Z790I Edge WiFi Gaming
Cooling be quiet! Pure Loop 240mm
Memory 64GB Gskill Trident Z5 DDR5 6000 @6400
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Philips Evnia 49M2C8900
Case LANCOOL 205M MESH Snow
Audio Device(s) Moondrop S8's on Schiit Hel 2e
Power Supply ASUS ROG Loki SFX-L 1000W
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
Looks like it did. I just fixed this. Caught this conversation in passing. All is well now :)
W1zzard
Administrator
27,076 (3.71/day)
Memory 48 GB
9,340 (6.05/day)
Louisiana
Keyboard G710+x3
Ug what's up with firefox and the drm content banner just for going to the forums page yes I have drm nonsense off this hasn't been happening until recently though.
Solaris17
25,938 (3.79/day)
Alabama
VR HMD Quest 3
Probably someone’s profile post. Not something to do with TPU specifically.
people embed shit like this. Video links, Spotify playlists etc.
this content is cross linked so when you load the page the browser tries to load remote content and that service likely does a check and when the browser sees DRM off it pops a message.
9,340 (6.05/day)
Louisiana
Keyboard G710+x3
Yeah I saw that stuff on the right column
uBlocked it but still happens just a pestering thing not sure why FF is popup though triggers should be off like suggest extensions as you browse/..
2,731 (1.17/day)
Buenos Aires, Argentina
System Name System V
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Storage SHFS37A240G / DT01ACA200 / WD20EZRX / MKNSSDTR256GB-3DL / LG BH16NS40 / ST10000VN0008
Case NZXT Source 210
Power Supply Corsair CX650M
Mouse Microsoft Trackball Optical 1.0
Keyboard HP Vectra VE keyboard (Part # D4950-63004)
Software Whatever build of Windows 11 is being served in Dev channel at the time.
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
As Lex said above, Youtube doesn't trigger it. Spotify however does.
9,340 (6.05/day)
Louisiana
Keyboard G710+x3
Looks like it stopped :cool:
Solaris17
25,938 (3.79/day)
Alabama
VR HMD Quest 3
Solaris17
25,938 (3.79/day)
Alabama
VR HMD Quest 3
Hey, I've been running into some issues accessing TPU for a week or so now. Maybe longer but I have only put conscious effort into hunting it this last week.
At first I thought it was a DNS issue on my end. So I went through my response logs and everything looked normal.
I then thought it was my adblockers but I dont have them enabled for TPU.
I connected to my racks in Florida and did not have issues browsing remotely.
I moved on to behavior and didnt experience the issue on any other site (I have multiple default tabs loading)
Finally I got off my ass and switched browsers incase this was a specific issue with chrome.
I decided I should be a real engineer for 5min and decided to test after everything else failed.
As you can see the loss column starts at "100%" this means nothing as the transport router is simply denying echo requests, pretty common. The same with the 75% indicated by 32.130.89.13. This address belongs to ATT and since ATT is my carrier is probably the network demarcation. So ignore the 75% as well especially since it has a trailing 0% this reaffirms network demarcation since its likely a border router on an edge network so it also will ignore most echo requests.
The actual issue begins after the entry into twelve99's (Telia) network. After the edge router: atl-b24-link.ip.twelve99.net
You can see the "loss" continues after entering the network edge. It enters Atlanta (atl), Then hops on the backbone (bb1) transit link to Reston (Virginia)(rest) then continues on the backbone link to New York (nyk) and continues until finally reaching the TPU servers at the nyc exchange (nyc-cyx distribution). Generally as im sure you know. You ignore the first indications of loss, doubly so if the hop afterwards indicates 0% loss. As this is usually transit routers ignoring echo requests so they dont consume load. (It could also be private transport links between networks) however; when loss is indicated sequentially in the chain that is usually an /actual/ indication of loss and a network issue. Be it congestion or otherwise.
I double checked this with a more basic tracert in terminal, and if you look closely the transit into twelve99 fails to reponed and the transport routers that do indicate a massive latency spike.
It really is a noticeable problem for me. (Likely others using this route) I'm talking like 30+ seconds to load the basic forum text boxes pictures and sometimes take hundreds of seconds.
This is pretty intermittent, but its consistently intermittent. If at all possible could you open a ticket with there NOC and have the route adjusted? If it helps you at all simply tell them the route to ATTs network is having issues. They will probably re-route over a diff link.
@W1zzard
Thanks.
Here is a longer one I had running during this post.
EDIT: I got pissed and actually checked there looking glass too. What a mess. https://lg.twelve99.net/?type=traceroute&router=nyk-b4&address=138.199.40.9
I cant be sure if the issue is on Telia or cdn77 but that connection is having issues.
Lets take a look.
mmmm no there router inside the equinix DC can reach cdn77 without issue. So this is a Telia/twelve99 route problem not ingress into cdn77.
W1zzard
Administrator
27,076 (3.71/day)
Memory 48 GB
what kind of issues? page not loading at all or just loading slow? send me your ip in a pm
9,340 (6.05/day)
Louisiana
Keyboard G710+x3
Have a little server melt down a little while ago ?
Accurate message on the error
Try refresh a in a few minutes hehe
FreedomEclipse
~Technological Technocrat~
23,407 (3.76/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Website seems to be running a little slow. Are the mice in the basement doing alright?
W1zzard
Administrator
27,076 (3.71/day)
Memory 48 GB
7,146 (1.45/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Video Card(s) Sapphire Pulse RX 7900XTX + under waterblock through Kryosheet
Storage Optane 900P[W11] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO[FEDORA]
Mouse Razer Basilisk
Software FEDORA 40
Frick
Fishfaced Nincompoop
18,950 (2.85/day)
Piteå
System Name Black MC in Tokyo
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
About loading times, this weekend I got an error messege saying something about having troubles with my internet connection. When I tried to go to the TPU forums. I forgot to take a screenshot. I thought it weird that a website I was connecting to would think I wasn't connected to the internet.
Status
