1usmus Custom Power Plan for Ryzen 3000 Zen 2 Processors
2,020 (0.48/day)
You might want to add the option to display the power plans with the script after yours is imported. Since this setting is on the old control panel some people might not find it right away:
%windir%\System32\control.exe powercfg.cpl
Also it's possible to enable the power plan with the script. Perhaps ask for confirmation from the user?
powercfg /S 95deb0c7-ed9f-4c7c-8251-bda630a27498
Currently using 3800X on X570 Master with BIOS F7B (1.0.0.3 ABBA). Will test the effect in the coming days. Thanks for sharing 1usmus.
1usmus
AMD Memory Guru
61 (0.03/day)
Ukraine
Think he's asking if the excessive light load boosting that Amd fixed by reducing Windows-CPU communication to 15ms would be undone by your new power plan.
Would it? I'm quite concerned too, don't want max boost when I open a window because my fans go crazy.
1 ms response, but I changed the settings that cause the processor to go to P0 in idle. Minor tasks and short-term peaks provoke him less.
iO
531 (0.11/day)
Germany
Processor R7 5700x
Motherboard MSI B450i Gaming
Cooling Accelero Mono CPU Edition
Memory 16 GB VLP
Video Card(s) RX 7900 GRE Dual
Storage P34A80 512GB
Display(s) LG 27UM67 UHD
Case none
Power Supply Fractal Ion 650 SFX
3600 w/ 1003abba, does help to tame R15 a bit
but at the same time kills the much improved scheduling of R20
xxquaaxx
2 (0.00/day)
Great Job !usmus .My temps went down and my cores now at max speed 4.4 ghz amd 3700x I have noticed as well better preformence scores in benchmarks .I will test some games and I will provide feedback
iO
531 (0.11/day)
Germany
Processor R7 5700x
Memory 16 GB VLP
Case none
1usmus
AMD Memory Guru
61 (0.03/day)
Ukraine
PBO disabled and temps dropped maybe ~2C to 54C
1) PBO enabled (default)
or
2) Try to write a log using HWINFO.RM has problems reading registers. While reading, information may be overwritten there and you may see incorrect data.
Gambit2K
2 (0.00/day)
If anyone could point out where I can find the "Power Supply Idle Control = Low Current Idle " options is in the Asus 1.0.0.3ABBA it would be appreciated.
99 (0.05/day)
Processor AMD Ryzen 3700X
Motherboard Asus X570 TUF Gaming Plus
Cooling NZXT Kraken X62
Memory G.Skill 2x8GB 3600CL16
Video Card(s) Asus Strix RTX 2070
Storage Samsung 850 SSD 500GB
Case NZXT S340 Elite
Doesnt have the "CPPC","CPPC Preffered Cores" settings on Asus X570 TUF, after enabling everything suggested I did not see:
- higher boost clocks, maximum was 4ghz all core (with PBO its 4,15ghz)
- higher CB scores
In CB R20 single thread test, the boosting cores varied between core0 and core1, so I guess its working.
bug
14,190 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
No
To work on a CPU, the CPU needs to be exist. There is nothing called Ryzen 2.
Ah, old school software, like they did back in the 70s... :p
406 (0.07/day)
czech republic
System Name AMD forever, AMD overclocker
Processor Athlon 3000+ Venice, Athlon x2 4600+ EE Windsor,x4 955 BE@3.9GHz AIR, X4 965 BE, x4 970 BE, x6 1090T
Motherboard Asus C5F-Z, Asus C5F, Asus C4E, Asus C4F, Asus RIIIE, Asus R4E, Asus M5F, Asus M6F, Asus M7H,
Cooling Corsair H100, Swiftech H220, CM Hyper 212, Xigmatek 1283 DK+Ultra Kaze, CM V6GT, Noctua NHD14
Memory Kingston Hyper X, 1600 A-Data 2000x, Corsair Dominator GT 2000 MHz, GSkill TridentX 2400MHz, HyperX
Video Card(s) HD3870 512MB GDDR4, HD5770 1024MB GDDR5, ATI HD4870, HD 6870 GDDR5, HD 7870,Radeon R9-270X
Storage 2x 320GB WD+Samsung, 1x 500 GB Samsung, SSD X-25, SSD HyperX, SSD Seagate, SSD Corsair GT
Display(s) BenQ 24" 24XL
Case HAF 922, Aspire X-Cruiser, benchtable Wroom
Power Supply Seasonic 500W and Seasonic 650W, Corsair AX 1200W, Zalman Goldrock 750, Galaxy OC edition 1200W
Software x64 win 7 and x86 Win XP SP3
Benchmark Scores you rather I do not want to see .. :-D !!!Thuban coming soon, new secret Gigabyte mobo too !!!
Thank you for great work for us Usmus!
2,020 (0.48/day)
Testing 3800X in CB20 i got 5067 MT and 527 ST.
MT is roughly the same it was before but ST did increase from 524. I did not bother disabling PBO right now and changing any BIOS settings. I see Gigabyte has released F10a for my board with 1.0.0.4B so i need to install that first.
19,378 (3.49/day)
So, 524 and 527 are not roughly the same... (even though it is not even 1% increase and within run variance)... what does roughly the same mean for the MT testing?
gandorfin
1 (0.00/day)
Gigabyte X570 Aours Elite f10a bios (1.0.0.4b) seems to be missing some of those options
  • CPPC
  • AMD Cool'n'Quiet
  • PPC Adjustment
are they just not implemented or I'm blind?
217 (0.04/day)
In your walls
System Name Bongfjaes
Processor AMD 3700x
Motherboard Assus Crosshair VII Hero
Cooling Dark Rock Pro 4
Memory 2x8GB G.Skill FlareX 3200MT/s CL14
Video Card(s) GTX 970
Storage Adata SX8200 Pro 1TB + Lots of spinning rust
Display(s) Viewsonic VX2268wm
Case Fractal Design R6
Audio Device(s) Creative SoundBlaster AE-5
Power Supply Seasonic TTR-1000
Mouse Pro Intellimouse
Keyboard SteelKeys 6G
Yeah, asus has like.. half of these settings lol, 10/10 bios team
5,717 (0.92/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
AMD need to pay this guy, or better yet HIRE this guy. Single handily fixing AMD’s performance problem with Zen2 boosting.
7 (0.00/day)
  • CPPC
  • AMD Cool'n'Quiet
  • PPC Adjustment
I'm in the same situation. Aorus master x570, f10a
Now it use the fast cores on ccx0 but the faster core is on ccx1 and never use it..
OctavianPrime
1 (0.00/day)
one question, i have laptop fx505dy with 3550H cpu and rx560x gpu. should this powerplan work on this cpu?
96 (0.04/day)
Germany
Processor Ryzen 7 3700x
Motherboard AsRock X570M Pro4
Cooling Be Quiet Dark Rock Pro 3
Memory 4 x 16 GB Crucial Ballistix Sport LT red 3000C15 @ 3800C16 Micron rev E
Video Card(s) Zotac RTX 2070 mini
Storage Corsair MP510 1.92TB
Display(s) Samsung U32J592UQU 31.5" UHD + Fujitsu P19-2 19" 1280x1024
Case Jonsbo U3 mATX
Audio Device(s) ATH-M50
Power Supply Corsair SF600 600W SFX [currently RMAed]
Mouse Logitech G500
Keyboard QPAD MK-50 mechanical
Software Win10Edu_64
@OctavianPrime That is an APU based on Ryzen+, so it will not make a difference because CPPC2 is not implemented on those. :) But it likely will also not harm anything, so you might give it a try.
I have a 3700x at home and might try this out when I get back and have some time. Thanks @1usmus !
2,020 (0.48/day)
My previous MT scores were in the 5060-5075 range. So it is roughly the same. But like i said im not running 1.0.0.4B yet and i have not disabled PBO either.
EDIT: So i closed all background programs and got 5093 MT. Not bad.
