Which air cooler for a ryzen 9 5900x
638 (0.20/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling The Arctic Liquid Freezer III 420 / Enermax LIQMAX III ARGB 360 AIO
Memory Patriot Viper Steel DDR4 16GB (4x 8GB) 4000M TRIDENT Z F-43600V15D-16GTZ /G.SKILL DDR4
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case TT 37 VIEW 200MM'S/ NZXT Tempest custom
Audio Device(s) Sharp Aquos
Power Supply FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum - EVGA 1300G2/Corsair w750
Mouse G502
Keyboard G413
#22
211 (0.52/day)
Warszawa
You prefere steve from gn ?
BTW another one I don't like due to being airflow psycho living in the world where any case which isn't top ventilated on his charts will burn your components.
But if you aim to run your cooler with Steve's 35 dBA, so Arctic's ~1500 rpm or other averagely ~1200, his review is fine to look at. But I from the start meant being able to go lower with noise with bigger coolers.
638 (0.20/day)
Mouse G502
Keyboard G413
I use Asus Dark Hero as well for my 5950X , I use ASUS DOCS ,plus Precision Boost 2 , single core is enhance , max temp is similar to stock , so happy with that .
Lack of cooling , will show up fast in BenchMate 2.5b .
1,795 (0.41/day)
Denmark
Processor ryzen 5 5600
Motherboard MSI B550 a-pro
Cooling Theremalright peerlees assassin 120 black
Memory 2x16gb 3600mhz cl 16 corsair vengeance lpx
Video Card(s) GIGABYTE GeForce RTX 3060 WindForce OC
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) O-Noorus PA-316 Triangle Esprit Titus Ez
Power Supply Corsair RM850X White
Mouse Logitech G PRO Superlight
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free bitdefender
Impressive the peerlees phantom 120 beats just about every low budget air coolers, those who are better costs minimum twice as much up to 3 times as much (noctua)
Noctua NH-U12A is overpriced relative to it's performance like crap,hell atleast the NH-D15 is better by a good margin to the NH-U12A
5,668 (2.96/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
What else is new?
17,993 (2.68/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
1,795 (0.41/day)
Denmark
17,993 (2.68/day)
Well my NH-U12A isn't really crap though as you can see in my screenshot...
But it seems you don't have the budget and don't appreciate Noctua coolers...
You can always buy something on the cheap, check out ali express.
5,668 (2.96/day)
Poland
The artic freezer 36 and we havn't seen the new Noctua NH-D15 (i will beat it won't be cheap)
You're not stating anything that wasn't said before in this thread. Also, people have already posted the review for Freezer 36. You have everything you need to make a decision.
3,952 (0.83/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Noctua U12A is designed to give larger cooler like performance for cases that limit air coolers to 160mm and under while also not putting as much physically stress on the mobo. It does a very good job at that for a price, obviously Noctua has better coolers for less if your case can fit them.
1,058 (0.25/day)
Babylon 5
System Name DaBeast! DaBeast2!
Processor AMD AM4 Ryzen 9 5900X 12C24T/AMD AM4 RYZEN 9 3900X 12C/24T
Cooling Thermaltake Water 3.0 360/Thermalright PA 120 SE
Mouse Logitech G703/Logitech G603 WL
Keyboard Logitech G613/Keychron K2
Software Win11 Pro/Win11 Pro
I have a TR PA 120 SE on my 3900X and it's doing a bang up job at cooling it, does just about as well (maybe a little worse off compared to the TT Water 3.0 360 ARGB AIO I had before it). It's in a different case though, the 3900X (+ GB X570S Aorus Elite AX) is now in a SOLDAM XR-1 and the Tt Water 360 AIO is cooling my 5900X (+ GB X570 Aorus Xtreme) in a CM H500M case. So, my recommendation is a TR PA 120 or its successor, but IF OP already has a PA120, I don't see a need for any sort of change....
1,601 (0.67/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Cooling D5 clone, 280 rad, two F14 + three F12S bottom/intake, two P14S + F14S (Rad) + two F14 (top)
Memory 2x8 GB Corsair Vengeance bdie 3600@CL16 1.35v
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@gasolin
takes about 2min to set the power saving profile (turning off any power saving features like wifi/usb/pci meant for portable stuff),
and set max cpu perf to 50%.
doing this since i7 3700K, as i dont need +4 cores at full clocks to surf o stream stuff,
done the same on my 5950, even that is under water.
ignoring for a moment taht 'noise" on most coolers incl aio, is from
1 "cheap" fans.
2 lazy folks that dont care to setup a fan/cooler properly to not ramp up unless gong above
50-60C.
not a single build i have done in past 20y where a user complained about it being noisy,
and that's incl ~25$ arctics and ~120/130$ Corsair/Arctic and Alphacool AIO (rad as exhaust).
1,795 (0.41/day)
Denmark
50% is not at all enough, i bought a 12 core cpu, not 6 core
fb games use my cpu above 50%
1,601 (0.67/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
u set up 2 profiles,
power saving (low load like surfing/streaming),
and balanced for gaming/benching/video editing (min cpu to 99, max to 100%), switch between them based on use.
even without a UPS (which adds the battery icon on taskbar allowing for quicker switching),
there are tools for win, that u can use.
heck there are online guides how to have 2 cmds on the desktop
that get double clicked, to switch between profiles.
power plan switching
211 (0.52/day)
Warszawa
Stop tying price with performance.
E.g. longevity of Noctua's fans is legendary. I haven't had opportunity to try new Thermalrights, but looking how cheap they sell dual towers with two fans, I would be surprised if their craftmanship wasn't bottom of the barrel :laugh: Pretty common are complaints about coming with SE coolers fans starting to rattle after not long, few weeks or month what fits my suspicion well.
Other thing you pay for when going Noctua is their customer service. Renowned and supporting almost all coolers they've ever made with kits for new sockets. TR does kits too, but I would like to know how it works in practice. They're for sale online, but from what I've seen pretty expensive when Noctua's is known for sending them for free at least during six-year warranty.
BTW these are two reasons why even most expensive Noctuas happen to be the cheapest in the long run :]
1,795 (0.41/day)
Denmark
My Thermalright Peerless Assassin 120 Black has no problems with the fans and it is close to 9 month old
986 (1.63/day)
System Name Windows
Processor 13900K
Motherboard Pro Z790-A WiFi
Cooling Arctic LF III 360
Memory 32GB 6600 CL32
Video Card(s) RTX 4090
Display(s) MSI MAG401QR
Case Phanteks P600s
Power Supply Vertex GX-1000
Software Win 11 Pro
Benchmark Scores They suck.
I'm not really seeing an issue here :confused:
The OP is overclocking the 5900X with an extra 80 watts past spec with a $30 air cooler. What's the problem?? The temps are exactly where they should be. You're not going to go much lower even with the best cooler and 2000+ RPM fans.
If you have a fetish for low temps at high wattage, buy intel.
1,795 (0.41/day)
Denmark
when playing games my cpu in chrome goes above 70c
2,494 (1.42/day)
System Name Not a thread ripper but pretty good.
Processor Ryzen 9 5950x
Motherboard ASRock X570 Taichi (revision 1.06, BIOS/UEFI version P5.50)
Cooling EK-Quantum Velocity, EK-Quantum Reflection PC-O11, EK-CoolStream PE 360, XSPC TX360
Memory Micron DDR4-3200 ECC Unbuffered Memory (4 sticks, 128GB, 18ASF4G72AZ-3G2F1)
Storage Samsung 2TB 980 PRO 2TB Gen4x4 NVMe, 2 x Samsung 2TB 970 EVO Plus Gen3x4 NVMe, AMD Radeon RAMDisk
Power Supply Corsair RM750x
Mouse Logitech M575
Benchmark Scores Typical for non-overclocked CPU.
One thing to consider with Noctua is their fan noise "sounds better". It might just be me but even at audibly high rpms they seem to have a nicer sound than other fans. Also some Noctua coolers come with the Ryzen offset mounting kit giving them a slight advantage over other coolers.
3,952 (0.83/day)
sounds normal, that CPU is designed to run hot and won't start to throttle until 85 or 90c if I recall (forget which)
2,494 (1.42/day)
Mouse Logitech M575
When I had my 5950x on NH-L9a it throttled around 90c so I think you are correct on that. I love your system specs btw.
17,993 (2.68/day)
#22
211 (0.52/day)
Warszawa
You have already almost the best air cooling can offer and even yourself link reviews showing that changing it with "stronger" won't shave you more than few degrees. It all when your 70C is totally fine for this CPU. You must be from the gang of temperatures always too high. All the time monitoring temps and living in fear of your precious components dying from overheating when they don't. It's what needs to be changed here, not an air cooler ;)
2,494 (1.42/day)
Mouse Logitech M575
However:
Storage "Stronger than yours" :confused::p:D
I imagine storage HDD arms are strong, perhaps strong enough to rip off heads if they touch the forbidden platter?
